Frequently Asked Questions: WK/XK - Page 3 - JeepForum.com
 1Likes
post #31 of 137 Old 02-15-2012, 09:30 PM
dMalice
2009 WK
Originally Posted by BonesWK View Post
2"-2.25" BB Tire options. - NOT Including the OME 3"
245/75/17 - No spacer or pinch weld mod required
255/70/17 - spacer optional (minor rubbing without) no pinch weld mod
265/70/17 A/T - No spacers, no pinch weld
265/70/17 AND 255/75/17 - M/T - Spacer required 1.5" or some people use 1/4" AND Pinch weld mod required.
33x12.5x17 - 1.5" Spacer, Pinch weld and rear fender modification required
Thanks for posting this. just to clarify, if the 265/70/17 does not require spacers or a pinch weld then neither would the 255/70/17... so with a 2" lift there's no rubbing or mods necessary up to a size 265/70/17- just not a 265/70/17 mud tire. I assume that other than with the stock size tire, all other sizes require the upper control arm bolt to be cut/trimmed...?
dMalice is offline
post #32 of 137 Old 02-16-2012, 08:48 PM
jshif003
2005 WK
Just an FYI.... A new kit is entering the market... Rustys offroad 2.5" advanced kit. $499.99. The kit includess coils, struts, and shocks... Very comparable to the ome kits. I should receive a delivery tomorrow.... Pics and measurements soon to follow.
jshif003 is offline
post #33 of 137 Old 02-22-2012, 02:47 PM
dMalice
2009 WK
...back to the ever-present Tire size question, lol.
I assume that other than stock size, any larger sized tire (without a spacer installed) requires the upper control arm bolt to be cut... does anyone have a definitive answer as to what sizes require the bolt to be cut?
Also, what are you guys doing if you ever need to separate the ball joint? how do you remove that nut after the bolt is cut??
dMalice is offline
post #34 of 137 Old 03-09-2012, 08:25 AM
Rob 99TJ
Is there a write-up around for the DIY MDS indicator light for the 5.7 liter?
99' TJ Gunmetal Blue Sport /w D30 No-Slip/D44 Trac-Loc, 5spd, 2" susp./1" body, 33"MT/R's/AR767's, Durabak, Currie, Warn
07' WK Silver 5.7 QD2, Bilsteins & front strut plates.
Rob 99TJ is offline
post #35 of 137 Old 03-09-2012, 06:02 PM
TurboDiesel
2008 WK
depends what rim u are running, stock rim u will probably have to cut the bolt
im running a 17" rim with +10 offset and im about an inch away from the bolt with 255/75 BFG KM1's
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline
post #36 of 137 Old 05-14-2012, 11:37 AM
snowdude1026
2008 WK
Im about to get my Jeep all done up and lifted and pretty. I got the OME HD, and the 1.25" spacers. My tires I want are the goodyear duratecs 265/70/17 on the jeeps stock rims. Will I be needing a pinch weld mod done? If so, I hope the shop im going to knows how....
Also, this bolt issue I keep hearing about, how do I alleviate that? Or should I not even worry?
snowdude1026 is offline
post #37 of 137 Old 05-14-2012, 01:08 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
You shouldn't have to worry about trimming the bolt if you're putting spacers on.
As far as the p/w - best bet is to see if you get any rubbing. Street wise other than sometimes at full lock particularly in reverse is the only time a rubbed and it was very minimal. On the trails it's different because the suspension is different places through it's travel and turning at the same time so rubbing will be an issue - how much of an issue just depends.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #38 of 137 Old 05-26-2012, 08:58 AM
dMalice
2009 WK
Sorry- I must have missed your reply- Thanks. yeah, that sounds right. After doing research and buying new tires, I figured out that it all comes down to the spacers/rim offset in determining the max AT tire size without any mods to your fender/pinch weld or control arm bolt. I would say without a spacer or different offset rim, the max size you can fit with a 2" lift is 255/65/17 [I]maybe[I] a 255/70/17. I have 255/65/17 Falkens and it's very close yet they aren't rubbing at all... but any larger and that bolt would need cutting.
