GC CRD coolant temperature when towing - JeepForum.com
post #1 of 16 Old 01-27-2014, 11:18 PM Thread Starter
VANCRD
2007 WK
Just wondering if anybody has used a scan tool to get the actual coolant temperature when towing with a GC CRD? I would be particularly interested to see what temperatures it gets to when towing uphill, in summer. Thanks for any answers.
VANCRD is offline
post #2 of 16 Old 01-28-2014, 02:41 AM
MBDiesel
2015 WK
I'll be able to get you some numbers in about 6 months
Based on what I've seen on my scan tool, the center tick on the gauge is about 90C. The first tick above the peg is about 60. I haven't gotten it past the middle tick since I got my reader.
2015 WK2 Billet Silver Diesel 4x4, ORA2, ATG
1990 Mercedes-Benz 300D 2.5 Turbo - 155k
MBDiesel is offline
post #3 of 16 Old 01-28-2014, 06:42 AM
SSF556
2008 WK
I am able to see coolant temps....normal driving minimal load it will be around 190 to 199F....when towing or loaded for camping in the hills in SC heat I will see 215 - 220 F max...these engines are designed to go upwards of 240F plus. 250F and you may want to get concerned.
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #4 of 16 Old 01-28-2014, 12:08 PM Thread Starter
VANCRD
2007 WK
Thanks MB and Scooter. I was towing with my CRD for the first time last summer (2 days after I got it) and the needle got up to between the 1/2 and 3/4 mark on the bigger hills. Was wondering what temperature that was. I have a scan tool now so I will be able to get the exact temperature when heading up there again this July. I assume that the MB drivetrain is set up for this - given that it has a towing capacity of 7200 lbs. - I guess I would like to see more cooling in the thing so it would stay around 190-200 even when towing - much like the way an 18 wheeler can just crawl up a long hill towing a heavy load and do it all day without worrying - due to lots of cooling capacity in the engine and transmission. I was also trying to find a gauge that would read the transmission temp (as has been discussed here several times) but aside from the Dashhawk - which is not made anymore - there does not seem to be one that I can buy that will show this.
VANCRD is offline
post #5 of 16 Old 01-28-2014, 01:24 PM
MBDiesel
2015 WK
If you have (or are willing to get) an Apple device, the guys who made Dashhawk make Dashboss now. It is a proprietary Bluetooth transmitter that sends the data to their app. I have one and it displays trans temperature, shaft and turbine speeds as well as current and target gear.
Here's some screenshots from my iPad showing the app (not in the Jeep so the data isn't there). The scale on the fuel pressure gauge is not big enough (Bosch CDI gets to 26,000PSI); Ken is working on making it bigger for the next app update.
MBDiesel is offline
post #6 of 16 Old 01-28-2014, 03:39 PM
jjt250
2007 WK
Does the transmission temp part actually work on that app??
2007 Grand Cherokee Limited | QDII | 3.0L Diesel | S4xC Shackles Mounts | Goodyear Duratracs
Bilstein HD Front/Rear | Rusty's 1/2" Strut Spacer | Hemi XK Front/Rear Coils | HID Projectors
jjt250 is offline
post #7 of 16 Old 01-28-2014, 04:00 PM
SSF556
2008 WK
You will be hard pressed to keep coolant at those levels when towing.....check out the Sprinter forum as well for more details on towing temps.
2008 CRD QT2
SSF556 is offline
post #8 of 16 Old 01-28-2014, 08:12 PM
MBDiesel
2015 WK
It does, and it is different than the coolant temp (not just a copy of that data). I can verify the validity of the data because it changes to a copy of the coolant temp when in park or neutral. The temp sensor is wired in series with the park/neutral switch on the NAG1. From the service manual:
Theory of Operation
The Electrohydraulic Control Unit Assembly of the NAG1 transmission contains a temperature sensor to monitor the
transmission oil temperature. This sensor is wired in series with the transmission Park/Neutral switch. The Transmission
Control Module (TCM) expects to see a valid voltage level from the sensor when the shifter is in Reverse
or any forward Drive position. The TCM also expects to see an open circuit condition when the shifter is in the Park
or Neutral position. When the controller detects an open circuit when in Reverse or any forward drive position the
DTC will set. Note: Due to a open circuit condition in Park or Neutral, the TCM substitutes the Transmission Temperature
reading with Engine Temperature when in Park or Neutral.
