Fuel Level Sensor replacement - JeepForum.com
post #1 of 5 Old 07-23-2010, 12:57 PM Thread Starter
samger2
Anyone know of a good link to a write up on dropping the tank on an 05 Grand Cherokee Laredo? I've got a bad fuel level sensor and my aftermarket extended warranty won't cover it.
I've done the job on my 1997 TJ...just don't know how different it is on my newer Grand Cherokee...haven't had a chance to crawl underneath the thing yet....
Any help is greatly appreciated.
samger2 is offline
post #2 of 5 Old 07-23-2010, 01:18 PM
theSovereign
2007 WK
theSovereign is offline
post #3 of 5 Old 07-23-2010, 01:21 PM Thread Starter
samger2
Figures...I can't access it from work...have to look at it when I get home. Thanks a ton for the link!!
samger2 is offline
post #4 of 5 Old 07-23-2010, 03:04 PM
Texas WJ
Texas WJ's Avatar
2005 WK
Before you replace the sensor, check out the connections. Make sure there in no corrosion.
I had a issue a couple months back where high water was causing a problem with the gauge, after it dried out everything was fine.
265/70-17 BFGoodrich All-Terrain T/A KO, 2" lift, JK Wrangler Moab wheels, Spidertrax Spacers, Rola Roof Rack.
Texas WJ is offline
post #5 of 5 Old 07-23-2010, 03:12 PM Thread Starter
samger2
Thanks for the tip, I'll make sure to check everything out first
samger2 is offline
oil leaking from oil level sensor jeepunlimited ZJ Grand Cherokee Forum 6 02-09-2011 08:12 AM
oil level sensor Bossanova ZJ Grand Cherokee Forum 1 03-05-2010 08:46 PM
Oil Level Sensor? Killer Cougar ZJ Grand Cherokee Forum 2 04-04-2008 07:22 AM
Oil Level Sensor trailboy ZJ Grand Cherokee Forum 1 01-16-2007 05:11 AM
oil level sensor bonemover ZJ Grand Cherokee Forum 1 08-30-2006 08:17 PM
