GDE Tune (Green Diesel Tune) - Page 51 - JeepForum.com
 1Likes
post #751 of 1279 Old 06-15-2013, 09:00 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
Mileage report
I took my first short trip using since my DPF delete. Drove 276 miles, mostly freeway, about 20 miles in town. I drove 65-72 on the freeway depending on speed zones and traffic. Used my cruise control. Did not do anything unusal to improve mileage...just drove as usual.
Upon returning, I check mileage using careful manual calculation. 25.27 MPG.
The EIC was showing 22 & 23 all day.
Chirpz
2007 WK 3.0L CRD, Quadradrive II, GDE EcoTune, DPF-Delete
4xGuard Front, Rear, Belly, & Side Rails, Factory Skids
EHM MOD, Garmin Mechanic EcoHD, K&N Filter (Deleted)
Chirpz is offline
post #752 of 1279 Old 06-17-2013, 09:13 AM
Zlartibartfast
2007 WK
Originally Posted by TangoTango View Post
So what happens if the DPF is missing? Is there some kind of UREA container you need to keep full for any reason?
if your DPF is "deleted" then you just need a tune that removes the regeneration cycle altogether. Urea is only required for DPF equipped diesels that were made to use it. Neither my CRD nor my 09 VW TDI use Urea in a regen.
I went back to my Eco tune after driving about 1500 miles on the Hot tune. I like the snap of the hot tune but in NOrush-hour traffic I was losing MPG because I couldn't keep it in higher gears. w/Eco I almost never have to rev above 2K RPM but w/Hot it always wants to run up to 3K before upshifting.
I still have my DPF intact.
Zlartibartfast is offline
post #753 of 1279 Old 06-26-2013, 08:10 PM
fishinbama
2007 WK
I have a questions for GDE, do you guys make a tune for the 2013 passat tdi 6manual? I just put a deposit down on one. Keeping my jeep though.
2007 limited crd 2wd, 3.07 ratio, GDE eco tune, dpf delete, tnadanzig resonator delete
fishinbama is offline
post #754 of 1279 Old 06-27-2013, 06:36 AM
GDE
2005 KJ Liberty
Not yet. The OBD flash tool will not work on the new diesels. Tuners need the ecm from the vehicle to flash and then return to the customer. We have not got into this approach yet as it requires a large investment in hardware. GDE
GDE is offline
post #755 of 1279 Old 06-27-2013, 02:39 PM
Zlartibartfast
2007 WK
Hey fishinbama (fellow TDI owner here....) at the risk of committing a hijack, I'd suggest you check out http://forums.tdiclub.com/forumdisplay.php?f=13 for specifics about a TDI tune
BTW Keith is on that forum, as well - it's how I first found out about GDE, before I bought my WK CRD
post #756 of 1279 Old 06-27-2013, 11:58 PM
terrasmak
2007 WK
GDE was just ordered for my dads WK
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
terrasmak is offline
post #757 of 1279 Old 06-28-2013, 01:00 AM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
He's gonna love it.
Chirpz
Chirpz is offline
post #758 of 1279 Old 06-28-2013, 03:07 AM
quigebo
Hi GDE,
Im in OZ and have one of Murchison Products full 3" ss systems on my 07 WK which Id expect has the DPF delet as theres a straight pipe there.
Question is I've had your tune for several years now, and I'm very happy with it. You only had the eco tune available then(I think), and I was wondering if I need to get a dpf delete upgrade and does the hot tune come standard now as it wasnt an option when i got mine?
As I said another happy customer thats for sure
quigebo is offline
post #759 of 1279 Old 06-28-2013, 04:02 AM
ryann04
2008 WK
Originally Posted by quigebo View Post
Hi GDE,
Hey, The DPF Delete Tune is an "extra". It is an additional $100. It will work with both your Eco-Tune and/or Hot-Tune.
2008 - Jeep Grand Cherokee - 3.0L CRD - Quadra Drive II - GDE Hot-Tune - OME HD Lift Kit - OEM Full Steel Skids
Blue WK Club Member #42 // DIESEL FTW !!!! -Ryan
ryann04 is offline
post #760 of 1279 Old 06-28-2013, 08:17 PM
SSF556
2008 WK
Hi GDE,
You do not need a DPF delete because you do not have DPF....lucky
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #761 of 1279 Old 06-28-2013, 08:57 PM
quigebo
hey scootr29, Im not sure about this but wont the ECM try to do a regen on the DPF even though its not there?
I think your talking about the actual DPF delete pipe, I'm asking GDE if my tune would have the DPF delete upgrade as I've had my Eco tune for a few years now and Im not sure there was a delete upgrade tune then. They were only just developing the "hot" tune I think, but i could easily be wrong
quigebo is offline
post #762 of 1279 Old 06-28-2013, 09:35 PM
Cherokee30D
2007 WK
I also have Murchison Products 3" stainless exhaust and GDE Tune.
After checking with Stu (Murchison Products), he only sells the Eco tune.
He won't sell the Hot tune.
Very happy with my set up.
Cheers, Craig
Cherokee30D is offline
post #763 of 1279 Old 06-28-2013, 10:05 PM
TurboDiesel
2008 WK
yea i thought the WH and XH didnt come with a DPF...
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline
post #764 of 1279 Old 06-29-2013, 04:41 AM
chrali
2006 XK Commander
XH does dunno about WH
Encourage alternative fuels - use all the petrol!
GDE HOT Tune
chrali is offline
post #765 of 1279 Old 06-29-2013, 07:44 AM
SSF556
2008 WK
No..your Jeep's ECM does not have regen programmed in from the factory. So you would have no need to purchase the "DPF delete" option from GDE.
Australia, UK etc Grand Cherokees did not have DPFs.
2008 CRD QT2
SSF556 is offline
Green Diesel Engineering tune for WK GDE WK Grand Cherokee & XK Commander Forum 87 06-01-2016 01:19 PM
tune up for a 05' Free-Willy WK Grand Cherokee & XK Commander Forum 0 01-07-2010 06:49 AM
95 ZJ Tune-Up ?'s trontheman89 ZJ Grand Cherokee Forum 2 11-07-2008 11:18 AM
4.7 tune-up, non H.O. H3RESQ ZJ Grand Cherokee Forum 15 01-15-2007 07:21 PM
Tune Up on a 99 GC? MFairbourn ZJ Grand Cherokee Forum 2 07-17-2004 01:45 PM
