Frequently Asked Questions: WK/XK - Page 5 - JeepForum.com
 4Likes
post #61 of 142 Old 09-06-2012, 05:17 PM
keggles
keggles's Avatar
2008 WK
Either is a good tire, Duratrac's have been the more popular from what I have seen on here. I wanted a good tire for a little offroad but still good for highway as I travel statewide for work. Best way to choose, what are your intentions/budget/expectations and find the best; P tire unless you are going big time use LT. I use TireBuyer.com which has good prices with free shipping. The Nitto is a 65k 500AB 113S tire for $150 each @ 265/70/17
I'm a nut, but not just a nut.
08 WK 5.7 Hemi 4x4
06 WK 4.7 - RIP
Silver WK Club #63
keggles is offline
post #62 of 142 Old 09-06-2012, 05:23 PM
Marna89
Awesome. Thanks for your help. Will check it out.
Marna89 is offline
post #63 of 142 Old 09-06-2012, 06:09 PM
CHSWarEagle
just found a pretty good deal on a 2008 wk 4.7 4wd, decent miles and was wondering if there are ant downfalls the the engine? i have read that there have been issues with the engine block overheating and having to replace after about 40k miles. does anyone have any suggestions or info on this?
thanks guys for the info!
CHSWarEagle is offline
post #64 of 142 Old 09-28-2012, 09:51 AM
caiati
2006 WK
I would buy a 4.7 with no worries whatsoever. I have an 06' with only 55K on it which is not big deal but I have two friends with 2001 GC's that have the 4.7L. They both have had them for years. One has 140,000 miles with absolutely no problems. The other has 178,000 miles and has never had an issue with the engine. He says that within the last 20,000 miles or so he does burn a little oil between changes. I actually drove it for a few days last week and the motor runs smooth and strong. The friend with the higher mileage has beaten that Jeep for years. He bought it when he was 21 and did plenty of mud/snow and trails with it. He did go through a transmission at 80,000 miles which was his fault. He did not put enough tranny fluid in it when he changed it. He has broken axles a few times due to pushing the limits. Not one ounce of engine problems.
caiati is offline
post #65 of 142 Old 09-28-2012, 09:52 AM
caiati
2006 WK
In addition............... The main reason I bought my Jeep with the 4.7 is because I saw how my friend beat the crap out of his for years and never had an issue.
caiati is offline
post #66 of 142 Old 09-28-2012, 06:49 PM
Theogriff15
2006 WK
Hey guys just wondering if there is any brand of lights that is recommended? I mostly see KC and Hella's, and I am planning on doing the lights behind the grille mod. Just wondering if there are any size restraints so that the lights can fit behind there?
2017 JKU - Sport, 3.21, Weathertech Floor Liners, Quadratec Diver Down Seat Covers
Theogriff15 is offline
post #67 of 142 Old 09-30-2012, 08:45 PM
oducks12
2005 WK
The 6" hella's work great behind the grill because the housing is relatively shallow compared to other lights. You could probably get away with using the 7" Hella's but I have no idea what it would look like. I think it might cover up too much of the grill for my taste, but to each their own! Other concern would be blocking airflow to the radiator. The Hella's are only 55w which is a bummer, but with upgraded wiring they can handle 100w bulbs.
2005 WK Laredo - SOLD
2015 WK2 Limited
oducks12 is offline
post #68 of 142 Old 11-29-2012, 04:28 AM
DieselDevotion
2007 WK
Q: What is the biggest tire you can fit without a lift?
A: Without any trimming or bolt cutting, 255/65/17, but you may have some rubbing at full lock(steering wheel turned all the way in one direction) with some tires depending on tread depth and design. The largest 18" tire you can add on the stock 18" rim without a lift is a 265/65-18.. The more aggressive looking the tread, the less clearance you will have. If you are unsure whether a tire will fit, go to a local tire chain(Big-O, Les Schwab, America's/Discount Tire Co, etc) and have them test fit that tire on both front wheels. You can then check the bolt for the Upper Control Arm(UCA), just above and to the inboard side of the front tire. Turn the steering wheel to full lock in each direction and check for the tire rubbing against the wheel well on the edges of the tire.
