Front R/H Wheel Speed Sensor always stuffs up - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Front R/H Wheel Speed Sensor always stuffs up
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 11-06-2014, 02:40 PM   #1
multihulls
2006 XK Commander
I keep on getting a fault with my R/H front wheel speed sensor (WSS). I have the standard fault code come up along with the Dash warning lights and the brake pedal does the usual rattle noise and pedal pump. I then change the sensor and then all is good for about 6 months and then it happens again. I had replaced my front wheel bearing for some Chinese ones and though this was the issue so I bought original Mopar bearing and sensors and guess what the problem is back again after 6 months.
Is there's a central WSS module that may be at fault?
Or any other item that could be making the R/H sensor stuff up?
multihulls is offline   Reply With Quote Quick reply to this message
Unread 11-08-2014, 02:21 PM   #2
multihulls
2006 XK Commander
Bump, any answers to this problem? I could just change the sensor again but I'll be back doing it again in 6 months so I'd like to find the route of the problem.
Any help or thoughts please.
Unread 11-16-2014, 05:55 AM   #3
multihulls
2006 XK Commander
That's a pity, not one reply.
