Front diff bushings - JeepForum.com
post #1 of 15 Old 10-21-2012, 11:41 AM Thread Starter
polpilot
2005 WK
Front diff bushings
Where can I get new bushings for my front diff? I replaced my ELS senor yesterday and noticed that the bushings are pretty warn, and i get a bad thunk in the mornings when I first put it in reverse. So I'm thinking I need to replace them. I've looked at Rockauto, Autozone, and Google! Is this a dealer part?
Anyone in Germany here is my Off Road page.
polpilot is offline
post #2 of 15 Old 10-21-2012, 12:07 PM
Budasac
2005 WK
You can get two of the three but the front you have to buy the bracket with the bushing in it. That one is only available from the dealer as far as I know.
Budasac is online now
post #3 of 15 Old 10-21-2012, 10:23 PM
suzieque
2008 WK
The 2 bushings that do not require a bracket are actually referred to as isolators, I think the part number is 52089516ab. The part with the bracket is 52114354aa.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #4 of 15 Old 10-22-2012, 06:48 PM
McGR
2007 XK Commander
McGR is offline
post #5 of 15 Old 10-23-2012, 12:20 AM
scootter82
2009 WK
Here are the parts needed:
1 of these. $107.10
http://www.justforjeeps.com/fraxmobr.html
2 of these. $29.79 a piece
http://www.justforjeeps.com/fraxmois.html
Prices are slightly higher than above. I copied and pasted from the tutorial: http://www.jeepforum.com/forum/f67/h...cement-1299567
I just ordered these myself and plan on changing them out pretty soon.
OME HD, JBA UCA, Rear Adj TB, Catch Can, K&N CAI, Gibson CB, MM TB, Flaspaq, Full LED swap
scootter82 is offline
post #6 of 15 Old 10-23-2012, 07:30 AM
DavidsCyclops
2014 WK
Check this site. you must know the part number.
http://www.mopar-wholesale.com
They are usually the cheapest reliable source that I know of
DavidsCyclops is offline
post #7 of 15 Old 10-23-2012, 09:31 AM
Scottso699
2006 WK
I actually just got these replaced at the dealer 3 days ago (under warranty). They were totally shot. Just the upper 2 though - the front lower one was in good shape. I was shocked at how much the front dif was moving up and down! Rather scary actually.
Scott
2006 WK Overland, OME HD Springs F&R, Bilstein 4600 Struts, 1.5" Rear Spacer, 265/70/r17 BFGs
Scottso699 is offline
post #8 of 15 Old 10-23-2012, 10:37 AM
DavidsCyclops
2014 WK
under warranty?
post #9 of 15 Old 10-23-2012, 10:54 AM
Scottso699
2006 WK
Originally Posted by 2005WK37David View Post
under warranty?
Oh sorry - I should have elaborated - I had the foresight to buy a Max Care warranty when I bought the jeep back in 2010. For what I spent on that Warranty it has paid for itself almost 3 times over now. All I pay is $150+tax when I get service done.
Scott
post #10 of 15 Old 10-23-2012, 01:58 PM
IndyBlueWK
2005 WK
Clunk..
IndyBlueWK is offline
post #11 of 15 Old 10-23-2012, 02:05 PM
Scottso699
2006 WK
Originally Posted by IndyBlueWK View Post
I know this is off topic but can anyone tell me what in the world #18 in this diagram is? And what it does?
Scott
post #12 of 15 Old 10-23-2012, 05:19 PM
DavidsCyclops
2014 WK
I believe it is a damper, to limit vibration.
post #13 of 15 Old 10-23-2012, 07:17 PM
Beeracuda
2006 WK
That is what the book shows...
2006 Grand Cherokee Overland, bone stock...for now.
The Beeracuda:
Beeracuda is offline
post #14 of 15 Old 10-23-2012, 08:59 PM
Scottso699
2006 WK
Ok weird... how does it work? When I poked my head under there and it looks like a brick with a hole drilled through it...
Scott
post #15 of 15 Old 10-23-2012, 10:05 PM
Beeracuda
2006 WK
I am definitely no engineer, but if I was guessing, the added weight is harder to move so it helps to dampen out the vibration or change the frequency where the vibration would happen.
The Beeracuda:
