Front Skid Plate - JeepForum.com
post #1 of 24 Old 10-12-2007, 03:58 PM Thread Starter
mrfWKJeep
2006 WK
Front Skid Plate
I was noticing my front skid plate is plastic?? Wondering if anyone has made one out of metal, something I can fab at home, not sure how I would cut/bend the metal though???
mrfWKJeep is offline
post #2 of 24 Old 10-12-2007, 04:45 PM
T-Rated
T-Rated's Avatar
That's not a skid plate. It's a "brush plate." That's the factory default unless you get the skid package. You can buy the metal plate from a dealer, or JustForJeeps.com or JParts.com. And while you're at it, you can get the fuel tank and transfer case skid plates, too. For the T-Case plate, you *have* to the the fuel tank skid, as the T-Case skid mounts to the F-Tank skid.
If that's not enough protection, go for the FrontGuard HC from 4xGuard.com.
Jeep: 2006 Midnight Blue Grand Cherokee Limited 4.7L Bells Whistles
Mods: Tow Hooks Mopar & 4xGuard Skid Plates & Rock Rails Flowmaster 70 255/65R17 REVO's
T-Rated is offline
post #3 of 24 Old 10-12-2007, 05:26 PM
coyote runner
That 4xguard has nice stuff for the price,..I installed the rear HC skid for my WK,..forget about the front HC skid,..no longer in production or will it be according to 4xguard.
coyote runner is offline
post #4 of 24 Old 10-12-2007, 05:27 PM
S10Eater
S10Eater's Avatar
correct me if im wrong but can i assume that my truck is equipped with the skid plates seeing in that its an overland (2007)
1987 350 JEEP COMANCHE
Licence plate: FSTJEEP
2001 TJ SE, 31" KM2s, cragar d styles
JEEP: If i wanted a Hummer, I would have asked your sister
S10Eater is offline
post #5 of 24 Old 10-12-2007, 06:01 PM
coyote runner
the stock skids are fine for moderate off roading,...4xguard make HC (Hard Core) skids designed for more grulling off road abstacles,..the rear skid would be in addition to your stock providing protection to your rear bumper so it wont rip off when hitting tree roots or stiff rocks,..same goes with the front.
post #6 of 24 Old 10-12-2007, 07:19 PM
coloradowk
Probably, but all it takes to make sure is looking underneath your Jeep.
AKA DurangoZJ
2011 WK2 | 2007 Superlifted WK on 33s
coloradowk is offline
post #7 of 24 Old 10-13-2007, 01:01 AM
merlinTec
merlinTec's Avatar
Hi
This is cost cutting by Jeep a 2005 had a metal one as standard.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #8 of 24 Old 10-13-2007, 03:40 PM
CEPCNC
2005 WK
My stock front plastic brush plate got ripped off within the first couple thousand miles I had it. I replaced it with a 4xguard piece....this thing hasn;t moved or bent one bit...and it's only the front guard 1 which is aluminum.
CEPCNC is offline
post #9 of 24 Old 10-13-2007, 05:06 PM
flyrx
flyrx's Avatar
2007 WK
Has anyone that has changed the plastic brush plate for a more substantive metal skid plate noticed an increase in engine/road noise? The plastic piece's design (with hollow plastic cells) looks like it was designed to insulate against noise. I was just wondering....
flyrx is offline
post #10 of 24 Old 10-13-2007, 06:14 PM
jeepgaffer
2006 WK
I switched my 'brush plate' out for the Mopar 'Front Suspension Skid Plate' and I haven't noticed any difference. The real skid plate is pretty heavy, though. I don't think that plastic one has much to do with sound, either....
2006 Bright Silver Grand Cherokee Laredo
3.7L 4WD ("mostly" stock)
jeepgaffer is offline
post #11 of 24 Old 10-15-2007, 06:04 AM Thread Starter
mrfWKJeep
2006 WK
guess I'll have to swap out the parts for the 4xguard parts, seems like the way to go.
post #12 of 24 Old 10-15-2007, 07:17 AM
T-Rated
T-Rated's Avatar
4xGuard is not a replacement for the Mopar skids. You'll *need* to get the factory skid plates, which you can install yourself. The 4xGuard skid plate(s) cover areas not covered by the factory skid plates.
T-Rated is offline
post #13 of 24 Old 10-15-2007, 03:40 PM Thread Starter
mrfWKJeep
2006 WK
that's good information - I didn't know that...
post #14 of 24 Old 10-15-2007, 04:04 PM
CEPCNC
2005 WK
Take 4xguard's belly skid: it covers the cats whilst the OEM plates don't. The 4xguard skidplates are plenty good for most situations, but for near complete peace of mind it is wise to do as T-rated suggests...get them OEM+4xguard components and rest easy.
CEPCNC is offline
post #15 of 24 Old 10-15-2007, 04:07 PM Thread Starter
mrfWKJeep
2006 WK
I was going to order the front suspension & transfer case skids but I was reading that the fuel tank one is required to install the transfer case one? justforjeeps won't ship the fuel tank one - pickup only. Can I replace the other two and leave the plastic fuel tank "brush gaurd" for now?
Skid Plate BonesWK WK Grand Cherokee & XK Commander Forum 17 01-30-2010 02:43 PM
4XGuard Front skid plate thequif WK Grand Cherokee & XK Commander Forum 9 09-17-2009 09:28 PM
front noise after removing front skid plate davets ZJ Grand Cherokee Forum 2 12-08-2008 05:54 AM
Front Skid plate Schwarttzy ZJ Grand Cherokee Forum 8 08-17-2007 10:28 AM
Front Mopar Skid Plate with a lift... Does it work? Is it worth it? Soft 8 ZJ Grand Cherokee Forum 42 10-14-2006 08:32 PM
