Front driveshaft disconnect - JeepForum.com
post #1 of 15 Old 08-17-2010, 02:27 PM Thread Starter
Acidcold
2005 WK
Wondering if anyone here (4WD WK) has driven there Jeep without the front driveshaft? reason i ask is because i am trying to locate a problem and want to remove the shaft for a few days and drive it around town.
No smart @ss comments please! i am annoyed by this issue as it is.
Thanks
Acidcold is offline
post #2 of 15 Old 08-17-2010, 02:55 PM
merlinTec
merlinTec's Avatar
no I don't think you can sorry. What's the problem?
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #3 of 15 Old 08-17-2010, 03:24 PM Thread Starter
Acidcold
2005 WK
Not sure on the problem, i have replaced my entire front end minus the axle and still have terrible steering, i hear a very bad and scary clunk which i can't seem to find anywhere, not sure i can blame my lift then again i might have to tear down my front end again and hope i find the cause of my steering.
My new rack and pinion shows no leaks at all which i still feel that it might be my problem.
I am just so feed up with this POS and really considering making my Jeep rear wheel drive at all cost.
Acidcold is offline
post #4 of 15 Old 08-17-2010, 03:24 PM Thread Starter
Acidcold
2005 WK
I would imagine it's something electrical that might not let me drop the front driveshaft?
Not 100% sure if that is where my clunk is coming from.
Acidcold is offline
post #5 of 15 Old 08-17-2010, 03:27 PM Thread Starter
Acidcold
2005 WK
Now that i think about it, my front yoke and transfer case would still be spinning acting as if my driveshaft was in place..
Acidcold is offline
post #6 of 15 Old 02-12-2011, 08:47 PM
militia
2005 WK
why did jeep go gay
mine was making that same damb scary clunking noise, lol it only gets worsei just snapped off and my front drive shaft began to glow red and about seared threw my break or gas lines that run under the driverside. 05 limited 5.7 let me know if its possible to drive it without the thing on. now i cant get the damb thing to engage any gear or even turn over? it seems the damb things get a scratch and the whole system shuts down? ha imagine if we got a everytime we got scrapes we blacked out...there goes boxing i'm about done with jeep
militia is offline
post #7 of 15 Old 02-13-2011, 08:38 AM
Lt_JWS
2006 XK Commander
Are you having trouble with ESP/ABS or just the noise? Can you describe it alittle better? Also i believe you can't disconnect the front driveshaft...
2006 XK 4.7V8 | Quadra-Drive II | Daystar 2" Lift |K&N Filter | Port and Polished Throttle Body| Magnaflow# 12256 | IAT Mod | Leather, heated seats,Command View| Factory Tow hooks | Full factory skids | Rear D-Ring Shackle
Lt_JWS is offline
post #8 of 15 Old 02-18-2011, 02:12 PM
WK-916
If its a fulltime 4x4 then you cant disconnect the front ds.... it will make the viscous coupling inside freak out!
It will try and transfer power to the wheels with no slip... if no connection to front wheels.... will try and transfer all the power to the front but no driveshaft to transfer anything
WK-916 is offline
post #9 of 15 Old 02-18-2011, 02:32 PM
LJS8510
LJS8510's Avatar
2015 WK
Carlos,
when do you hear the clunk
as you drive?
as you turn?
going fast/slow
over bumps??
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #10 of 15 Old 02-18-2011, 03:47 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Originally Posted by LJS8510
Carlos,
as you drive?
as you turn?
going fast/slow
over bumps??
Not sure he is still having this problem. This was from back in August.
Omelet is offline
post #11 of 15 Old 02-18-2011, 11:22 PM Thread Starter
Acidcold
2005 WK
Originally Posted by LJS8510 View Post
Carlos,
as you drive?
as you turn?
going fast/slow
over bumps??
Better late than ever Len! lol
Acidcold is offline
post #12 of 15 Old 02-19-2011, 06:05 AM
LJS8510
LJS8510's Avatar
2015 WK
lol
I hate when that happens!
LJS8510 is offline
post #13 of 15 Old 01-17-2016, 06:21 PM
vloveday
Took the front drive shaft off the 06 Commander today. The vehicle backed of the ramps once the front drive shaft was removed. Typically, I would have had the other tires chalked but the trans should have kept the vehicle on the ramps with the rear drive shaft in place. Anyone have an idea why the vehicle would be able to move?
vloveday is offline
post #14 of 15 Old 01-17-2016, 06:41 PM
caulk04
2008 WK
Because inside the transfer case is a differential. Always set the parking brake!
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #15 of 15 Old 01-17-2016, 06:58 PM
vloveday
Makes sense, thanks.
vloveday is offline
Driveshaft disconnect dz1087 ZJ Grand Cherokee Forum 7 02-17-2009 04:04 PM
Front driveshaft too long after swapping front differential jjeeeeppss ZJ Grand Cherokee Forum 11 08-12-2008 05:19 PM
how do i disconnect WJ front radiator fan? mat1 ZJ Grand Cherokee Forum 3 12-30-2006 08:25 AM
Front axle Disconnect 95GCV8 ZJ Grand Cherokee Forum 10 06-15-2006 09:40 AM
Front Driveshaft ? Bloodbath ZJ Grand Cherokee Forum 0 05-12-2006 09:17 PM
