Fuel injector leak? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Fuel injector leak?
Rough Country Deals at JeepHut.comSave at JeepHut on Smittybilt Soft topsUp to $75 Cash Back on Your ARB Fridge Freezer Purchase
Unread 08-10-2014, 12:26 PM   #1
Dark_Star
Hi guys. Recently I've noticed a burnt diesel smell in the cab of my 08 gc crd. It only smells at a stop with the fan running inside. So I look under the cover in the engine bay and found this black tar on one of my injectors. It's giving off the same smell as in the cab!image-2231073399.jpg image-2166156663.jpg image-1526211107.jpg Has anybody had this problem? Or point me in the right direction as to a fix? Thx in advance!
Dark_Star is offline   Reply With Quote
Unread 08-10-2014, 01:02 PM   #2
Dark_Star
Just went out and fired it up without cover and the foam noise canceler off; and I found that there is combustion chamber fumes escaping for were the injector enters the block! which would explain the burnt diesel smell I'm experiencing! Is this just a simple blown o ring or do I need to change the whole injector? Thx
Unread 08-10-2014, 01:36 PM   #3
caddydaddy
2007 WK
There's a copper gasket under the injector called an injector seal, and it is fairly easy to replace.
2007 CRD Grand Cherokee Limited 4x4
GDE ECO Tune, Turbo Resonator Delete, EHM
166,000+ miles!
caddydaddy is offline   Reply With Quote
Unread 08-10-2014, 02:39 PM   #4
gemiller
2008 WK
Those copper gaskets are one time use also, so even if you're planning on pulling it to look around you need a new one. My injectors had no secondary seals (just grease), so assuming yours is like mine just replace the copper seal and call it done!
2008 WK Red Rock Crystal Pearl CRD || Lifted and stuff.
gemiller is offline   Reply With Quote
Unread 08-10-2014, 06:42 PM   #5
Dark_Star
Ok thx. Are any special tools needed or is it as easy as undoing the bolt replacing the copper gasket and then bolt it back up again?
Unread 08-10-2014, 07:56 PM   #6
TangoTango
2008 WK
The screw is also a one time use part .. so you will need to replace the o-ring and the screw. Then torque plus a 180 twist.
TangoTango is offline   Reply With Quote
Unread 08-11-2014, 03:35 PM   #7
Dark_Star
Ok thx for the help
Unread 08-12-2014, 11:59 AM   #8
Dark_Star
Will I need a injector puller to remove the injector; there is barely any " Black Death tar" around it. Or can it be done without?
Unread 08-12-2014, 06:30 PM   #9
TangoTango
2008 WK
that tar is the foam injector sheild melted. you can pull them by hand, injector cleaner is your friend.