MBDiesel is offline
post #9 of 16 Old 01-29-2014, 02:04 AM Thread Starter
VANCRD
2007 WK
Thanks MB, great information. My kids have I-phones so I will give that app a try pronto - it would be great if I could get transmission temp as well!
Scooter - yes, I'm sure you're right and it's probably not necessary anyway.
VANCRD is offline
post #10 of 16 Old 01-29-2014, 10:45 AM
Drudgery1971
2007 WK
Thanks for this info. I am going to try this on Dashcommand as it has trans temp also (4 versions actually) but I never realized it was tied to the gearing in terms of on/off and only tried it in park..... which it read coolant temp like you said so I figured it was wrong. Will see if it switches over once in drive. Thanks again.
2007 WK Limited 3.0 CRD - Stock (Mine)
2010 XK Sport 5.7 Hemi - Stock (Wife)
Drudgery1971 is offline
post #11 of 16 Old 01-29-2014, 11:20 AM
Radcrd
2007 WK
If your transmission starts to overheat you will get a warning signal and message on the cluster stating Transmission over temperature.
2007 WK CRD QDII, GDE HOT tune. 275/55/18'' on Sahara's, SRT8 suspension.
2000 Jetta TDI (hers)
2006 Liberty CRD (sold)
3 VW TDI's (sold)
Radcrd is offline
post #12 of 16 Old 01-29-2014, 02:02 PM
MBDiesel
2015 WK
Thanks MB, great information. My kids have I-phones so I will give that app a try pronto - it would be great if I could get transmission temp as well! Scooter - yes, I'm sure you're right and it's probably not necessary anyway.
FYI you'll need the Dashboss Bluetooth OBD dongle for the app to work. The license for the app is included with the purchase of the dongle.
MBDiesel is offline
post #13 of 16 Old 06-28-2016, 06:05 PM
meatlord
meatlord's Avatar
I have been towing my 6k lb camper this week in @ 90 f temps and was wondering what everyone else was running for engine temps. I am frequently seeing 215 to 221 on 6% grades here. Is the 240 range still safe for towing? Was getting concerned about what I was seeing with my OBD reader.
05 Rubicon "Big Stupid" / 99 XJ on 31s "Nurple" FOR SALE. / 07 WK Limited CRD GDE Hot Tuned DPF delete. / 00 TJ "One Shot Wonder"/ 03 Nissan SE-R 6 speed V spec. / 00 Suzuki DR650.
meatlord is offline
post #14 of 16 Old 06-28-2016, 09:41 PM
caddydaddy
2007 WK
When I towed my 5k lb enclosed trailer up a hill in the Summer, I was seeing coolant temps in the 220's F.
Trans temp was near 200 or so.
2007 CRD Limited w/QDII
GDE HOT Tune, Turbo Resonator Delete
2" RC lift
194,000+ miles!
caddydaddy is offline
post #15 of 16 Old 06-28-2016, 10:19 PM
meatlord
meatlord's Avatar
That's good to know, I have a PML deep trans pan( + 4 qts capacity) and even with the extreme towing I was doing, I can't get more than 176 degrees on the trans temp. My main concern was how hot is too hot as far as engine temps. I just don't want to fry my motor due to being uninformed on the range that is acceptable.
Thanx for your input, I absolutely love my CRD. I would not buy a truck and it fits the bill for all my needs.
I also run royal purple trans fluid if that makes any difference.....
meatlord is offline
