GDE Tune (Green Diesel Tune) - Page 10 - JeepForum.com
 1Likes
post #136 of 1279 Old 08-03-2012, 07:34 AM
GDE
2005 KJ Liberty
Modifications to keep the vanes fully open all the time will lead to an underboost code, very weak performance and higher levels of soot generation. VGTs are not designed to be operated with full open vanes as the cross sectional flow area is just too large to build adequate drive pressure in the turbine. This holds true for low rpm and light,medium load operation. At full load, high rpm the vanes are typically more open as the flow rate is high enough to build boost.
GDE is offline
post #137 of 1279 Old 08-03-2012, 11:51 AM
Jscheier
2007 WK
I just ordered a GDE tune (5 minutes ago).
If you look back through the archives, I had an InMotionUSA tune on my CRD since July of 2009.
Last week I got a check engine light and it was the same one I had before (Exhaust Gas Pressure P0471). Dealer checked it out, replaced the sensor and then got additional code (P0069 - MAP Sensor). Turns out the PCM was bad.
After two attempts, we got a PCM that would take all of the coding and the Jeep is up and running again. Unfortunately, without the InMotion tune.
InMotion has gone AWOL, so, after reading this thread, I decided to give GDE a try and get the Jeep back to a Boss 302 towing machine
Thanks for all of your detailed posts... definitely makes the decision easier!
John
2007 Jeep GC QD2 CRD (GDE equipped Toy Hauler)
2012 Boss 302 (Track Toy)
Jscheier is offline
post #138 of 1279 Old 08-07-2012, 11:28 AM
Jscheier
2007 WK
Got the programer late yesterday afternoon. Set it up and pulled my OEM file. Sent it in to GDE well after 5 p.m (MST). At 7 pm (MST) I got a reply with my modified file. Man.. talk about customer service. That's 8 p.m. in Michigan!
Anyway, installed it last night and all of the comments above are correct. Slightly louder when leaving a stop. Power is up. I filled the tank this morning and will keep tab on the mileage (although the display shows WAY higher than before on my InMotion tune).
Thanks GDE!
Jscheier is offline
post #139 of 1279 Old 08-07-2012, 12:45 PM
SSF556
2008 WK
Thanks GDE!
You are going to like it......we need some Boss eye candy in this thread..post up a pic...
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #140 of 1279 Old 08-07-2012, 02:36 PM
Jscheier
2007 WK
Photos from last year when I first got it. One is PPIR (Pikes Peak International Raceway) and I think the other is PMS (Pueblo Motorsports Park).
Jscheier is offline
post #141 of 1279 Old 08-08-2012, 12:40 PM
Harry7
2006 WK
I had the ETC warning light come on again on the way home tonight, and it went into limp home mode so I went straight to a mechanic that was recommended by a friend. He read the fault codes in front of me and came up with 2398, 1974 and 1033, all relating to Boost Pressure Sensor/Control. The dealer had told me the fault code was P0046, so this looks like something different, or the dealer wasn't being entirely honest because he wanted to sell me a whole new turbo atú3600?!
Harry7 is offline
post #142 of 1279 Old 08-09-2012, 11:42 PM
attystomper
2011 WK
New to the forum with a used 2007 Grand Cherokee CRD. Just bought it a week ago and have been researching several tunes. I have a question regarding the GDE tune "second hand".
Someone is selling a GDE tune locally that I know of. The seller says included are the tune as well as the flash/scan tool which doubles as an OBDII code scanner/clearing device.
How is this tune going to work if it is VIN locked? I thought with GDE, you got the flash tool, emailed them your OEM tune and they emailed you back the ECO tune? How does this work if it's a second hand tune?
