Front Bilsteins installed myself - JeepForum.com
 2Likes
post #1 of 35 Old 12-10-2009, 07:40 PM Thread Starter
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
I did the front Bilsteins todays. Don't know why people pay someone else to do it. Only took 2 1/2 hours with normal tools and spring compressors that I bought ages ago.
The only thing that was a pain was moving the fuse box and reservoir to get to the upper nuts. I put the compressors on first, then loosened the nuts and fork bolts, knocked the upper a arm loose and out it came ... piece 'o cake.
Remove 3 nuts holding fusebox or 1 nut securing coolant reservoir (reservoir is also secured with tab, just push it towards the engine to release)
Push/hold fusebox or reservoir out of the way while removing 4 nuts securing upper strut bracket (pic)
Put car on jackstand.
Remove wheel
Hydraulic jack under lower control arm (LCA)
Jack all the way up until it starts to lift off jackstand
Put on spring compressors (pic)
Lower jack until light pressure is applied.
Loosen nut at upper control arm (UCA) ball joint
Hit bolt with heavy hammer (it took two strikes with my 3 pound hammer)
Unbolt lower strut clevis (fork) @ LCA. Remove bolt
Unbolt swaybar @ LCA
Unbolt the clevis bracket bolt now. It's easier than doing it once strut is removed. (pic)
Remove wireholder located at strut fork securing bolt
Keeping hold of the spindle, remove UCA nut that you loosened earlier
Keep an eye on the brake line from now on.
Slowly lower jack all the way.
Carefully remove strut. You have to push the UCA up to get the strut out.
Note orientation of shock upper mount and upper and lower spring isolators.
Spring is already compressed, so just remove the upper shock nut. (pic)
Take it all apart and lay it out on the floor in order.
Remove the clevis/fork by smacking the bottom of the shock with a heavy hammer 6-10 times.
Put the fork on the new strut by tapping it with the hammer, I put a bit of grease on the strut to help it along.
Put it all back together remembering to put the washer on FIRST as shown in the diagram that came with the new struts.
Finesse the strut back in place pushing the UCA out of the way.
I bolted the top bolts in first to hold it in place.
The rest goes back in reverse order.
It really was pretty easy.
I didn't have a large enough socket for the clevis/fork bolt so I just used two big crescent wrenches.
I did it without help, but a second set of hands while removing/installing the strut would help.
Started at 2:30, finished at 5:05
Below ... Fuse box held out of the way to access upper strut mount bolts
Below ... Spring compressors installed and UCA ball joint nut that's to be loosened
Below ... Unbolt the clevis bracket bolt
Below ... removing upper shock nut
Below ... Put that washer on first!!
Below ... Key hole for lower spring isolator doesn't match on bilstein, had to cut knob off of isolator.
buddy357 likes this.
07 Steel Blue Overland CRD QDII | Bilsteins | 4xguard Matrix | Rear SRT8 SwayBar | DashHawk w/egt | MBRP XP Exhaust | New Intake Tube & Seal | Alternator Splash Guard | Crank Sensor | GPS AL InMotion Hack | Swirl motor bypass | Blue WK Club Member #13 | 200,000 Mile Club | Dogpiled Club | pre-N23 FDCM |
89 GW w/plow
wookiee is offline
post #2 of 35 Old 12-10-2009, 08:31 PM
jeepfan30
2014 JK Wrangler
You're teasing me! I ordered some this week and today they told me they are on nationwide backorder. Just my luck, do you know where there might be a secret stash?? I look forward to seeing your pics, I'm going to do mine myself too.
3" EVO Enforcer, Fox 2.0 Shocks, 4.56 w/Truetracs, Coast F&R DS, 35" Toyo M/T, Warn Zeon 10-S
jeepfan30 is offline
post #3 of 35 Old 12-10-2009, 08:35 PM
JMorash
2005 WK
Im writing this to get a notification for your pics when posted. Good job.
2005 WK 5.7L Hemi
HEMI Club Member #28
3.5 Rock crawler lift.265/65R17 Toyo AT SuperChips Flashpaq MDS delete
JMorash is offline
post #4 of 35 Old 12-10-2009, 09:54 PM
modelbuilder
2005 WK
Pics and a write up would be great.
