Gauges going crazy - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Gauges going crazy
ANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete NEW JK WRANGLER GRAB BARS NOW at ROCKRIDGE4WDJeep Wrangler Complete Gear Upgrade Kits with Installs and
Unread 12-02-2009, 02:01 PM   #1
88mudder
Gauges going crazy
This may have been on here before but I haven't found it. 06 Grand 4x4 4.7l the gauges will go crazy from time to time when driving down the road. It will ding, all warning lights come on, message says trans over temp, tach and speedo will zero out, just crazy stuff!! Anybody experienced this??? The check engine light is staying on all the time reading P0456 - Evap Emission Sys Leak. But that shouldn't have anything to do with the gauge problem.
Thanks for any help!
88mudder is offline   Reply With Quote Quick reply to this message
Unread 12-02-2009, 02:07 PM   #2
Texas WJ
Texas WJ's Avatar
2005 WK
Bad ignition switch maybe?
http://www.jeepforum.com/forum/f67/e...em-pod-882517/
http://www.jeepforum.com/forum/f67/l...f-dash-822346/
As for the "Evap Emission Sys Leak", maybe a bad gas cap?
255/75-17 BF Goodrich Mud Terrain TA KMs, 2" lift, JK Wrangler Moab wheels, Spidertrax Spacers, Rola Roof Rack.
Texas WJ is offline   Reply With Quote Quick reply to this message
Unread 12-02-2009, 02:55 PM   #3
88mudder
Thank you!!
Unread 12-07-2009, 01:24 PM   #4
88mudder
I know this is a dumb question but I am assuming the switch you guys are replacing is on the backside of the key hole??? Just wanted to make sure before I started panels off the dash.
Thanks!!
Unread 12-07-2009, 01:31 PM   #5
colinzj
2006 WK
It is.
But have your battery tested and check your terminal connections first.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is online now   Reply With Quote Quick reply to this message
Unread 12-07-2009, 05:01 PM   #6
88mudder
Thanks! I put a new battery on about a month ago. Come to think of it, I didn't have any problems until the old battery died and I put a new one on.
Unread 12-08-2009, 10:38 AM   #7
88mudder
Well I put in the new ignition switch last night and it didn't fix the problem. I put a new battery on about a month ago so the battery is good. It was fine this morning for about 2 miles. Then hit a small bump in the road and warning lights and gauges went crazy again. Anybody has any other ideas??? This is driving me nuts!!! Maybe something loose/bad connections since it seems to mess up more when I hit bumps??? But don't know where to start searching???
Unread 12-09-2009, 07:10 AM   #8
ddaniels72
1999 WK
Chrysler issued a TSB, number 08-15-99 on May 21, 1999 about this problem. I quote from the bulletin:
SUBJECT:
Erratic, Intermittent Cluster Operation/Intermittent Air Bag Warning light.
OVERVIEW:
This bulletin involves installing a repair harness containing a revised instrument cluster connector.
MODELS:
1998 - 1999 (TJ) Wrangler
1998 - 1999 (XJ) Cherokee
SYMPTOM/CONDITION:
Some vehicles may exhibit an intermittent illumination of the air bag warning light or an intermittent tachometer or speedometer drop out. An Airbag Electronic Control Module (AECM) fault code - "No Cluster CCD BUS" message will be present.
DIAGNOSIS:
Using the DRB III(R), read and record all active and stored fault codes in the AECM. This condition is caused by minor oxidation of the BUS circuit terminals at the instrument cluster connector. Electrical terminals will show signs of oxidation, which will appear as darkened lines or marks on the cluster male terminals. These often appear as gray or black marks rather than the appearance of oxidation or corrosion usually associated with higher current carrying circuits. This condition will set a "NO CLUSTER CCD BUS" message. The fault code will usually be stored and not active. THIS TECHNICAL SERVICE BULLETIN WILL NOT ADDRESS FUEL OR OIL PRESSURE GAUGE ISSUES. If this fault code is present, either active or stored perform the Repair Procedure.
PARTS REQUIRED:
1 - 05016261AA Cluster Connector Patch Harness
1 - 04856975 Electric Contact Cleaner
2 - 04778570 Heat Shrink Tubing
POLICY:
Reimbursable within the provisions of the warranty.
This sounds like your problem, but the year models stated aren't right for you? quoted from http://autorepair.about.com/library/a/1a/bl550a.htm
ddaniels72 is offline   Reply With Quote Quick reply to this message
Unread 12-09-2009, 08:15 AM   #9
merlinTec
Do you have a lot of keys on there? are you hitting it with your leg?
UK Chrysler Jeep Master Tec.
merlinTec is offline   Reply With Quote Quick reply to this message
Unread 12-09-2009, 09:01 AM   #10
88mudder
No other keys, just the Jeep key. I even started it with the ignition hanging under the dash and wiggled it around nothing changed it was actually working fine at the time.
Unread 12-09-2009, 09:10 AM   #11
88mudder
Well now I am on to something else. A couple of months ago when the gauges first started acting up was the first time I had ever washed under the hood. Since then it has been inconsisent with the problem. Some days the gauges work fine, some days not. However they usually always work fine on start up and then mess up a mile or so down the road. Last night since nothing else was working I decided to wash under the hood again to see if it made a difference. IT DID!!! At first try after washing it wouldn't start. Turned over a few times, then nothing. Unhooked the battery for a few min and it started. No gauges worked, all warning light on, message center reading transmission over temp. The cooling fans were roaring because it thought the trans was hot.... Apparently something is getting wet.. Weird that it still messed up 2 months after washing it though....would think it would have dried out and been fine if that is the problem.
Unread 12-11-2009, 10:27 AM   #12
88mudder
Can anybody tell me where the Body Conrol Module "A" is? The computer says it lost communication with body contol module "A". This thing is driving me crazy!!
Unread 05-13-2012, 09:48 PM   #13
JeepWKWJ0006
2006 WK
I am interested in this too. My 06 Jeep GC WK Limited has done this 3 times now. It seems to happen at anytime. Twice while I was parked idling at work and then when I left work tonight the gauges all started to flicker off and on for a few seconds and all else was fine. The AC was on full blast and after the flickering stopped it was still on full but it seemed to be less than before.
JeepWKWJ0006 is offline   Reply With Quote Quick reply to this message
Unread 05-14-2012, 09:38 AM   #14
croth
2005 WK
Body control module is located on the junction block under the drivers side of the dash.
Craig
croth is offline   Reply With Quote Quick reply to this message
Unread 11-19-2014, 03:31 PM   #15
2007JeepNJ
2007 XJ Cherokee
Same thing has been happening to me. About a month ago I starting noticing my dashboard would light up real quick and then go back to normal. The gauges would act all crazy also like the gas, MPH, RPM would just shut off like I turned the truck off. It happened a few other times since then but they were again real quick ones. Then last night on the way home from work my dashboard lit up and didn't stop for about a minute or so. I was able to capture it on my phone camera. When the issue stopped, the engine light and TPS sensor was still on but went away today by itself. I am bringing it into the dealership tomorrow since this is something I do not want to start dealing with this on a daily basis.
2007 JEEP GRAND CHEROKEE LAREDO 4X4 SPORT UTILITY 4-DR - 3.7 V6
2007JeepNJ is offline   Reply With Quote Quick reply to this message
