Gas & Brake pedal vibration and pulsing Help - JeepForum.com
post #1 of 5 Old 10-15-2014, 03:09 PM Thread Starter
ChrisWK
2005 WK
I have thrown parts at my jeep and cannot fix this problem. I changed all brake rotors and pads new shocks new upper control arms. I still have this annoying vibration in the gas pedal any speed and the brake pedal vibrates too with just touching it with your foot, but once you brake it has a pulsing feeling not like the abs feeling but similar too it. Could I have a bad abs sensor and not know it or will I have a warning message ? My two front tires are worn on the inside because of bad shocks. The fluid in the diffs is mobile one about 15k on the fluid.
What else to look for or fix this problem.
Thanks
ChrisWK
Limited HEMI Dark Khaki Pearl SRT8 Full Body Kit, Roof Rails,SRT8 Engine Strut Bar, Lund Rear Spoiler, MYGIG INSTALLED with LOCKPICK, Kenwood Sub,AFE Intake, Taylor Spark Plug Wires,G2 Silver Painted Brake Calipers, Billet Tech Catch Can, Addco Sway Bars Front and Rear, Eibach Lowering Springs,Xenon Volt HID Lows 6k,Chrome SRT Reps
ChrisWK is offline
post #2 of 5 Old 10-15-2014, 03:36 PM
carangelover
2007 WK
When was the last time the brake fluid was changed? I had the same problem for the brakes. I changed the fluid to clean new stuff and it resolved the issue. I had never changed it before 103K.
carangelover is offline
post #3 of 5 Old 10-15-2014, 04:20 PM
Tango.
2008 WK
warped rotors? did you turn the new rotors?
Tango. is offline
post #4 of 5 Old 10-16-2014, 08:03 AM Thread Starter
ChrisWK
2005 WK
I turned the front rotors and got new rear rotors, I changed the fluid all nice and clean bleed the line to clear fluid.
ChrisWK is offline
post #5 of 5 Old 01-18-2015, 06:29 PM
TurboDiesel
2008 WK
any update on this?
i bled my brakes and get an almost abs like feel on my brake pedal
very random and just a quick vibration...not consistent
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline
