Fuel Economy DROP after Fuel Filter Change?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Fuel Economy DROP after Fuel Filter Change??
CCOR is your 1 stop source for everything Jeep!Stainless Steel Door Hinge PinsPoly Door Hinge Bushings
Unread 03-31-2014, 08:34 AM   #1
08CanuckCRD
2008 WK
Hi all. My 08 WK CRD was in the shop last week for a CEL issue. Tech ended up replacing a glow plug and the fuel filter (just hit 150k Kms btw). The GC drives great but the mkleage meter in the dash is reporting a significant drop in fuel economy. Pre filter cange I was averaging 11.2l/100km. Now it's reading 14.1l/100km(!). I thougt a new fuel filter was supposed to improve fuel efficiency....
Any idea what's going on here? I haven't put many km on the vehicle since the filter change. Does the computer need a break-in period??
Thanks in advance.
2008 WK Grand Cherokee Limited 3.0L CRD TurboDiesel, QDII, Stock 245/60R18
08CanuckCRD is offline   Reply With Quote Quick reply to this message
Unread 03-31-2014, 04:24 PM   #2
tnadanzig
tnadanzig's Avatar
2007 WK
You can see a slight drop in fuel economy when changing a fuel filter if it hasn't been changed in a really long time ~ 1l/100km or so. The lack of flow can help you get better economy because your cutting off the engine for fuel and not even realize it. Using just the necessary amount to maintain performance. Its such a gradual process that you would never even know it's happening except once you change the filter its such a shock to the system so to speak. I would say that is quite a drop so there should something else wrong. Do you reset the dash gauge every fill up, has your route changed, driving style? All those can play a factor into your mileage once you changed the filter. No break in when changing the filter.
CB Engineering
CB-engineer.com
2008 3.0L CRD WK LTD - Wifes, GDE DPF Delete Tune, Turbo Resonator Delete, 3" Intercooler, Addcoo Rear Sway Bar, 3.07 gears
2007 3.0L CRD WK LTD - Stage 2 Custom Spooling Tune, Go Fast Parts
Pro-lite Build
2003 F250 6.0L CCLB - Gearhead Tunes
tnadanzig is offline   Reply With Quote Quick reply to this message
Unread 03-31-2014, 07:32 PM   #3
furiousbudy
2008 WK
Remove your plastic cover, and check your fuel lines on top of the filter, might be leaking. I dont thrust any dealer when its time to work on those merc engines
2008 Grand Cherokee CRD Limited 170,000KM, Kendall 5W40 Euro
2007 18CK Pionneer Travel Trailer
furiousbudy is offline   Reply With Quote Quick reply to this message
Unread 04-02-2014, 11:59 AM   #4
08CanuckCRD
2008 WK
Thanks guys. I checked the filter- the top is dry and clean, so no leaks as far as I know. I DID get bent pver the hood on the filter install, which will NOT be happening at the dealer again($118 for a fuel filter PLUS install??), but that's likely another thread!
I did reset the counter after the filter change - the first time I've done that since buying in Sept - so that's likely got something to do with the number jump. It's come down a bit since - reading 13.1 at the mo' after limited city driving. I think it may just need a good highway run to settle down to where I think it ought to be. Fingers crossed - with the current price of diesel in my part of Ontario, I'd really like lower consumption numbers, especially as I set up to tow my first travel trailer this summer.
Unread 04-02-2014, 02:17 PM   #5
pawwright
Don't feel bad about the dealer charge for the fuel filter - last time I was in there they tried to change my fuel filter for $160USD..........luckily I had already priced out the filter thanks to this board.....
pawwright is offline   Reply With Quote Quick reply to this message
Unread 02-04-2015, 09:36 AM   #6
omsok
2007 WK
Hi:
Just a quick reply to say I have not noticed any drop in fuel consumption after changing fuel filter on my 2007 WK. I am actually going to post a full pictorial since I have yet to see one explaining in detail.
Also the issue of finding the exact part number and not spending any extra dollars than necessary. I ended up tracking the correct filter from Mercedes by using the Mopar Part# 05175429AB ($98 at Chrysler Dealership)The corresponding Mercedes part number (Made in Austria) is A 642 092 01 01 $65 Merc. Dealership.
Note: That is the current (Canada) part number on the box. The part number I asked him for was 642 092 07 01. He said that Part # had been discontinued; however when we opened the box A 642 092 01 01 the filter inside was clearly marked A 642 092 07 01. He said Mercedes is renowned for this. Numerous part numbers, constantly changing etc.
omsok is offline   Reply With Quote Quick reply to this message
Unread 02-04-2015, 03:56 PM   #7
TangoTango
2008 WK
puralator has one also.. it's about $50
Black WK Club #147
Life is hard. ...- John Wayne
TangoTango is offline   Reply With Quote Quick reply to this message
Unread 02-04-2015, 05:01 PM   #8
SSF556
SSF556's Avatar
2008 WK
You American guys are spending way too much for fuel filters....Hengst Filters here for $21 + shipping...Canadians...good luck
http://www.diesel-filters.com/h278wk...el-filter.html
They also have a great price on Hengst oil filters as well...
http://www.diesel-filters.com/e71h-d...il-filter.html
Both Hengst and Mahle are the OEM suppliers to Mercedes....it could be one or the other.
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline   Reply With Quote Quick reply to this message
Unread 02-05-2015, 12:25 AM   #9
ggrassmid
Thanks for the links. I will need to pick up a couple and change mine with my next oil change.
What do you use for air filter?
Black 2008 Limited CRD
GDE EcoTune, EHM, 2014 Rubicon take-offs
JF Black WK Club #168
ggrassmid is offline   Reply With Quote Quick reply to this message
Unread 02-05-2015, 07:40 AM   #10
SSF556
SSF556's Avatar
2008 WK
Fram filter from walmart..they are $10 bucks
2008 CRD QT2
crd , fuel economy
