GDE Tune (Green Diesel Tune) - Page 45 - JeepForum.com
 1Likes
post #661 of 1280 Old 04-10-2013, 02:36 AM
DieselDevotion
2007 WK
Originally Posted by jediknight
Hey let us know how that Fumoto valve is doing ... I've seen this but I had doubt. I like the idea. No more O ring to change
I've had them on various vehicles for years now. They work great, never had any issues. And on the wk you can do an oil change without removing the skid plate! Just make sure you get the one with the nipple.
07 Grand Cherokee Limited 3.0L CRD QDII
89 5.9 Cummins powered F350
98 TDI Jetta
DieselDevotion is offline
post #662 of 1280 Old 04-10-2013, 06:23 AM
BAH101
2008 WK
Yup, awesome addition. I got the one with the nipple and carry a 6" piece of tube I slide over it before I open the valve. No mess at all.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #663 of 1280 Old 04-10-2013, 06:26 AM
Radcrd
2007 WK
Originally Posted by jjt250 View Post
That's a good idea, I'll try that tomorrow. Do you turn it fully off or just partially? I know it turns from fully to partially above 40 mph I think. It is dangerous though, I have a few close calls where I couldn't get out of the way because of the lag. Is the issue reduced with the tune?
I have not tried it yet, just speculation at this time. Try it both ways, partially off then fully off. When I have a chance I'll find an empty parking lot to test it out. The issue is NOT reduced with the tune, still the same if you are talking about the cut-out issue? As for lag is it tremendously reduced (especially with the HOT tune) and you will take off much faster!
2007 WK CRD QDII, GDE HOT tune. 275/55/18'' on Sahara's, SRT8 suspension.
2000 Jetta TDI (hers)
2006 Liberty CRD (sold)
3 VW TDI's (sold)
Radcrd is offline
post #664 of 1280 Old 04-10-2013, 05:37 PM
TurboDiesel
2008 WK
can someone link the proper fumoto valve to use...i might aswell pick one up...oil change in 2 months
will probably go with the Mobil 1 0w30
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline
post #665 of 1280 Old 04-10-2013, 08:09 PM
1999xjnick
F-106
i did a google search for fumoto. and clicked the application button.
http://www.fumotousa.com/size_domestic.htm
1999xjnick is offline
post #666 of 1280 Old 04-10-2013, 08:37 PM
SSF556
2008 WK
Do you mean 0w40?
This is what I am using.
http://www.mobiloil.com/USA-English/...l_1_0W-40.aspx
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #667 of 1280 Old 04-10-2013, 08:40 PM
TurboDiesel
2008 WK
Originally Posted by scootr29 View Post
Do you mean 0w40?
yea thats the stuff
hopefully i can find it here lol
post #668 of 1280 Old 04-11-2013, 07:04 AM
r_unda
r_unda's Avatar
Originally Posted by 1999xjnick View Post
F-106
F106N for the one with the nipple, thats the one I have.
If I could do it again I will probably go with the F316L (M14x1.5) since it has a 90deg nipple. Which I think is better for our application but didn’t realize they offered until now.
My Jeep isn't getting older, it's getting newer part by part
2011 WK2 HEMI 4x4 Overland
2007 WK CRD 4x4 Limited GDE Tuned
1998 TJ SE
1973 CJ5 - YJ OME 2.5" lift, 33" tires
1951 Willys truck
r_unda is offline
post #669 of 1280 Old 04-11-2013, 11:42 AM
Xmind
2007 WK
I just bought a 2007 Grand Cherokee CRD last weekend that is completely stock. I have a list of things (fluids/filters/exhaust/EHM...etc) to take care of before I get to the tune. While I'd like to get the GDE tune, one thing that has me worried is the torque output on even the Eco tune. The site lists a torque output of ~440 ft*lb. It is my understanding that these transmissions are only rated for ~420 ft*lb? Is my information incorrect? It was hard finding any information on these transmissions because of the rename Jeep did to the MB trans. What is the most miles people have on their Jeep with an ECO tune? Any trans problems?
Xmind is offline
post #670 of 1280 Old 04-11-2013, 12:02 PM
jjt250
2007 WK
I would do some reading up on the SRT8 as they use the same trans. Do some exploring on SRT8 forums and see when they start having trans problems. A lot of people are running tunes and I have yet to hear of a transmission related problem caused by a tune. Torque limiting in 1st and 2nd are still there I believe unless you specifically ask for the limiter to be removed.
2007 Grand Cherokee Limited | QDII | 3.0L Diesel | S4xC Shackles Mounts | Goodyear Duratracs
Bilstein HD Front/Rear | Rusty's 1/2" Strut Spacer | Hemi XK Front/Rear Coils | HID Projectors
jjt250 is offline
post #671 of 1280 Old 04-11-2013, 01:30 PM
Xmind
2007 WK
Ah, great to know as I thought this trans was unique to the diesel, but if the SRT8 has the same trans and the tune still keeps the torque limit for 1st and 2nd then that alleviates my apprehension!
Xmind is offline
post #672 of 1280 Old 04-11-2013, 05:43 PM
r_unda
r_unda's Avatar
Just an update. A few posts back I was having issues with the scan tool. I was not able to download my stock tune to send it to GDE. Anyways GDE replaced the scan tool and I was able to email them my stock tune. I cant wait to receive the Hot tune!
1998 TJ SE
1951 Willys truck
r_unda is offline
post #673 of 1280 Old 04-11-2013, 07:22 PM
TurboDiesel
2008 WK
good to hear!
Keith should have it back in no time!
post #674 of 1280 Old 04-12-2013, 08:00 AM
Zlartibartfast
2007 WK
@Xmind - I read (on a different forum) about a CRD owner in Europe claiming to achieve 610 Nm (450ft/lbs) torque on a dyno. I have registered 400ft/lbs using TorquePro for Android (not the same as a dyno but it's only $5). I'm confident the W5J400 can handle the Hot tune's torque increase, provided it's maintaned properly.
Zlartibartfast is offline
post #675 of 1280 Old 04-12-2013, 11:18 AM
r_unda
r_unda's Avatar
Hot tune installed! The WK drives a lot better with this tune! Once I get some free time I will install the dpf delete pipe and switch to the tune with no DPF.
1998 TJ SE
1951 Willys truck
r_unda is offline
Green Diesel Engineering tune for WK GDE WK Grand Cherokee & XK Commander Forum 87 06-01-2016 12:19 PM
tune up for a 05' Free-Willy WK Grand Cherokee & XK Commander Forum 0 01-07-2010 05:49 AM
95 ZJ Tune-Up ?'s trontheman89 ZJ Grand Cherokee Forum 2 11-07-2008 10:18 AM
4.7 tune-up, non H.O. H3RESQ ZJ Grand Cherokee Forum 15 01-15-2007 06:21 PM
Tune Up on a 99 GC? MFairbourn ZJ Grand Cherokee Forum 2 07-17-2004 12:45 PM