By changing rims to a less positively offset rim such as what you did with the +10mm offset (stock wk's have a +50mm offset which places the tire under the bolt) it allows the tire to clear the control arm bolt without having to cut it. That is why Pintler AEVs are so popular- they look good AND have a +25mm offset which allows the tire to clear the bolt.
this is crucial to know, because the quick fix is to cut the bolt... but I cringe to think how one would ever replace the control arm ball joint without the hex on that bolt in order to actually remove it
(... Now, I just need to sell my 4 chrome clad caps so I can buy some Pintler +25mm offset rims before my next set of tires!)
dMalice is offline
post #39 of 137 Old 05-26-2012, 11:26 AM
ibeatmywk
2006 WK
retreaded tires
any thoughts on them? a couple buddies have some from tread wright and they love them and havent had any problems. just trying to get some input before i buy tires.
ibeatmywk is offline
post #40 of 137 Old 05-27-2012, 05:37 AM
JeepN4KC
JeepN4KC's Avatar
I think they're pretty reliable. Couple guys in my local Jeep club that have them and haven't had any issues. Only complaint one of the guys has is he wasn't able to choose the sidewall.
~Mike~
WK
XJ
JeepN4KC is offline
post #41 of 137 Old 06-03-2012, 11:52 AM
njhomeowner
Is the "Maximum Deceleration" feature harmful to the transmission?
Hi,
Was reading the Owners manual of my '08 Limited the other day, looking for info on the operation of the "Autostick" as I live in a hilly area and thought it would be good to use these features when climbing and descending hills. I found this passage interesting
"NOTE: To select the proper gear position for maximum deceleration (engine braking), move the shift lever to the left “D(-)” and hold it there. The transmission will shift to the range from which the vehicle can best be slowed down."
After reading, I said wow that's cool - got to try it out and see if it works. Well I was not impressed - in fact I am now mildly paranoid about transmission damage. I was traveling at about 40 on a moderate hill and was in D then proceeded to hold the shifter to the left as instructed. Immediately the "D" changed to a 5 - indicating the gear I was in, then it shot to "1" and the engine jumped to 5,000 RPM - at least. It didn't feel abnormal, per-se, and there was no unusual drive line noise, banging, loss of control, etc. However anyone who has ever driven a strict manual would know never to do something like that, right? So why would the Automatic Trans do that as part of it's programming? Rest assured I will never try that feature again.
I have driven the truck a few times since then and it all seems OK, but this truck is my baby - the best car I ever owned (since the '98 TSI I had with 175K miles) - and I don't want to screw it up - especially when doing something the manual says is OK!
Has anyone tried this and gotten similar results?
Any comments or suggestions would be appreciated.
njhomeowner is offline
post #42 of 137 Old 06-06-2012, 11:01 PM
Anthony92x
2007 WK
I'm pretty sure mine just knocks it into 1st gear. My gf hit it before and it went to first. Didn't like the engine sound for that and I try my best to avoid it.
07 WK 3.7 Bilstein hds, bored TB, K&N filter, RC 1.25in spacers, Kicker audio, Trail lights, 4prong plugs. Cree 7w reverse lights mostly blacked out.
07 WK 3.7, Cree 7w reverse lights, tinted tails, kicker audio, K&N filter,ported TB, RC 1.25in spacers, Bilstein HDS, 4 prong plugs, aux lights, Bedliner'd grill, rear step and rear latch cover.
Anthony92x is offline
post #43 of 137 Old 07-14-2012, 08:04 AM
jeeperjk
2009 JK Wrangler
What's the backspacing on the stock WK/XK wheels? I've got the chrome wheels on the XK and I want to put 265/70-17 tires on and not trim the bolt or use spacers. Anyone have definitive info so I can look for new wheels with appropriate backspacing?
jeeperjk is offline
post #44 of 137 Old 07-14-2012, 08:05 AM
jeeperjk
2009 JK Wrangler
And what's the stock width? Are they 7.5" wide?
jeeperjk is offline
post #45 of 137 Old 07-14-2012, 04:12 PM
jeeperjk
2009 JK Wrangler
After further research, I'm thinkin' they're 6" BS on the stock wheels. I think I'm gonna go with AEV Pintlers and 265/70-17 Falken Rocky Mountain ATS.
Thoughts? Opinions?
jeeperjk is offline
99 WJ 4.7V8 Frequently shuts off while driving?? jjwells21 ZJ Grand Cherokee Forum 8 09-04-2014 03:48 AM
Front End Grinding Noise..I know this has been asked, please look. boosoo ZJ Grand Cherokee Forum 4 07-12-2012 09:16 PM
2000 jeep stalls frequently..... lilreeken ZJ Grand Cherokee Forum 0 02-18-2008 12:41 AM
Another BB Question... (I don't think it has been asked before) BlaineWasHere ZJ Grand Cherokee Forum 2 04-25-2005 08:45 AM
the most asked question... darktiger ZJ Grand Cherokee Forum 4 01-07-2003 09:25 AM