The first answer of this section needs to be corrected! One is obviously wrong but more than likely both are. It says largest 17" tire size you can run is 30" tall and and largest 18" tire size you can run is 31.5" tall and nearly a half inch wider.
I call total BS, a moderator needs to fix this for those who are new to this site and those who don't know much about metric tire sizes.
07 Grand Cherokee Limited 3.0L CRD QDII
89 5.9 Cummins powered F350
98 TDI Jetta
DieselDevotion is offline
post #69 of 142 Old 12-05-2012, 06:04 AM
gamma500
2015 WK
DiscountTireDirect actually beats this site along with TireRack..DTD has free shipping and a pretty good set of Rep's if you call with a question. Had them price me a set of tires in stock at the cost of the cheaper ones I wanted but they didn't have in stock.
2015 JGC Ltd, 3.6L
gamma500 is offline
post #70 of 142 Old 01-18-2013, 02:37 PM
RagtagGuy
2005 WK
Is there a lift/tire and rim size chart avaiable?
RagtagGuy is offline
post #71 of 142 Old 01-18-2013, 02:46 PM
naidib04
2006 WK
It's on another sticky thread at the top
PM me for details on Jeep
Blue WK Club Member #35
naidib04 is offline
post #72 of 142 Old 01-18-2013, 05:32 PM
RagtagGuy
2005 WK
I'm not finding it...
post #73 of 142 Old 01-20-2013, 12:54 PM
Jeepguy910
2005 WK
I would leave the bolt alone. $120 for 4 spacers and its more than enough. Mine is getting 265/70/17 Nitto Terras. With the lift/spacers/tire size it is about the same spacing as stock.
where did you get 4 spacers for $120 the only ones i can find is $100 bucks for just 1 pair
Jeepguy910 is offline
post #74 of 142 Old 01-20-2013, 07:15 PM
keggles
keggles's Avatar
2008 WK
RoughCountry is where i got my 1.5" spacers.
08 WK 5.7 Hemi 4x4
06 WK 4.7 - RIP
Silver WK Club #63
keggles is offline
post #75 of 142 Old 02-28-2013, 01:25 PM
fingaz
2009 WK
Originally Posted by dMalice View Post
...back to the ever-present Tire size question, lol.
I assume that other than stock size, any larger sized tire (without a spacer installed) requires the upper control arm bolt to be cut... does anyone have a definitive answer as to what sizes require the bolt to be cut?
Also, what are you guys doing if you ever need to separate the ball joint? how do you remove that nut after the bolt is cut??
Yes, back to the ever-present Tire Size Question:
The first page only talks about either stock height OR tires with a lift. It doesn't give info if you have stock height and have spacers and the pinch weld mod.
Whats the largest r17 tire I can fit with no lift and with spacers and with the Pinch Weld Mod, too?
I think my answer may be the 255/70r17. Thoughts? has anyone gone larger?
2009 3.7L Laredo Black | Two-Toned Leather | RER Nav/DVD/BA System | Viper alarm | HID's in the lows and fogs | Westin Brush Guard | Tinted Tails | Custom Blue LED Interior/Rear Hatch Lights | Rough Country 1.5" Spacers | General Grabber 255/70r17 -- Island Beach State Park 4x4 Mobile Sportsfishing Permit In -- To Do: Install Uniden CB, Rock lights
fingaz is offline
99 WJ 4.7V8 Frequently shuts off while driving?? jjwells21 ZJ Grand Cherokee Forum 8 09-04-2014 03:48 AM
Front End Grinding Noise..I know this has been asked, please look. boosoo ZJ Grand Cherokee Forum 4 07-12-2012 09:16 PM
2000 jeep stalls frequently..... lilreeken ZJ Grand Cherokee Forum 0 02-18-2008 12:41 AM
Another BB Question... (I don't think it has been asked before) BlaineWasHere ZJ Grand Cherokee Forum 2 04-25-2005 08:45 AM
the most asked question... darktiger ZJ Grand Cherokee Forum 4 01-07-2003 09:25 AM