My fronts are on the way. My 4wd shop got them for me from the east coast.
Already installed the rears.
modelbuilder is offline
post #5 of 35 Old 12-11-2009, 01:58 AM Thread Starter
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
I ordered mine from shockwarehouse 10/29 and they got here 11/30!
89 GW w/plow
wookiee is offline
post #6 of 35 Old 12-11-2009, 08:31 AM
jeepfan30
2014 JK Wrangler
That's where I ordered mine. They said they will be in mid January.
post #7 of 35 Old 12-11-2009, 09:13 AM
modelbuilder
2005 WK
Try to call a local shop. My 4WD shop ordered them for me and they located a set of fronts for me on the east coast. I should get them next week.
Shockwarehouse is a big company and they don't have the time to give individual orders much attention. Plus my local shop was only charging $4 more per shock with free shipping.
post #8 of 35 Old 12-11-2009, 11:48 AM
YB Normyl
YB Normyl's Avatar
2016 JK Wrangler
Subscribing
YB Normyl is offline
post #9 of 35 Old 12-11-2009, 11:59 AM
smcginnis87
4X4WK
smcginnis87's Avatar
2007 WK
Very cool!! helps if i do it my self...
2015 WK2
--4x4WK--
smcginnis87 is offline
post #10 of 35 Old 12-11-2009, 12:53 PM
Acidcold
2005 WK
It is super easy to do it your self, just curious why you compressed the coils before removing the whole assembly?
Acidcold is offline
post #11 of 35 Old 12-11-2009, 01:17 PM Thread Starter
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
Lazy!
By putting on the compressors while the spring is already compressed, I don't have to tighten them after the strut is out.
Plus with the spring compressed, it makes the assembly itself shorter, which makes it easier to remove.
89 GW w/plow
wookiee is offline
post #12 of 35 Old 12-12-2009, 01:01 AM
grebesjeep
2005 WK
How do they ride??? I need new shocks but not sure if should get stock ones or get bilsteins. My concern with the bilsteins is they will ride rough and cause the inside of the jeep to rattle and sound like $%*& over bumps....any feed back would be great! Great write up with the front install.
05’ WK GC, Hemi, REC/VES, 2.25” RR lift, 265/70/17 Bridgestone Revo 2’s, Rubicon wheels, k&N CAI, Magnaflow exhaust, Factory underbody steel skid, Factory transfer steel skid, Homemade front skid, Homemade rocksliders. Commander shift nob, Nav in motion cheat, Rola roof rack, Bilstein's, Rear air bags and remote compressor, factory projector/HID retrofit, front and rear SRT8 sway bars, chrome front tow hooks….thats it for now.
grebesjeep is offline
post #13 of 35 Old 12-12-2009, 04:58 PM Thread Starter
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
The oems were always 'floaty'
If you watch indy car racers. Remember how they go over humps in the road? That's what it feels like now.
89 GW w/plow
wookiee is offline
post #14 of 35 Old 12-13-2009, 12:18 AM
justa4banger
2007 WK
So hey since i'm in town you wanna do mine lol ......
I guess i might need to order the shocks first... I almost pulled the trigger on some blistiens and SRT8 springs (going the other direct on my 2WD) , but i decided to wait after the holidays...
2007 GC LTD CRD 2x4.........For towing...
1985 Mustang SVO 2.7t......In progress
justa4banger is offline
post #15 of 35 Old 12-13-2009, 11:49 AM
smcginnis87
4X4WK
2007 WK
??? so are they stiff now or what?
2015 WK2
--4x4WK--
RR 2.25" & Bilsteins? cobrakillerta WK Grand Cherokee & XK Commander Forum 2 12-03-2009 05:40 PM
4'' IRO LA's and Bilsteins Sal ZJ Grand Cherokee Forum 8 08-26-2009 12:11 AM
Bilsteins for RR lift drrabazz WK Grand Cherokee & XK Commander Forum 3 01-09-2009 09:21 PM
Bilsteins vtbert3 WK Grand Cherokee & XK Commander Forum 2 04-20-2008 04:41 PM
Bilsteins on 2005 wk patd63376 WK Grand Cherokee & XK Commander Forum 18 10-26-2007 06:39 PM
