GDE Tune (Green Diesel Tune) - Page 49 - JeepForum.com
 1Likes
post #721 of 1280 Old 05-03-2013, 07:03 AM
Zlartibartfast
2007 WK
it's worth noting that Keith @ GDE has been tuning other CRD's for quite some time, including MB and VW. I can't say how my engine will be running after 50K miles on the GDE tune(s), but I can say that right now it's running better than when I bought it. 5K miles on the Eco tune, now 1K miles since I flashed the Hot tune, no complaints.
Zlartibartfast is offline
post #722 of 1280 Old 05-03-2013, 01:46 PM
Tuco
Tuco's Avatar
2007 WK
Had to be in Nelspruit at 9:00 this morning, but woke up very early and could not get back to sleep.
So left just after 5:00 after filling up and decided to test the Jeep's fuel consumption at 100km/h true speed on the gps. Above 100 aerodynamics tend to stuff up consuumption.
Got to Nelspruit and filled up immediately. Pleasant surprise: 27,7mpg at an average speed of 56mph.
Not bad for a permanent 4x4 with a lift, bigger tyres, 5 speed auto and a heavy body. And driver.;D
And the GDE Hot tune.
Back got 21mpg at an average speed of 73mph.
Total distance 400 miles.
Its not clear what units you are using here (US vs imperial gals?). Your average is 24.35 mpg. This is about what I get on highway with a stock set up and after many thousands of miles of data.
So how are you folks computing MPG's? I hope its not with the EVIC (especially if tire size has been changed!) or with a single one-way trip or tank of fuel. I see so many posts where someone gets outstanding mpg's. When in reality they are going down a mountain or with strong tail wind or they simply dont know how to do the math. To get an accurate estimate of MPG change after installing a product like GDE, it will take many tanks and many miles and many conditions to determine. A one-way trip of a couple hundred miles means nothing to me and it should mean little to anyone.
Sorry for the rant...
07 WK CRD Limited
Tuco is offline
post #723 of 1280 Old 05-03-2013, 04:07 PM
quicksilverado
2007 WK
I average about 27 mpg on the hwy at 70 mph. 50/50 hwy city I average around 25 mpg. Just made a trip from Smyrna ga to Bristol tn. Drove thru the mountains and could only drive 60-65 mph for most of the trip. Mpg on the trip up was 28.4 for the 300 mile trip. On the trip back I did some site seeing on back roads. Some of the roads I could only drive between 30-45 mph. 450 miles on that tank I got 29.3 mpg. I have taller tires and hand calculate my mileage for every tank. Any faster than 70 mph and the mpg drops fast. Ran 75 mph all hwy for a tank and got just over 26 mpg. I drive conservative and usually run at the speed limit.
07 Grand Cherokee Limited CRD 4X4 GDE tune
00 Silverado 10 sec work truck
quicksilverado is offline
post #724 of 1280 Old 05-03-2013, 04:17 PM
BAH101
2008 WK
Ok, I installed the ECO w/o delete in April 2012, upgraded to the ECO tune w/delete in Nov.
During the time with just the ECO tune, I tracked on paper every fill, marking down the mileage on my fuel receipt.
My exel spreadsheet, corrects for my mileage due to my oversized tires.
So, during that period, I drove 16416km (10199m) and used 1745.775 litres of summer blend diesel (461.18US Gal)(362.6imp Gal).
So, my mileage, combined, about 80% highway, 20% city works out to:
10.3 liters/100km
27.4 mpg (imp gal)
22.8 mpg (US gal)
I have not had as good figures with the ECO/delete yet, as it has been very cold since November and have been using winter blend fuel. But, since I installed it, my figures have been 26.1imp Gal, 21.7US gal, 10.9 l/100.
Forgot to add my pre tune/post lift and larger tire mileage:
25.4 (imp) mpg
11.4 l/100
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #725 of 1280 Old 05-04-2013, 12:06 AM
Rainier
2006 WK
Actually I use fuelly for all my calculations.
Rainier is offline
post #726 of 1280 Old 05-11-2013, 10:20 AM
CrazyCanuck66
2008 WK
Ok I guess it's about time I asked all the questions that I have after reading about this awesome product. I bought my jeep GC Limited S in November with 61,000 km on it, I think there's 68,000km now. I have a 5 year extended warrantee on it. So if it will void the warrantee which Ofcourse they say it will I'm going to have to wait another 5 years and I dont think I can wait that long haha. Anyway my 1st question is if I flash any of these tunes will I be able to put it back to my stock settings for servicing or any mechanical problems without leaving any foot prints for the dealership to void my warrantee. 2nd I will most likely skip the Eco tune and go straight to the Hot tune because I am looking for more power then fuel mileage even though it sounds like the Hot tune gets almost the same depending on how u drive it. I was woundering can I run the hot tune without a dpf delete because I think someone was saying u can't run the dpf without gutting ur dpf and putting in a dpf delete pipe or else u will plug it up. I will eventually put one in But the reason I ask this is because if I gut it and put the dpf pipe in the dealership will kno forsure. 3rd I was reading on GDE website that if u are going to use the hot tune u should have a aftermarket torque converter is that nessasary or am I ok with what came stock with the GC. 4th and finally I bought a edge insight cts dash diagnostic scanner does anyone kno if it will work with these tunes. U guys are the ones that kno best so I thought it was time to ask because I am itching to start upgrading thanks.
CrazyCanuck66 is offline
post #727 of 1280 Old 05-11-2013, 10:39 AM
Zlartibartfast
2007 WK
Originally Posted by CrazyCanuck66 View Post
.......1st question is if I flash any of these tunes will I be able to put it back to my stock settings for servicing or any mechanical problems without leaving any foot prints for the dealership to void my warrantee.
Yes, you can flash back to the OEM tune. AFAIK the dealer cannot determine what you had flashed previously, but it may be possible for them to see that a flash has been applied.
2nd .....I was woundering can I run the hot tune without a dpf delete....
Yes you can run with DPF intact and fully functional. I have put 7K miles on my CRD with the GDE Tune and a working DPF
The OEM converter is fine the tune(s) will not exceed it's rated capacity
I don't know the answer to that one, but I am using Torque Pro and it works just fine
post #728 of 1280 Old 05-11-2013, 11:35 AM
CrazyCanuck66
2008 WK
Awesome thanks for the information is there anything I would need to do befor I go ahead and order it
post #729 of 1280 Old 05-11-2013, 11:57 AM
Zlartibartfast
2007 WK
I would read/fix any DTC's you might have before applying the flash; you can use the flash tool to scan for codes before installing the tune. If you are on your factory original battery, be prepared to replace it. Mine died after exactly 5 years of service
post #730 of 1280 Old 05-11-2013, 12:29 PM
CrazyCanuck66
2008 WK
I'm pretty sure when I bought the GC they put a new battery in and I have no code errors I check it with my edge cts when I got it last week. Thanks.
Hey do u kno if the swirl motor error is turned off when u load the tune. Mine is still ok but does that mean the swirl motor is turned off or just the sensor so it doesn't go into limp mode if ur swirl motor goes If its just the sensor how will u kno if it swirl motor does go if the sensor is off?
post #731 of 1280 Old 05-11-2013, 01:54 PM
TurboDiesel
2008 WK
hey another BC guy :P
with the tune u will never had a swirl motor issue and it leaves the valves open i believe
i need to order the hot tune..but i like my mileage..dont know how much of a drop it would be cause i do all city driving
also i got a dpf delete and reso delete
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline
post #732 of 1280 Old 05-11-2013, 02:16 PM
CrazyCanuck66
2008 WK
Nice yea I would get those deletes too but I can't I guess until my warrantee is up
post #733 of 1280 Old 05-11-2013, 02:40 PM
TurboDiesel
2008 WK
i got some third party warranty that ive never used..
dont know what they could blame the dpf delete for...
also from what i have heard the dealer can see how many times u have flashed the ECU, dont know if they can tell with what tho
post #734 of 1280 Old 05-11-2013, 03:39 PM
CrazyCanuck66
2008 WK
Hmmm really that's no good if they can see that. I don't want to loose my warrantee that's 5 years of free fixes down the drain. Wasnt it u who said u need to get rid of ur dpf if u use the dpf delete or else u will clog it. If I gut it then they will really know. What where ur gains with the dpf delete and when u got rid of the dpf
post #735 of 1280 Old 05-11-2013, 03:58 PM
jjt250
2007 WK
The Hot tune and the Eco tune are your base tunes. The DPF delete tune can be added as extra for like $100. So if you don't want to delete your DPF (through gutting it or straight piping it), then do not get the DPF delete tune when you get your base tune. If you run your Jeep with the DPF delete tune but have not gotten rid of the DPF, you will clog it.
2007 Grand Cherokee Limited | QDII | 3.0L Diesel | S4xC Shackles Mounts | Goodyear Duratracs
Bilstein HD Front/Rear | Rusty's 1/2" Strut Spacer | Hemi XK Front/Rear Coils | HID Projectors
jjt250 is offline
Green Diesel Engineering tune for WK GDE WK Grand Cherokee & XK Commander Forum 87 06-01-2016 12:19 PM
tune up for a 05' Free-Willy WK Grand Cherokee & XK Commander Forum 0 01-07-2010 05:49 AM
95 ZJ Tune-Up ?'s trontheman89 ZJ Grand Cherokee Forum 2 11-07-2008 10:18 AM
4.7 tune-up, non H.O. H3RESQ ZJ Grand Cherokee Forum 15 01-15-2007 06:21 PM
Tune Up on a 99 GC? MFairbourn ZJ Grand Cherokee Forum 2 07-17-2004 12:45 PM
