Frequently Asked Questions: WK/XK - Page 7 - JeepForum.com
 4Likes
post #91 of 142 Old 07-15-2014, 10:47 PM
bersh
2008 WK
I have an addition to the tire talk from throughout the thread. Today I had a set of Cooper AT3 265/70-17 installed on my stock wheels, running them without spacers on an OME MD lift. I don't have any rubbing on the pinch weld, but I had to cut the ball joint stud almost to the nut to give what I think is adequate clearance. I initially cut the stud at the base of the threads and I had about 1-2mm clearance, which to me was too tight. I also had quite a bit of rubbing at full lock in both directions (passenger was slightly worse) on the frame/metal plate that is located at the rear portion of the wheel wells. I took a BFH and folded the lower lip on this plate in a touch so it hopefully won't grab the tire, and I also hammered on the face of the plate at the two rubs to hopefully provide enough clearance. I cleaned, prepped, cleaned again, shot it with primer, and then a quick shot of rubberized undercoating when I was done. It was still tacky so I haven't driven it yet tonight so not sure if I will still have contact or not.
Point of all this is that I don't think the original recommendation of 265s (31.6") for a 2-3" lift is correct without saying there will most likely be rubbing. Everyone is worried about the pinch weld but that sharp lip on the frame can do damage to your new tires as well. I've seen in this thread, as well as numerous other threads, 265/70-17 being recommended with no rubbing, and from what I've seen today this simply isn't true. Granted, different tires, styles, manufacturers are going to have variations in diameter and width, but I can tell you for sure that the Cooper AT3 in that size rubs with the OME MD lift. I really don't want to run spacers, and I'm considering calling my tire place in the morning to see if they'll swap out the 265 for 255, or possibly 265/65-17. However, between the cost of the remounting and balancing, and the additional cost due to the 255 being a less common size, I'm already at the cost of a set of spacers so I might just cave in and use them until I can find another set of wheels.
I've also posted similar info in the tire/wheel thread and a couple others that get read often. I hope this info helps out others that are in the situation I was in and wondering what size tires to go with after they get their new lift on. For what it's worth, I've been driving with the lift for about a week and it settled at most about 0.25" from when I first put it on. I'm now at about 22.25" from center of hub to the wheel well in front. I have the CRD, no armor or bumper (no real plans to put armor on, though I may get the front "suspension" skid in the future) using 4600 in the front.
bersh is offline
post #92 of 142 Old 07-16-2014, 08:36 AM
csacharuk
2005 WK
Bersh, I'm in exactly the same boat as you right now. I have a 2" BB lift and last week installed 265/70/17 General Grabber AT2 all around. I used 1/4 spacers to clear the UCA bolt, and have no issues with the pinch weld or fender. However, at full lock I'm hitting the frame and sway bar. I wasn't as concerned about the front sway until I noticed the when in reverse at full lock the rubbing on the frame was actually cutting small pieces out of the tread on the front tires.
I figured my only option at this point was to invest in a set of new spacers to hopefully throw the wheel out just far enough so it wont hit anymore. I reached out to Kolak and he suggested the same thing.
I ended up ordering 1.25" spacers all around and will be putting them on this weekend, hopefully in addition to Bilstein 4600 rear shocks.
I'll keep you posted on the results.
Good luck with your tires
Blue 05 WK 3.7 | RC 2 BB | 265/70/17 GG AT2 | Bilstein 4600 HD (rear) | 1.25 Spacers | Hypertech Max
csacharuk is offline
post #93 of 142 Old 07-16-2014, 11:26 AM
bersh
2008 WK
I am going to add that the upper stud was contacting the tires slightly, even though I initially had that 1-2mm of clearance (maybe 2-3mm, I didn't try to measure it but not much clearance). I generally agree that if the stud clears it should always clear, but I think you need more than 1/8" or so to be sure. While driving there must be some dynamic force going on in curves and corners that must flex the tires a touch as yesterday in the driving I did before cutting the studs more I had a very slight vibration/rubbing feeling when taking curves and corners at speed. When I removed the tires to cut the stud and hammer the fender, I noticed a line around the edge of the tread at about the point that the studs were. It didn't cut into the tire, more like rubbed it clean, so it must have just very slightly been making contact. Today, taking corners and curves at speed I didn't have any of the same sensation so I'm guessing that the additional chopping has provided enough clearance. Lesson learned is that having just enough space for say a credit card to slide between the stud and tire isn't enough.
Also, the hammering helped but didn't solve the rub on the frame. I may try smacking it a bit more, but the contact is still enough that I don't think I can bend it far enough out of the way with the BFH. I may try an air chisel with a blunt tip to see what happens.
I know I'm making this sound a bit more doom and gloom than it really is, but folks should be aware that this FAQ is a bit misleading/lacking information so hopefully this helps a bit.
bersh is offline
post #94 of 142 Old 01-09-2015, 07:43 PM
jccJeep
2007 WK
Was is the stock height from center caps to fender?
USA
jccJeep is offline
post #95 of 142 Old 01-13-2015, 10:09 AM
bigswingface
2005 Quadra Drive II Question
Please know I did read through a lot of threads before asking this.
