Front Differential and Transfer case fluid change - JeepForum.com
post #1 of 12 Old 06-25-2013, 04:54 AM Thread Starter
guls
2015 JK Wrangler
After watching the video's here I tried changing the fluids on both differentials and transfer case. But I was only successful on the rear differential.
Front differential there is no room to remove the fill plug (14mm Allen wrench) and on transfer case there is no room to remove the drain plug (10mm Allen wrench). Dealer is asking $225 for both. Any help be appreciated.
Also I was trying to install the new headlight switch but couldn't get the screws out on the plastic casing on steering wheel. Are they Philips or just standard screws.
Thanks.
guls is offline
post #2 of 12 Old 06-25-2013, 08:11 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
Not sure what u mean by "no room" to get to the front diff and tcase. They should be readily accesible.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is online now
post #3 of 12 Old 06-25-2013, 10:19 AM
colinzj
2006 WK
A hex socket will easily get the transfer case done if your allen wrenches are too long.
Can't comment on the diff. My dealer charges only slightly more than the fluid cost on those.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline
post #4 of 12 Old 06-25-2013, 10:56 AM
JKM
2005 WK
They are good instructions on WKjeeps.com Review these and they should be helpful
JKM is offline
post #5 of 12 Old 06-25-2013, 11:30 AM
JeepN4KC
JeepN4KC's Avatar
For the diff just cut about 2" off the handle of a 14mm allen. Use this with a 14mm box wrench.
~Mike~
WK
XJ
post #6 of 12 Old 06-25-2013, 11:46 AM
modernblueWK
Way to stick with it!
SOLD 2008 WK 4.7 V8
2013 Hemi Durango Crew
2007 Silverado Crewcab LT3
modernblueWK is offline
post #7 of 12 Old 06-25-2013, 12:43 PM
modette
2005 WK
So what is the issue?
modette is offline
post #8 of 12 Old 06-25-2013, 02:41 PM
bhawks28
2014 JK Wrangler
^ yeah that's exactly what I do
2014 JKU Rubicon
bhawks28 is offline
post #9 of 12 Old 06-25-2013, 06:58 PM Thread Starter
guls
2015 JK Wrangler
Thanks, I will try it.
guls is offline
post #10 of 12 Old 06-25-2013, 08:43 PM
ryann04
2008 WK
Love it, thinking outside of the box.
Just learned something new today!
2008 - Jeep Grand Cherokee - 3.0L CRD - Quadra Drive II - GDE Hot-Tune - OME HD Lift Kit - OEM Full Steel Skids
Blue WK Club Member #42 // DIESEL FTW !!!! -Ryan
ryann04 is offline
post #11 of 12 Old 06-25-2013, 09:38 PM
Nejeep
If the T-case is a QT1 it has a vibration damper covering the drain hole. You have to remove the damper first.
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is offline
post #12 of 12 Old 06-27-2013, 01:08 PM
marko138
2011 WK
Yep, it's tight so that's what I did.
Was gonna say the same thing. Remove it (be careful, it's HEAVY) and access is EASY.
marko138 is offline