I need to know if it will work without costing me more money for a tune from GDE. Like, I thought the tune you get emailed back from GDE is specific only to you vehicle and can only be used for that specific vehicle. How is this going to work second hand? I know with my last Dodge turbo car,Caliber SRT-4, I bought an ECM used and had it custom flashed and then had to get someone with a Starscan to program the VIN.
attystomper is offline
post #143 of 1279 Old 08-10-2012, 04:47 AM
GDE
2005 KJ Liberty
A second hand flash tool will not be useable on your WK due to the VIN locking, unless the flash tool has been erased/cleared. If you want a GDE tune, why not just order directly from us?
GDE is offline
post #144 of 1279 Old 08-10-2012, 04:58 AM
Valpacer
2007 WK
2007 WH Grand Cherokee CRD (Yup, RHD Australia)- 3" Exhaust, GDE Flash Tune, CRDSTU/SL Hybrid Lift & bash Plates, 4xGuard Rock Rails, Saguaro F & R Bars, RCV's, Warn 9.5cti-s, AEV Saverge Rims, Nitto Mud Grapplers, Snorkel, Custom Rear Drawers, On Board Air, BullyDog Monitor, Dual Batteries -
Valpacer is offline
post #145 of 1279 Old 08-10-2012, 10:31 AM
attystomper
2011 WK
I'll definitely be buying a gde tune straight from gde shortly, I just had a funny feeling the guy was trying to scam someone with a useless "used" flash. Thanks for the help.
post #146 of 1279 Old 08-10-2012, 11:34 AM
torqrise
2007 WK
Any GDE users monitoring EGTs? I'm wondering about the effect of reducing the amount of EGR that this tune offers on exhaust temps. In theory they should increase.
Also - does the GDE tune advance timing?
torqrise is offline
post #147 of 1279 Old 08-10-2012, 12:54 PM
SSF556
2008 WK
I have seen a significant decrease in exhaust temps.....
2008 CRD QT2
SSF556 is offline
post #148 of 1279 Old 08-10-2012, 10:09 PM
GDE
2005 KJ Liberty
The GDE ECO tune typically lowers cruising exhaust temps 50-150 F, depending on speed/load. By optimizing the combustion less fuel is needed to hold speed and correspondingly slightly lower EGTs.
On a side note: We are almost finshed validating a DPF delete tune. Early data is showing a decent increase in fuel economy around 2 mpg. There is virtually no smoke exiting the tailpipe even without a DPF installed. The Merc engine is very clean. Coupled with the ECO tune the fuel economy gain can be up to 3-6 mpg.
The DPF itself was just gutted, then refit in place and all sensors remain in factory configuration. The face of the DPF was 60-80% clogged from ash. PO did not use the "low ash" oil apparently. Based on feedback, the exhaust tone is not noticeabley different w/o DPF brick.
GDE is offline
post #149 of 1279 Old 08-10-2012, 11:05 PM
SSF556
2008 WK
Will current customers get this DPF delete tune for free?
2008 CRD QT2
SSF556 is offline
post #150 of 1279 Old 08-11-2012, 09:20 AM
gemiller
2008 WK
I'm itching for a dpf delete, I would probably take the plunge on the tune if it is dpf delete especially if someone is making an oem replacement dpf filter removable pipe(no issues with my filter right now so wouldn't want to trash it.) I'd love to tune, dpf delete and MBRP exhaust at one shot.
2008 WK Red Rock Crystal Pearl CRD || Lifted and stuff.
gemiller is offline
Green Diesel Engineering tune for WK GDE WK Grand Cherokee & XK Commander Forum 87 06-01-2016 01:19 PM
tune up for a 05' Free-Willy WK Grand Cherokee & XK Commander Forum 0 01-07-2010 06:49 AM
95 ZJ Tune-Up ?'s trontheman89 ZJ Grand Cherokee Forum 2 11-07-2008 11:18 AM
4.7 tune-up, non H.O. H3RESQ ZJ Grand Cherokee Forum 15 01-15-2007 07:21 PM
Tune Up on a 99 GC? MFairbourn ZJ Grand Cherokee Forum 2 07-17-2004 01:45 PM
