fuel rail/ system pressure - too low - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > fuel rail/ system pressure - too low
Savvy/Currie Aluminum Control ArmsRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits ZONE 4.25" combo lift for TJ available at Rockridge4w
Unread 07-25-2014, 06:53 PM   #1
mathetes
Junior Member
2007 WK
I am getting the code: p0087. I have found some treads but no solutions that I can find. It is a 2007 jeep grand cherokee CRD. No other symptoms. If someone could point me in the right direction or if there is a tread dealing with this, let me know. Thanks
mathetes is offline   Reply With Quote Quick reply to this message
Unread 07-28-2014, 02:57 PM   #2
mathetes
Junior Member
2007 WK
I got the code again
If someone can direct me, again I would greatly appreciate it. The jeep tripped the code P0087 again and this time the blinking red light came on - electronic throttle Control. It happened when I accelerated to get on the freeway.
Unread 07-28-2014, 05:11 PM   #3
tom19511
2006 WK
http://www.obd-codes.com/p0087
Tom19511
tchristopher1@wowway.com
2006 Grand Cherokee Laredo 3.7
2007 Liberty Sport 3.7
tom19511 is offline   Reply With Quote Quick reply to this message
Unread 07-28-2014, 09:45 PM   #4
mathetes
Junior Member
2007 WK
I appreciate that very much. Starting place
Unread 07-29-2014, 10:26 AM   #5
jediknight
2008 WK
Do you have a tuning box ?
Tuning box can trip these codes.
Check your connection with the fuel rail pressure sensor.
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline   Reply With Quote Quick reply to this message
Unread 07-29-2014, 09:47 PM   #6
mathetes
Junior Member
2007 WK
I have the Eco tune from green diesel engineering. I will check the connection. But I don't know where it is. Is it on the drivers side?
cgkoon
2007 WK 3.0L CRD, Quadradrive II, GDE EcoTune, DPF-Delete,
EHM MOD,
Unread 07-30-2014, 07:47 AM   #7
chrali
2006 XK Commander
Some cheap power chips attach to the engine to follow it into providing more fuel, which I think is where Jedi is coming from. As the eco tune is a software remap there is no connection to check.
Sent from my C6833 using JeepForum
Encourage alternative fuels - Use as much petrol as you can!
chrali is offline   Reply With Quote Quick reply to this message
Unread 07-30-2014, 11:32 AM   #8
mathetes
Junior Member
2007 WK
After I read my post, I realize I don't make it very clear ... sorry - The connection I was speaking about was the fuel rail pressure sensor -
Unread 07-30-2014, 02:45 PM   #9
jediknight
2008 WK
Originally Posted by chrali
Some cheap power chips attach to the engine to follow it into providing more fuel, which I think is where Jedi is coming from. As the eco tune is a software remap there is no connection to check. Sent from my C6833 using JeepForum
Correct
@Mathetes,
Fuel rail pressure sensor is located on the passenger side fuel rail at the rear. But since you have a tune already, disregard my post about the tuning box/power chip.
See if there is any fuel leakage near injectors. Another thing is I would try loading the ori and drive for a while and see if this trip the code again. You should try this before lauching yourself into further diagnosis. Your code could be anything from fuel rail pressure sensor, fuel quantity control valve, fuel rail solenoid and maybe a clogged fuel filter.
Unread 07-30-2014, 04:02 PM   #10
mathetes
Junior Member
2007 WK
good advice - will let you know what happens (changed the fuel filter last month)
Unread 08-07-2014, 09:03 PM   #11
mathetes
Junior Member
2007 WK
The jeep has tripped the code P0087 a couple of more times. So I decided first to change the fuel filter. So far no codes even with hard accelerations. Must have been a dirty filter though I had changed it about 7,000 miles ago.
cgkoon
EHM MOD,
Unread 12-13-2014, 11:14 AM   #12
mathetes
Junior Member
2007 WK
found the problem
I wanted to tie this thread up. I kept tripping the code P0087. So I decided to replace the Fuel rail pressure sensor and it fixed it. If any one else trips this code at least you will know what it could be. It wasn't too difficult to replace. If you have any questions, let me know. It cost about $345.00 including shipping.
Glad this is finally over
cgkoon
EHM MOD,
Unread 12-13-2014, 12:31 PM   #13
kwikrnu
That is seriously expensive for a sensor.
2007 WK CRD QDII 2" spacer lift
kwikrnu is offline   Reply With Quote Quick reply to this message
Unread 12-13-2014, 03:15 PM   #14
mathetes
Junior Member
2007 WK
yeah, the stealership wanted $485.00
cgkoon
EHM MOD,
