Found this spliced wire under the hood, what is it for? - Diesel WK - JeepForum.com
post #1 of 22 Old 06-08-2012, 04:46 PM Thread Starter
r_unda
About two month ago I bought this 07 WK diesel. I was looking under the hood today and found this cut wire. Anyone knows for what it is for? Anyone has a WK diesel wire diagram?
Everything looks like it is working fine but would like to know what it is for.
Thanks!
My Jeep isn't getting older, it's getting newer part by part
2011 WK2 HEMI 4x4 Overland
2007 WK CRD 4x4 Limited GDE Tuned
1998 TJ SE
1973 CJ5 - YJ OME 2.5" lift, 33" tires
1951 Willys truck
r_unda is offline
post #2 of 22 Old 06-08-2012, 05:47 PM
TurboDiesel
2008 WK
hmmm thats weird
no idea what it would be for
doesnt even look like there is enough slack to make it tight lol
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline
post #3 of 22 Old 06-08-2012, 06:06 PM
terrasmak
2007 WK
Test lead and hook it up
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
terrasmak is offline
post #4 of 22 Old 06-08-2012, 06:14 PM
nostaw22
Call a dealer and ask... They may be able/willing to print you out a diagram if you visit the dealership.
JW
1998 XJ - built for offroading
2007 WK CRD - DashHawk, for towing the XJ
nostaw22 is offline
post #5 of 22 Old 06-08-2012, 07:15 PM
terrasmak
2007 WK
On mine, it is connected. Hook a test lead to it and see what happens
post #6 of 22 Old 06-08-2012, 08:03 PM
Tango.
2008 WK
That is the FCM front-control-module and there was some kind of a recall for them. Maybe the recall was cut the purple wire?
I would NOT hook it back up if it was my vehicle. I would cap the wire off.
I do have the WK diesel wire diagrams. The wire diagrams don't help much as in "what is this wire for".... the are more geared toward "how is this wired" so you can look up a part and see how it is wired. So you might have to look at half the wire diagrams before you got to that wire.
PM me if you are interested in the diagrams.
Tango. is offline
post #7 of 22 Old 06-08-2012, 08:04 PM
suzieque
2008 WK
it seems "VT/WT" color combo is used in many places on the vehicle. can you count the total wires on that plug? is it 16 total wires?
couple options are:
1) passenger door ajar light/switch - try driving away with the passenger side door slightly open, should be some light on the dash that says its open
2) transfer case neutral light - have a look at your manual and figure out how to change the transfer case in neutral, I've never had a need to do this, but I believe a light comes on near the handle.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #8 of 22 Old 06-08-2012, 09:05 PM
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
Mine is not cut.
Best I can do is it's connector C104, that looks like position 7 Circuit G6 20VT/GY (Diesel) Oil Pressure Sensor Signal
07 Steel Blue Overland CRD QDII | Bilsteins | 4xguard Matrix | Rear SRT8 SwayBar | DashHawk w/egt | Provent MBRP XP Exhaust | New Intake Tube & Seal + EHM | Alternator Splash Guard | Crank Sensor | GPS AL InMotion Hack | Swirl motor bypass | Blue WK Club Member #13 | 200,000 Mile Club | Dogpiled Club | pre-N23 FDCM |
89 GW w/plow
wookiee is offline
post #9 of 22 Old 06-08-2012, 10:01 PM
Tango.
2008 WK
wookie has it ...
G6 20VT/GY OIL PRESSURE SENSOR SIGNAL
Tango. is offline
post #10 of 22 Old 06-08-2012, 11:38 PM
suzieque
2008 WK
Is violet with a white stripe? Or is it violet with a grey stripe? Looks violet with white stripe to me. Certainly don't want the oil pressure sending unit cut.
suzieque is offline
post #11 of 22 Old 06-08-2012, 11:49 PM Thread Starter
r_unda
Originally Posted by TangoTango View Post
wookie has it ...
Everything makes sense now.
Long story sorry guys.
Back when I just purchased the WK I had the oil pressure light coming on, I took it to back to the dealer. The WK was there for about 3 weeks and they could not fix the problem. I took the jeep home (they said I could drive it without a problem). I was doing the oil change and noticed that the oil filter cap was broken (The tapered extension and O-ring boss wasn't there). When to the dealer got a new cap and this fixed the problem. You can read about it here: http://www.jeepforum.com/forum/f67/c...07/index3.html
While I was doing the oil change I looked around the engine and noticed that the oil pressure sensor wires were spliced into the wires that are going directly to the computer under the battery. I didn’t think much about it then since I was excited that I fixed the problem by replacing the cap and I was able to finally drive my WK plus the sensor was still working (it was still sending the low pressure signal with the broken cap).
Anyways, I wonder what they bypassed, should I be worry? Everything looks to be working fine.
The shop that worked on it for the oil pressure light was Love Jeep Pre-owned in Corpus Christi. So if you have a Diesel near the Corpus Christi Area don’t take it there. The guys up front are really nice and helpful but I guess their tech don’t know how to work on the diesel WK.
1998 TJ SE
1951 Willys truck
r_unda is offline
post #12 of 22 Old 06-09-2012, 09:38 AM Thread Starter
r_unda
It is violet with a grey stripe
1998 TJ SE
1951 Willys truck
r_unda is offline
post #13 of 22 Old 06-09-2012, 09:51 AM Thread Starter
r_unda
Here is what I was talking about. I removed the battery to take a better look at the wires.
Here is the violet with gray wire. One of the oil pressure sensor wires is connected to the violet with gray wire going in to the computer with some type of resistor.
And here are other two spliced wires. One is gray with pink stripe and the other one is bright green. The remaining two wires from the oil pressure sensor are connected to them going into the computer.
I guess they thought that there was something wrong with the oil pressure sensor wire loom. Not crazy but I would have tried other things before starting to cut wires! Maybe like changing the oil and filter!! He would have noticed the broken cap!!
1998 TJ SE
1951 Willys truck
r_unda is offline
post #14 of 22 Old 06-09-2012, 07:25 PM
p3busman
Would have been nice if they would have used heat shrink splice connectors, to help keep moisture away from the wire.
p3busman is offline
post #15 of 22 Old 06-09-2012, 08:14 PM
SSF556
2008 WK
I would be a little pissed if a Jeep dealer did splicing in my Jeep....
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
found something sligtly leaking under my hood Taul_Paul WK Grand Cherokee & XK Commander Forum 2 04-04-2012 06:05 PM
Extra Wire Found By Oil Pan YB Normyl WK Grand Cherokee & XK Commander Forum 5 04-26-2011 02:01 PM
WK Diesel: I found the proper oil cheap! 2007GrandDiesel WK Grand Cherokee & XK Commander Forum 14 01-19-2009 06:12 PM
what is this i found under my hood? steve L. ZJ Grand Cherokee Forum 11 11-04-2008 07:43 PM
what is this disconnected wire under my hood? MEinSoCal ZJ Grand Cherokee Forum 27 08-03-2008 09:49 AM
