GC replaced water pump - now over heating... please help! I'm clueless - JeepForum.com
post #1 of 7 Old 10-22-2011, 04:16 PM Thread Starter
karillian
2005 WK
So yesterday...
It sounded like my belt went... then I pulled over and steam started spewing out. Radiator fluid leaking (pouring) everywhere.
I had a mech look at it, they said it was the water pump... it looked like it to me, but I know nothing about engines. SO, he replaced the pump today. He let it run to get it to burp, for a LONG time. It seemed like it didn't want to, so he drained everything again, added the coolant and water, let it run. Said it was good. I drove it 2 blocks and my temp gauge went to H, it said over heating on my readings, I tried to turn on the heater to pull heat away and my heater wouldn't get hot. So it sounds like there's air blocking or something. So... is it that little screw in the line that needs to be loosened to air out?? Nothing else seemed to work. Please help me!! Thank you!!
karillian is offline
post #2 of 7 Old 10-22-2011, 06:05 PM
06WKLaredo
2006 WK
Hope it's not a blown head gasket...
06WKLaredo is offline
post #3 of 7 Old 10-22-2011, 06:14 PM
brenden15s
2005 WK
Yes its that little screw take it out and use a funnel to pour coolant in there it will vent air and pull in coolant needed
R.I.P. CW3 Windorski, CW2 Tillery, CW2 Kelley, and CW2 Todd. KIA 25 January 2009 CW3 White and CW2 Gaudet. KIA 5 June 2011. See you on the green... AIR CAV!
brenden15s is offline
post #4 of 7 Old 10-23-2011, 12:35 AM Thread Starter
karillian
2005 WK
Thanks... Ill try that tomorrow
post #5 of 7 Old 12-24-2011, 08:44 AM
jmolli
Replaced the water pump at 70,000 miles on my 2005 3.7L WK. It had a diesil like sound at idle, it was the bearings failing on the pump. I could shake the pulley easily with my hands. The job is very easy, only took 1.5 hours. Be sure to remove the vent plug where the upper radiator hose goes into the front engine cover and fill the block SLOWLY through the upper hose until you get fluid out of the plug hole.
If you don't do this, you will overheat due to no water in the block. Not a good thing!
P.S. Find yourself a new mechanic!
jmolli is offline
post #6 of 7 Old 12-24-2011, 09:11 AM
brentwoodkris
2005 WK
Hopefully he put the thermostat in the right way around...
brentwoodkris is offline
post #7 of 7 Old 12-26-2011, 12:20 PM
BlueSteelJP
2005 WK
Also check the radiater isn't plugged at the bottom because of debree from gaskety material etc.
Blue WK Club Member #10
2005 Jeep Grand Cherokee Limited, 5.7 Liter Hemi no Mods So Far.
BlueSteelJP is offline
laredo , overheating , radiator help needed , water pump failure
water pump + power steering pump z rated ZJ Grand Cherokee Forum 3 09-16-2014 05:50 AM
Replaced water pump- still leaking coolant Blaze45 ZJ Grand Cherokee Forum 7 08-26-2011 02:36 PM
zj over heating after instaling high flow watter pump and thermostat and radiator dlvsdh ZJ Grand Cherokee Forum 12 12-21-2010 12:33 PM
cooling system problems , water pump and thermostat replaced . no heat. natesxj ZJ Grand Cherokee Forum 4 10-25-2009 09:49 AM
Replaced water pump but still leaking flyboy14295 ZJ Grand Cherokee Forum 6 10-15-2008 07:03 PM
