GDE Tune (Green Diesel Tune) - Page 2 - JeepForum.com
 1Likes
post #16 of 1281 Old 05-11-2012, 06:53 AM
SSF556
2008 WK
Originally Posted by jiggadog View Post
Would you mind explaining why you have it set-up like this? I don't understand what the purpose is. thanks.
Every 750 miles a CRD will do a high temp regeneration. The only way you can tell if the regen is happening is by monitoring the exhaust temps. When my CAT1 exhaust temps climb above 900F, 1000F to 1200F I know immediately that the engine is doing a regen.
Like I said it happens every 750 miles and last for about 10 minutes. It is the process by which soot is turned into ash.
I also know to continue driving to maximize the temps. If you were in stop and go traffic there is the potential to get a less than ideal regen. When you are on the highway you are putting out higher temps which aid in the regen process.
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #17 of 1281 Old 05-11-2012, 10:55 AM
jiggadog
2008 WK
ok..got you..you've set-up the dashawk to have a visual indicator when the jeep is in regen mode..i was stuck on the "flash" part.
thanks for the explanation.
2008 WK CRD Limited 4x4. Every available option package
jiggadog is offline
post #18 of 1281 Old 05-11-2012, 08:36 PM
Dr. Internet
I can also tell when it's doing a regen by the odor. Fairly noticable Diesel smell with the windows down.
Steve
2012 Black GC Overland Summit 4x4 2006 Red LJ Rubi
USN Club Hull TJ-13 TX Jeep Club #29
Dr. Internet is offline
post #19 of 1281 Old 05-11-2012, 10:45 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
GDE Tune flash scan device arrives.
Getting back to the GDE Tune, I ordered it on Wednesday morning and it shipped out the same day. It arrived today!! Wow, that was fast.
Unfortunately, I won't be able to use the tool until Sunday afternoon. I'll post some photos of the device along with my nervous comments and blood pressure.
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #20 of 1281 Old 05-12-2012, 09:18 AM
fishinbama
2007 WK
Don't forget that you will have to download your current tune, come back to the computer and mail it to them. Then it will get modified and sent back to you to be uploaded in your Jeep. When I got mine I thought it would just plug and go.
fishinbama is offline
post #21 of 1281 Old 05-12-2012, 10:31 AM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
Yes. Thanks for the reminder.
Chirpz
Chirpz is offline
post #22 of 1281 Old 05-12-2012, 10:51 AM
BAH101
2008 WK
Here is where you find instructions (if you haven't found this site yet): http://www.greendieselengineering.co...list/112.pkage
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #23 of 1281 Old 05-12-2012, 12:33 PM
terrasmak
2007 WK
Talking about tunes and EGT gauges, how hard is the EGT sensor to install. Where do people mount the gauge and what do you think of this. http://www.google.com/products/catal...d=0CLQBEPICMAo instead of water temp I would go to the trans pan for trans temp
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
terrasmak is offline
post #24 of 1281 Old 05-12-2012, 07:59 PM
jediknight
2008 WK
Brillant !! I like the idea of monitoring EGT from each manifold. Especially with a tune I think its vital to know EGT before the turbine ... if EGT during regen is 1200 F at the CAT 1 sensor...imagine what the temperature is like just before the turbine !
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline
post #25 of 1281 Old 05-12-2012, 10:18 PM
terrasmak
2007 WK
Is the EGT sensor supposed to be before or after the turbo?
BTW the search function sucks on this forum? Nothing came up under EGT, he'll this thread should have come up.
post #26 of 1281 Old 05-12-2012, 11:20 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
GDE Tune Arrives
I guess I was too eager to wait. I managed to sneak away from our anniversary party and download my data from the WK and email it off to the GDE people.
To my surprise, by the end of the day, I received an email reply with my new tuneup data file ready to install. I'll do that tomorrow afternoon and then do some testing. Waiting is difficult.
Fast service.
Chirpz
Chirpz is offline
post #27 of 1281 Old 05-13-2012, 11:25 AM
jediknight
2008 WK
Where ever you want, it depend what temp you'd like to monitor. There's already sensors after the turbo... Ecu captures the cat temp so you can monitor those via obd gauges (dashawk or bullydog). Curently there's none before the turbo
post #28 of 1281 Old 05-13-2012, 10:17 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
GDE Tune .... OK, Wow!
