Front Drive Shaft Removal - Page 3 - JeepForum.com
post #31 of 35 Old 05-31-2013, 12:05 AM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
That is interesting! I have a uni on the pinion end and a cv on the t-caseend with my Hemi and mine doesn't come out without unbolting the crossmember. Iplan to take the spare shaft I have in and have it modified like yours on thet-case end with a double cardan and also have them put a slip in it so it willcompress enough to be removed if need be. You said you had the adapter speciallymade? I was hoping there would be something out there already that would work.Any chance I could trouble you for one?!
That sucks about the brake lines! I wonder why they did that?
Omelet is offline
post #32 of 35 Old 05-31-2013, 12:21 AM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Some more info and pics:
http://www.jeepforum.com/forum/f67/o...1/index40.html
Omelet is offline
post #33 of 35 Old 06-01-2013, 04:32 AM
Valpacer
2007 WK
Does yours not have a slip joint under the concertina plastic cover? If they put a slip joint the same length as the rear shaft noone would have any problems!
My shaft was cut down down and had the Cardan welded onto the end, and they machined the flange on the cardan to match the tcase pattern. Not just as simple as an adaptor sorry!
2007 WH Grand Cherokee CRD (Yup, RHD Australia)- 3" Exhaust, GDE Flash Tune, CRDSTU/SL Hybrid Lift & bash Plates, 4xGuard Rock Rails, Saguaro F & R Bars, RCV's, Warn 9.5cti-s, AEV Saverge Rims, Nitto Mud Grapplers, Snorkel, Custom Rear Drawers, On Board Air, BullyDog Monitor, Dual Batteries -
Valpacer is offline
post #34 of 35 Old 06-01-2013, 08:19 AM Thread Starter
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Oh I see, thanks. I have a slip in mine but it is on the t-case side. It would get cut off when the cardan goes in, so they would have to add a new one at the same time.
Any chance our t-case end is similar to anything the JK uses? That would make things easier!
Omelet is offline
post #35 of 35 Old 06-26-2013, 09:56 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Pulled my front drive shaft today.
'07 4.7 - definately pull the cross member.
12 8mm bolts later - this is what comes out:
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
