Front Fascia - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Front Fascia
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineZone Offroad Body and Suspension Lift Kits, Brackets, DiscBilstein Shock Upgrade Kits, Jeep JK TJ XJ Wranglers and C
Unread 08-19-2014, 10:00 AM   #1
MikeJeep09
Front Fascia
I tried to search to no avail and could not find any info. My front fascia "unclips" The fascia has what looks like tabs that insert and just clip in. I can easily gently lift on the fascia and push the clips in but once I drive it they pop out again. Is there something I am missing? Thanks ahead for any help.
MikeJeep09 is offline   Reply With Quote
Unread 08-19-2014, 10:11 AM   #2
CRCs_Reality
2005 WK
Once you push the clips in, they should turn 90 degrees to lock.
Unless I'm misunderstanding your question?
2005 WK Limited, 5.7, QDII
Silver WK Club Member #116
CRCs_Reality is offline   Reply With Quote
Unread 08-19-2014, 10:59 AM   #3
Mitkch
2007 WK
@CRCs I was going to say the same thing as you.
Gotta turn them clockwise, mate. If it's not the air dam, you could take a couple pictures to illustrate your problem a little better.
Black WK Club #138
Mitkch is online now   Reply With Quote
Unread 08-19-2014, 12:28 PM   #4
MikeJeep09
Ok will have to take pictures there is not a clip that can turn, just almost like a cereal box top push in clip that is part of the mold on the fascia if that makes any sense.
Unread 08-19-2014, 12:29 PM   #5
modernblueWK
What year? Pics?
2008 WK 4.7 245/70-17 Grabber AT2 - Magnflow - JBA - G2 - Steel Armadillo - MLL's
Blue WK club #4
modernblueWK is offline   Reply With Quote
Unread 08-19-2014, 03:04 PM   #6
MikeJeep09
2009 Grand Cherokee Overland
Unread 08-19-2014, 03:51 PM   #7
suseejr
2008 WK
Drill a hole and use little black push pins. You can get them at Napa and they're removable
suseejr is offline   Reply With Quote
Unread 08-19-2014, 07:56 PM   #8
MikeJeep09
There is no way of accessing where these clips push in. I should have taken pictures but figured this might be a common problem. I guess not.
Unread 08-19-2014, 08:05 PM   #9
suseejr
2008 WK
Yes, its common, I see it all the time. right below the tab drill a small hole through the facia and the plastic behind it . then insert the corresponding size push pin in to the hole. Push in the center and it will lock it like a rivet. The push pins will match the black color of the facia. Which is actually an air dam
Unread 08-19-2014, 08:40 PM   #10
MikeJeep09
Unread 08-20-2014, 01:34 PM   #11
tom19511
2006 WK
Looks like they hook in the slot. look closely they may be broken.
Tom19511
tchristopher1@wowway.com
2006 Grand Cherokee Laredo 3.7
2007 Liberty Sport 3.7
tom19511 is offline   Reply With Quote
Unread 08-20-2014, 02:02 PM   #12
caulk04
2008 WK
Try removing the lower air-dam (7 1/4-turn fasteners, it's covered in the manual) and checking for debris or other damage causing it to pop out.
Simply removing it and re-installing it with those snaps first may be enough to get it seated properly.
Tint, Superchips, SRT intake tube, Gibson catback, catch can. One hardcore DD/kid hauler...yeah.
caulk04 is offline   Reply With Quote
Unread 08-20-2014, 03:18 PM   #13
MikeJeep09
Ok I will try to remove it. Also they do not appear to be broken.
