Found three broken exhaust manifold studs (hemi) - JeepForum.com
post #1 of 7 Old 08-25-2013, 07:41 PM Thread Starter
WieSeL
Found three broken studs today. The ones that hold the shield on the back portion of the manifolds. Looks like I will be pulling those off this week. It looks like a pita on the driver side. Any tips? Not looking forward to this repair
WieSeL is offline
post #2 of 7 Old 08-26-2013, 03:17 PM
90grandoneer
90grandoneer's Avatar
2006 WK
What chassis is this on? To answer your question, yes, let a co-worker do the job. Actually, both sides are a PITA, no matter which chassis you're dealing with. No real secrets, but the biggest problem might be getting the broken studs out. If it's a WK, you might try removing the plastic inner fender well. It doesn't help much, but does a little. Also, moving all the electrical stuff in the engine compartment (FCM and Fuse Panel) gives you a little more room to work. Best to just take your time, and try not to swear too much.
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, K&N Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline
post #3 of 7 Old 08-26-2013, 05:33 PM
giulio17
Yeah your going to go from up too and through the wheel well. It helps alot to get a miniature ratchet. If ur not getting new manifolds have them machined.
giulio17 is offline
post #4 of 7 Old 08-26-2013, 07:36 PM Thread Starter
WieSeL
Wk btw. Don't think they're warped yet. IM not really hearing an exhaust leak yet. Won't hurt to send them off to get milled though. Not looking forward to this one. Have to do my front pinion mount diff bushing also. Probly be a whole days work at the shop, on my day off! Oh well
WieSeL is offline
post #5 of 7 Old 08-26-2013, 07:40 PM Thread Starter
WieSeL
Does removing the steering intermediate shaft help like people mention?
WieSeL is offline
post #6 of 7 Old 08-28-2013, 07:46 AM
Walt
2008 WK
Yes. Tie down the steering wheel first before disconnecting the steering, thereby avoiding possible breakage of the clockspring (another $$$ PITA). Happened to the dealer when they replaced my driver's side exhaust manifold.
If you PM me, I will send you a pdf of the Mitchell's service procedure for changing the exhaust manifold on the WK. [Can't get it to load into this response.]
__________________________________________________ _______
"My Grand Cherokee isn't getting older...it's getting newer part-by-part."
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is online now
post #7 of 7 Old 08-28-2013, 08:18 AM Thread Starter
WieSeL
Thanks. Alldata, I mean Nodata that I have at work doesn't say much of anything. Think IM gona do the passenger side today and driver next week. Now is the I-shaft splined or can it only go on one way?
WieSeL is offline
