Front End Clunking Noise - Not Bushing...Maybe Calipers? - Page 2 - JeepForum.com
 1Likes
post #16 of 26 Old 08-26-2011, 05:34 PM
mailforjon
mailforjon's Avatar
2005 WK
bad tie rod or steering stabilizer?
-2005 WK 5.7 Limited [DD]
-1999 WJ 4.7 Limited [SOLD]
-1998 ZJ 5.9 Limited [SOLD]
-1996 ZJ 5.2 Laredo [SOLD]
-1994 ZJ 4.0 Laredo [SOLD]
-1993 XJ 2.5 [SOLD]
mailforjon is offline
post #17 of 26 Old 08-27-2011, 07:04 AM
multihulls
2011 JK Wrangler
I had a similar noise about 18 months ago and went to my local Sealership. I told them to check the front swaybar as I read this was common source of this type of noise. I picked the car up in the afternoon and they said they couldn't find the noise and bring it back if it get worse. Bloody hopeless!
I drove the car home crawled under the front of the car and unbolted one of the lower sway bar link rods. As soon as it was loose i found the problem. The nut on the ball joint at the top end of the sway bar link rod was loose. It just needed a 1/4 of a turn on the nut to tighten it, the joint didn't rattle any more. That hollow clunk noise had disappeared. Simple, quick and cheap fix. That was the second last time I ever went to the Stealership
multihulls is offline
post #18 of 26 Old 08-27-2011, 09:11 AM
Chapman89
2011 JK Wrangler
^I'm hoping this might be the case for me! haha
2011 JKU Sport - 6 Speed
315/70/17 BFG A/T KO
17x9 (4.5BS) Black Rock Dune Series Wheels
Chapman89 is offline
post #19 of 26 Old 08-27-2011, 09:49 AM
mrtosh
2005 WK
No steering stabalizer on rack and pinion.
'05 WK Limited QDII, Superlift 6", Bilstein struts,315/70/17 Duratracs, Gibson CB, Volant CAI, JBA UCA's, JKS quick disco, adj. Rear trac bar, 4xguard armor, Diablosport Intune, Xenondepot 6000k HID's, Putco Jet yellow fogs.
mrtosh is offline
post #20 of 26 Old 08-27-2011, 05:38 PM
mailforjon
mailforjon's Avatar
2005 WK
ah yes, thanks for the correction. i was thinking of the old WJ
-1993 XJ 2.5 [SOLD]
post #21 of 26 Old 04-18-2013, 03:04 PM
cdrdriver
2010 XK Commander
Clunking in front end
I had a horrible clunking sound in my right front wheel, 2010 Commander, so I pulled the tire and found that my caliper mount bolts were backed out almost half way. I had the brakes serviced about 4k miles ago(63000 miles on it now). Well, i just grabbed some thread locker and re-torqued all four calipers and the clunking noise naturally stopped. I'm glad the caliper didn't come off as it would've been a missile flying around down there!!!! Thank goodness it was an easy fix!!!
cdrdriver is offline
post #22 of 26 Old 04-19-2013, 08:26 AM
corswandtm
2007 WK
I had my sway bar bushings and links replaced. Tightened it up some, but did not solve the rattle over bumps. I have noticed now that it doesnt rattle with brakes applied. Must be my calipers. Can I tighten? Is there a clip that might be missing?
2007 WK Red Rock Limited - 5.7 HEMI w/QD-II - Stainless 22" Magnaflow muffler - AFE Stage 2 CAI - Bilstein HD shocks/struts - JBA Strut Spacers - 245-70/17 Firestone Destination AT
corswandtm is offline
post #23 of 26 Old 04-20-2013, 03:55 PM
dsjr2006
2006 WK
Doubt you calipers are rattling if they are tightened properly. The pads can move around and rattle or it could be something else entirely.
'06 Limited Hemi QDII - Icon Coilovers - OME Lift w/Bilsteins - 32" 265/65R18 Goodyear Duratracs on JK Sahara 18s - Smittybilt XRC10 Comp X20 Winch
05-08 WK Service Manual PDF:
dsjr2006 is offline
post #24 of 26 Old 10-08-2013, 07:02 AM
kbranderhorst
where the pads ride on the knuckle can become quite grooved and worn from never having any hard ware what I did was throw some weld in the low spots and then grind them back down flat and smooth I work at a garage and yes once in a while brakes will cause some noise issues like you are describing good luck
kbranderhorst is offline
post #25 of 26 Old 10-18-2013, 04:41 PM
BF740
2008 WK
Same clunk noise
Had a "clunk" noise in the front tire area after a front brake job (my first). After reading this forum I double checked the caliper bolts. Those suckers just needed turned another 1/4 of turn and the noise went away. Sort of crazy the noise those things can make by not being completely tightened down.
Thanks forum!
BF740 is offline
post #26 of 26 Old 10-07-2014, 12:19 AM
cqbennett
I've got a rattling sound that seems to coming from the left front wheel area. Poking around down there I noticed the caliper seemed to be loose and rattled when I shook it. Tried to tighten the mounting bolts and one of them tightens down some but then just keeps on turning and never snugs down all the way. Guessing something in the slide pin/bracket is worn/stripped? If I order a new bracket does anyone know if the slide pins, boots, etc are installed? All of the pictures of the brackets looks like just the metal bracket itself. Not really sure exactly how slide pins work, hadn't ever heard of them until earlier today when I was searching for parts.
cqbennett is offline
Clunking noise in front end...what could it be? 95gc ZJ Grand Cherokee Forum 5 09-03-2013 10:51 PM
Clunking noise in front end twodoggs ZJ Grand Cherokee Forum 7 08-29-2009 11:38 PM
Another clunking noise from the front... Tigggger ZJ Grand Cherokee Forum 4 04-06-2009 11:40 PM
Front End CLUNKING Noise KZad ZJ Grand Cherokee Forum 16 10-16-2006 07:27 AM
clunking noise from front end boostn ZJ Grand Cherokee Forum 3 04-27-2005 10:48 AM
