Front Hub Bearing Assembly recommendations? - JeepForum.com
post #1 of 12 Old 07-19-2013, 03:00 PM Thread Starter
JeepinShep
2007 WK
Pretty sure I'm going to be shopping for a set of front hub bearings shortly. 95k and they appear to have given up over the last couple of weeks.
Question to the forum: What brand(s) are good and recommended, and what should I stay away from? I want best bang for the buck, while avoiding stuff that'll leave me watching my wheels roll away 6 months from now.
eBay has 'something' for $50/ea
JCWhitney has 'em no name $75/ea..
Quadratec has 'em "OEM replacement" $130/ea
Timken has what some that appear to be great in writeup (lighter, stiffer, stronger), but sales documents do not reality make.. and they're $140/ea
And Omix-ADA has some for $215/ea
2007 WK Limited, Red Rock Crystal, 3.0L CRD, QD-II. OME HD lift. 255x75x17s. Pinchweld mod. 1.5" Alloy hub-centric spacers. F/R Stillen rotors and pads. 4xG rear diff guard and belly armor. Tuned by Green Diesel.
Originally Posted by bhoch
...you never, ever, skimp on suspension and tires as they will save your *** when you do something stupid - and .. you *will* do something stupid.
Originally Posted by DeansWings
Rock crawling is a whole 'nother animal. To me, the off-camber low rpm negotiation of lines provides a different type of adrenaline than plowing through mud. It's terrifying at times, but the pride of looking back at what you just climbed over is what is addictive.
JeepinShep is offline
post #2 of 12 Old 07-19-2013, 04:30 PM
sebastien
2006 WK
The place I took it to replaced my wheel bearing with junk one (parts master) had to replace it 3 or 4 times (for free) , finally upgraded to an OEM from the dearlership and has been fine since..
http://www.blacksheep4x4s.org/
sebastien is offline
post #3 of 12 Old 07-19-2013, 04:58 PM
giulio17
On all my jeeps I put timken bearings or national. They hold up really well but they cost a little more.
giulio17 is offline
post #4 of 12 Old 07-19-2013, 08:02 PM
BAH101
2008 WK
Well, as they say, you get what you pay for. A great man once said to me (my dad), "There is nothing more expensive than cheap tools". This also applies to parts.
My opinion, if you want to keep your Jeep for a long time, buy quality...if you're just trying to get it by, maybe looking to upgrade the item later due to lack of funds, or you are thinking of selling, buy the cheaper quality.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is online now
post #5 of 12 Old 07-19-2013, 08:11 PM
tjkj2002
2002 KJ Liberty
Timkin or SKF bearings are about the best options out there,may cost a little more but worth it.Granted Timkin now has been transfering there operations oversea's so they can be made in china now but SKF bearings are generally made in germany or japan so not low quaility stuff.
tjkj2002 is offline
post #6 of 12 Old 07-19-2013, 08:13 PM
Billybcpt
2005 WK
I got both front hub assemblies and they were Timken for $200 shipped from Amazon, look there.
Billybcpt is offline
post #7 of 12 Old 07-20-2013, 04:07 PM
blizzboy283
2005 WK
How does one know when hubs are going?
05 WK LTD 5.7L Hemi QD II Midnight Blue Pearl, Blue WK Club member #30
Intune, AFE Stage 2 CAI, BT Catch Can, Gibson Cat-back, OME HD, 255/75/17 BFG KM1s, 1.25" Spidertrax, LED Interior, Reverse & Tail Lights, 3/4" Grille, Chrome Fuel Door & handles, SRT8 Pedals, Taylor Shorties, XK knob, 4xGuard Front 4 & Rear Diff.
blizzboy283 is offline
post #8 of 12 Old 07-20-2013, 04:17 PM
sebastien
2006 WK
If your wheel wobbles, Jack up the wheel you think is bad, grab it and see if it wiggles
post #9 of 12 Old 07-20-2013, 04:21 PM
Billybcpt
2005 WK
It makes obvious grinding type noise when you turn and put weight on that hub assembly. Though some mechanics will say whatever side you hear the noise on then it's the opposite hub assembly that needs to be replaced.
post #10 of 12 Old 07-20-2013, 04:55 PM Thread Starter
JeepinShep
2007 WK
I'm going to replace both - though at the moment there's no wobble just from hand-pressure on the wheel. Watching videos and reading diagnostic guides has pretty much convinced me they're going bad.
post #11 of 12 Old 07-22-2013, 07:13 AM
JKM
2005 WK
RockAuto has the Timken units for $120 each. I installed Timken hubs when one of them started to make noise. I replaced both fronts as once one starts going, the other one is probably not far behind it!
JKM is offline
post #12 of 12 Old 07-26-2013, 08:36 AM Thread Starter
JeepinShep
2007 WK
Turns out, after an afternoon spent with a friendly mechanic, that it's probably NOT my wheel bearings after all. I have some excessive slop in the CV joint end of my front drive shaft. now I'm looking for a good driveline shop to build me a DC/DC shaft so I can a) service all parts in the future and b) have a slightly more dependable unit to handle the additional off roading I plan on doing.
