Front lift spacer formula - JeepForum.com
post #1 of 3 Old 10-22-2015, 08:50 AM Thread Starter
bobbylx
bobbylx's Avatar
2008 WK
Sorry for the silly sounding thread title but I figured that described it best. I've searched around and seen mention of this, but wanted to know if there is a definitive answer.
When adding spacer to the front end for a lift, is this a standard ratio of 1:2? meaning a .25 inch spacer yields .5 inches of lift?
Like I said, i've seen people mention that but wondered if it were accurate? I'm putting together the parts for my winter project, going with a modified Rusty's spring lift (same as modified OME Omelet did early in his thread). Instead of buying spacers for the front, I was going to use my budget lift as a template and cut my own from .25 inch steel.
Thanks in advance, hopefully this is an easy question.
2008 Overland 5.7 Hemi
Modified Rusty's lift
JK Moabs/Nittos
Black WK Club #136
bobbylx is offline
post #2 of 3 Old 10-22-2015, 10:48 AM
luckyse7ens
2010 XK Commander
You want to add a strut plate similar to rustys? IIRC that one is 3/8"'s and good for ~.5" lift.
Rusty's has designed a simple way to level out your Commander or Grand Cherokee when you've added weight to the front of the vehicle, such as a heavy-duty front bumper or winch. The strut plates are precision laser cut steel and will give your vehicle just under 1/2" of lift. They are positioned on TOP of the front springs.
Black WK Club #152
luckyse7ens is online now
post #3 of 3 Old 10-23-2015, 08:20 AM
KillaJeep4569
2006 WK
I have the JBA strut plate, they are 1/4" and give a half inch of lift. Not sure if Rusty's are the same. I recommend the JBA plus they are cheaper.
Im already at 24" so I wont need another plate.
KillaJeep4569 is offline