OK WOW!
I went out today at 3 PM and installed my new Green Diesel Tune for my WK.
I'll post some actual data later along with some "For Dummies" photos of how the install is done. It was easy. Here is my first impressions of the performance.
I got in and started up. Nothing unusual. I listened carefully and did not notice any additional noise. If it is louder, I can't tell, but then I do wear hearing aids in both ears. My wife did not notice anything either and she is a "sound hound." I have not told her about the tune up yet. That is my way of testing the "feel" of it.
I put it in reverse to back out of the drive way and first off I noticed that the Jeep started moving as soon as I touched the accelerator pedal. There is usually some mushiness in the pedal and you can tweak it a little when you back up. NO MORE. Same with forward motion. There is no play at all in the pedal, if you push it even a tiny bit, it goes.
I also noticed that the going smoother and steadier. I sometime get a tiny bit of turbo lag, but not near like it used to be. The turbo lag (if that's is what it is) is also different. Used to be it would not accelerate strongly until the lag was over, now is gets off to a smooth strong and immediate start and then there is this tiny little lag. It seems to happen on medium and fast take offs, and is imperceptible on the slow typical type take offs. My wife often complains about the Jeep being laggy. I doubt that I will hear that complaint again.
Power.... I took it out and stomped it couple of times. Very subjective test. It does seem to have more pep. I have no way to rate this. It has always been peppy. Now it is a smoother peppy. I did notice that it is more difficult to get it to go slow in those 20mph zones on Main street. Have to watch it.
Mileage.... most important to me.
I'm starting with a FULL tank and have previous records. I'm clocking mileage using my Garmin Nuvi in harmony with a Garmin Mechanic Ecoroute HD that monitors the actual engine performance through the computer port. For the next fill up I'll compare their "At the pump" feature with past records. Each routed trip is tracked and log individually.
This morning I drove to Church and back.
Recorded 16.xx on the way there and 19.xx on the way back. On the way there, the trip was ruined by a long period of idling when we made a stop....should have shut it off. It is only an 8 mile trip so a little idling makes a dent.
This evening, we made the same trip and recorded 23.xx both directions. So it appears that I will have 3 to 4 mgp increase in mileage. This is very good news to me and shows that the "tune" will be a lasting value.
By the end of the week, I'll have some comparison data to post.
So, my first impression is that the "tune" is easy to install and it does what it claims to do."
Chirpz
Chirpz is offline
post #29 of 1281 Old 05-14-2012, 06:31 AM
SSF556
2008 WK
Keep us posted...I am traveling this week to MI in my ML350 so it will be another week or 2 before I can get the actual fuel economy for the first tank of fuel with the tune.
Fuel economy alone the tune will pay for itself, and the peace of mind with the swirl motor is priceless.
2008 CRD QT2
SSF556 is offline
post #30 of 1281 Old 05-14-2012, 11:42 AM
Robert J. yates
So let me make sure I understand correctly... the GDE tune will eliminate the swirl motor from the equation with no adverse affects? I have 84k on my 08 right now and the replacement black seal charge tube I installed at 25k is now leaking pretty good so its not the be all end all fix either. I need to run this truck for another 2 years so avoiding the swirl motor problem is huge for me. If this tune gets rid of it... that right there is worth the price of admission.
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
Green Diesel Engineering tune for WK GDE WK Grand Cherokee & XK Commander Forum 87 06-01-2016 12:19 PM
tune up for a 05' Free-Willy WK Grand Cherokee & XK Commander Forum 0 01-07-2010 05:49 AM
95 ZJ Tune-Up ?'s trontheman89 ZJ Grand Cherokee Forum 2 11-07-2008 10:18 AM
4.7 tune-up, non H.O. H3RESQ ZJ Grand Cherokee Forum 15 01-15-2007 06:21 PM
Tune Up on a 99 GC? MFairbourn ZJ Grand Cherokee Forum 2 07-17-2004 12:45 PM
