GC Roof Rack - JeepForum.com
post #1 of 10 Old 05-20-2007, 07:54 PM Thread Starter
51flattie
1951 M-38
GC Roof Rack
Hello all, I recently purchased a "Defender" one piece roof rack to mount on our 2006 Overland GC. Looks like the cross bars need to be removed. I am about to cut them out but was hoping to avoid damaging OEM stuff for later re-sell. I've removed the tighten/adjustment bolt, tried prying the attachment to the side rail up, out, and to each side to no avail. There is an interesting looking recessed pin on the outer side of connection piece, does this need to be removed or punched out?
Any tips on removal is appreciated!
51flattie is offline
post #2 of 10 Old 05-20-2007, 08:05 PM
fxanimator1
I'd like to see pics of your roof rack.
fxanimator1 is offline
post #3 of 10 Old 05-20-2007, 08:11 PM Thread Starter
51flattie
1951 M-38
I will as soon as I can remove stock cross bars and install the new-assuming that you want to see the new Defender installed!
post #4 of 10 Old 05-20-2007, 09:31 PM
T-Rated
T-Rated's Avatar
That pin is what holds it in. Dunno how to remove it, though. Vice Grips?
I know that Swampy101 (I think he's on JeepsUnlimiited) has a Defender roof rack. Here's a post by him:
http://www.jeepsunlimited.com/forums...46&postcount=7http://www.jeepsunlimited.com/forums...46&postcount=7
And a link to pictures of his rig:
http://www.bryanmaine.com/web/Jeep/
Jeep: 2006 Midnight Blue Grand Cherokee Limited 4.7L Bells Whistles
Mods: Tow Hooks Mopar & 4xGuard Skid Plates & Rock Rails Flowmaster 70 255/65R17 REVO's
T-Rated is offline
post #5 of 10 Old 05-20-2007, 10:26 PM
coloradowk
No need to cut!! Just grab some needle nose pliers and pull that silver pin out. You'll be good to go.
AKA DurangoZJ
2011 WK2 | 2007 Superlifted WK on 33s
coloradowk is offline
post #6 of 10 Old 05-20-2007, 11:37 PM Thread Starter
51flattie
1951 M-38
Uh oh===tried to punch one through. its stuck now in about 1/8" . other 3 are recessed flush-no needle nose on those. I'll have to try to drill them out unless someone comes up w any great idea!! keep them coming--goin camping /4wheelin out of death valley nex weekend and really need that rack space
post #7 of 10 Old 05-21-2007, 08:41 AM
T-Rated
T-Rated's Avatar
Death Valley? Really? I thought it was getting too hot to set foot in that place.
I'm too lazy to walk the 20 feet to my WK, but would it work to find a long skinny pin/nail and pound them out from the other side?
T-Rated is offline
post #8 of 10 Old 05-21-2007, 02:23 PM Thread Starter
51flattie
1951 M-38
Too Hot?? Were staying in higher els coming in from owens valley - dropping in later afternoon.
Took a look at rack- no pin access from other side. After the beers have setlled in and I thought I should not do any cutting now - while in the shower this morning because that where i get all of my brilliant idea,s I thought does the new rack fit over the orignial?? to my surprise it looks like it does by shifting the cross bar to the desired location it will fit without removal of cross bar. Only drawback is the stock clamp/ tightening hand screw sticks up into the new rack storage area.
I'll install this evening to see if it really works..stay tuned
post #9 of 10 Old 05-21-2007, 06:49 PM
T-Rated
T-Rated's Avatar
If there's no pin access from the other side, why were you trying to punch it through? Hopefully you'll find a way to remove them.
Make sure you take pictures of the rack. I've yet to see some up close shots of them on a WK.
T-Rated is offline
post #10 of 10 Old 05-21-2007, 11:20 PM Thread Starter
51flattie
1951 M-38
OK,T-Rated is correct, Pin must be removed from at least one side. Need to drill out opposite side of assembly so that you can punch pin back out. Easy to drill through plastic assembly. Punch pin out, lift assembly off same side, lift the cross bar while at other side will release the other side-easy.
Only comment on Defender rack for the WK is that it is off center by about 1/2 inch due to mounting holes in rack. can't notice from sides, but is more recognizable from back where the "Defender" lable is not centered on vehicle.
Pics to come later--too dark now!
Need some help with my roof rack suzieque WK Grand Cherokee & XK Commander Forum 8 03-25-2009 02:35 PM
ZJ Roof Rack Steve98 ZJ Grand Cherokee Forum 19 12-08-2007 10:34 AM
roof rack footinmouth47 ZJ Grand Cherokee Forum 9 09-05-2006 01:41 PM
Durable Roof-rack vs. Trailer-hitch Rack? DenverCruiser ZJ Grand Cherokee Forum 12 01-10-2006 04:58 PM