I've seen posts that say QDRII is always in 4WD but only sends power forward if the rears slip. I've also seen posts and literature from Jeep stating it's a 48/52 split unless there's slippage, at which point the gerotors take over.
Which is the case? I understand to a fair degree how the differentials work in this system...I just don't know how much power goes to the front wheels on an everyday/normal driving experience.
And, if it IS true that the front wheels receive no power unless the rears slip, how does this effect its performance on snowy roads?
Thanks in advance for your responses. My only experience with 4x4s was my '91 Cherokee which was pretty easy to understand in terms of how the 4wd worked.
bigswingface is offline
post #96 of 142 Old 01-15-2015, 07:42 PM
PDragon
2007 WK
Bigs, the literature from Jeep is correct. The WK is bias towards the rear. As for driving in the snow and ice, the traction control does a pretty decent job at keeping the WK out of trouble. But make no mistakes, this is not a rally car. I keep finding myself having to slow down or bringing the rear under control when the Jeep slips the rear while turning on icy streets. You can also manually turn off/on traction control if you want to experiment with different driving experiences.
At the end of the day, the tires that you are running in the snow/ice will be a key factor for keeping you safe.
Hope it helps.
2007 WK CRD / QDII /+250,000 kms
GDE Eco tune / OME HD / JBA UCAs
275-75-17 Cooper Discoverer AT3
PDragon is offline
post #97 of 142 Old 02-07-2015, 05:27 PM
Greever
2008 WK
So on thursday I had a bit of a problem, the temp was like 2 and the highway was wet from mushed snow. While on the highway my windshield got a little misty but nothing to hit the wipers for...but thats not what my auto wipers thought lol. it whitewashed my windshield a bit so i pulled the stick to wash it a bit...man oh man was it a bad idea lol. Apparently my washer fluid froze up so my wipers went off w/o any fluid on the shield and made the problem worse...to the point that i had to get off the highway cause i could barely see through the shield. Luckily I had a bottle of windex with me (though that was partially frozen too, to the point that i broke the trigger try to spray it lol), cleaned the shield and turned off the auto wipers.
now my question is, what windshield washer fluid would you recommend?
Also, im going to be driving about 600 miles in one day next week. Gonna check my fluids tomorrow, but is there anything else I should check?
Greever is offline
post #98 of 142 Old 02-12-2015, 07:36 PM
kdawgFL
2005 WK
You can add 16oz of isopropyl ancho to a gallon of wiper fluid
2005 5.7L limited, 2'' BDS Lift, 255-70-17 Revo II
kdawgFL is offline
post #99 of 142 Old 02-18-2015, 02:20 PM
jd0110
2007 WK
Rain‑X De-Icer Windshield Washer Fluid works really well for highway driving when there's misting on freezing days. I live in Co and deal with this all winter. I use it when that drizzle is freezing to the windshield as well ...
jd0110 is offline
post #100 of 142 Old 02-18-2015, 05:06 PM
CavallinoRed
2006 WK
Just a note that if you have rain sensing wipers to not to use Rain X treatment itself on the area around the sensor/rear mirror.
Not sure if the De-Icer fluid would cause a problem but website says "Instantly applies Rain‑X technology to the windshield for greater driving visibility" so might cause a problem with this feature.
CavallinoRed is offline
post #101 of 142 Old 03-02-2015, 10:39 AM
JakeWK
2005 WK
FYI, the links on the OP to the Lift Kit website and the link to the HID conversion are dead links. The Lift website, 4x or something, is a dead link, and all of the pictures have been removed on the HID thread.
JakeWK is offline
post #102 of 142 Old 03-15-2015, 04:41 AM
ataylor062
2005 WK
Hi Friends, I having a problem with the spare tire mount on the WK in the rear. Is there a release somewhere in the tail area?
ataylor062 is offline
post #103 of 142 Old 03-15-2015, 07:37 AM
longboy
2006 WK
Included with the jack is a little square-ish "socket" that you use to lower the spare from it's location. Do you have the factory jack?
2006 5.7l WK
longboy is offline
post #104 of 142 Old 03-15-2015, 10:15 AM
ataylor062
2005 WK
Yes, but there is no socket of any kind. If I had the socket, I wouldn't know where to use it.
post #105 of 142 Old 03-15-2015, 11:22 AM
CavallinoRed
2006 WK
This help?
99 WJ 4.7V8 Frequently shuts off while driving?? jjwells21 ZJ Grand Cherokee Forum 8 09-04-2014 03:48 AM
Front End Grinding Noise..I know this has been asked, please look. boosoo ZJ Grand Cherokee Forum 4 07-12-2012 09:16 PM
2000 jeep stalls frequently..... lilreeken ZJ Grand Cherokee Forum 0 02-18-2008 12:41 AM
Another BB Question... (I don't think it has been asked before) BlaineWasHere ZJ Grand Cherokee Forum 2 04-25-2005 08:45 AM
the most asked question... darktiger ZJ Grand Cherokee Forum 4 01-07-2003 09:25 AM
