GDE Tune (Green Diesel Tune) - Page 41 - JeepForum.com
 1Likes
post #601 of 1281 Old 02-07-2013, 08:30 PM
quicksilverado
2007 WK
A friend has an app for his smart phone that connects thru the OBD II port with one of these.
http://www.amazon.com/Small-Elm327-O.../dp/B005M1AVFQ
07 Grand Cherokee Limited CRD 4X4 GDE tune
00 Silverado 10 sec work truck
quicksilverado is offline
post #602 of 1281 Old 02-08-2013, 07:14 AM
Zlartibartfast
2007 WK
I use an OBD-to-bluetooth scanner and run Torque on my phone. Max boost I have recorded is 22 PSI. The Jeep doesn't have a true EGT sensor, so I monitor my Cat temps as a substitute for an EGT gauge. (I'm not eager to drill a hole in my exhaust manifold)
Zlartibartfast is offline
post #603 of 1281 Old 03-18-2013, 06:55 PM
Dark_Star
Couple of questions about this tune: first, Does the GDE tune eliminate the need for the elephant hose mod? And second, doesn't the tune put out more torque then the torque converter can handle? Thx
Dark_Star is offline
post #604 of 1281 Old 03-18-2013, 06:57 PM
TurboDiesel
2008 WK
ive never had an EHM
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline
post #605 of 1281 Old 03-18-2013, 07:40 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
YES and NO. Yes, in that your swirl motor is no longer an issue and so it does not matter if oil gets dripped onto it. Also, you can simply fix the leak with the black gasket that is mentioned elsewhere in the forum.
NO.... in that oil is still being sucked into your turbo intake. If you don't like that, then do the EHM or get a Cache Can, or a Filter.
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #606 of 1281 Old 03-18-2013, 07:55 PM
Dark_Star
Thx for the response! I don't want the oil in the turbo so looks like I will be doing the ehm! Thx
post #607 of 1281 Old 03-19-2013, 07:44 AM
Radcrd
2007 WK
Beware as you live in a winter climate. If the EHM freezes up (and they do) you may blow your turbo or engine seals. See other posts on the subject, it happened to another member earlier this winter. Personally I dont use one and never have in my 12 years of owning Diesels. Seen too many VW TDI's blow their turbo seals.. Oil in your intake is not a terrible thing. If you are going to do the EHM I suggest you remove it in winter.
2007 WK CRD QDII, GDE HOT tune. 275/55/18'' on Sahara's, SRT8 suspension.
2000 Jetta TDI (hers)
2006 Liberty CRD (sold)
3 VW TDI's (sold)
Radcrd is offline
post #608 of 1281 Old 03-19-2013, 09:04 AM
Dark_Star
Awesome thxs for your post!!! I will have to do a little more research before I do this mod!
post #609 of 1281 Old 03-19-2013, 10:12 AM
SSF556
2008 WK
I do not use one......
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #610 of 1281 Old 03-19-2013, 05:29 PM
LJS8510
LJS8510's Avatar
2015 WK
I don't either
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #611 of 1281 Old 03-20-2013, 08:59 AM
wanabxtrm
Now that some of you have the DPF pipe deleted I'm interested in avg MPG change without the tune, with the tune, and with the pipe installed.
Just starting to weigh the addition of the tune here once I get some more $
wanabxtrm is offline
post #612 of 1281 Old 03-20-2013, 09:10 AM
DieselDevotion
2007 WK
You can't delete the dpf without a tuner. You will throw codes and cause the truck to go into limp mode.
07 Grand Cherokee Limited 3.0L CRD QDII
89 5.9 Cummins powered F350
98 TDI Jetta
DieselDevotion is offline
post #613 of 1281 Old 03-20-2013, 10:36 AM
wanabxtrm
-DD thanks I'm aware , that's why I thought this thread was a good spot to ask as the GDE seams to be the most widely used tune. I know they claim 2+ mpg boost, I figured removing the DPF had to relieve some back pressure and increase it some more. But not sure it's worth the cost over the near term, as its going to be my wife's daily vehicle (she could careless about power changes). I'm sure long term it would be.
post #614 of 1281 Old 03-20-2013, 11:48 AM
jiggadog
2008 WK
from what i've read on the site the mpg gains are more from the tuning and not necessarily from the added tune to remove the dpf. i recognize the better performance and fuel mileage as a reason to tune, but i calculated it would take around 77,000km (assumed cost of fuel was constant) to get back my investment in fuel savings from buying just the tune, no dpf pipe. people rarely keep their vehicles long enough to ever realize a substantial benefit of doing these mods, but i understand why people would make these changes if you intend to put 500,000km on your vehicle, want additional power for towing, etc.
as i understand it, the advantage from removing the dpf is an engine that will last longer. I've done the resistor mod to address the swirl motor, which was my biggest concern. i did the EHM prior to putting the resistor on, so i may actually put that back to stock as well. i bought the dpf delete pipe, but i'm not sure i'm going to bother at this point.
2008 WK CRD Limited 4x4. Every available option package
jiggadog is offline
post #615 of 1281 Old 03-20-2013, 02:09 PM
jaje
2007 WK
Don't forget there are two stages of the DPF: 1 - normal stage when it's not regenerating a deletion should get you 1-2 mpg at the most. 2 - regeneration stage is where excess fuel is sprayed in during the exhaust stroke in order to burn off the ash which reduces mpg at that time by 3-4 mpg. I'm not exactly sure how long the regen cycle is though.
'14 WK2 EcoDiesel Limited
'13 Subaru BRZ
#74 Exocet - NASA ST3 / E0
jaje is offline
Green Diesel Engineering tune for WK GDE WK Grand Cherokee & XK Commander Forum 87 06-01-2016 12:19 PM
tune up for a 05' Free-Willy WK Grand Cherokee & XK Commander Forum 0 01-07-2010 05:49 AM
95 ZJ Tune-Up ?'s trontheman89 ZJ Grand Cherokee Forum 2 11-07-2008 10:18 AM
4.7 tune-up, non H.O. H3RESQ ZJ Grand Cherokee Forum 15 01-15-2007 06:21 PM
Tune Up on a 99 GC? MFairbourn ZJ Grand Cherokee Forum 2 07-17-2004 12:45 PM
