Fluids and spark plugs - JeepForum.com
post #1 of 6 Old 06-19-2013, 09:59 PM Thread Starter
BoraBora
2015 JK Wrangler
I bought my Jeep used with 74k miles on it, and I'm now at 76k and have noticed a few things:
A) It takes a little effort to start up, spark plugs?
B) It occasionally shifts gears rough, usually when I pull my foot off the gas and I'm coasting and it down shifts
C) It's a dog when going up even the slightest hill and I really have to push it hard
D) The gas mileage is terrible! It's a 3.7 and I'm getting 12.5 in the city and 16 on the highway....and I'm not driving it hard, I'm very easy on the gas
I figure I might as well go and get everything serviced at once, such as the fluids and spark plugs and so on...however can anyone give me some pointers? I don't think the spark plugs have ever been replaced and I read that the rough gear shifting could be a sign to replace the transmission fluid? I was thinking of SeaFoaming it before taking it into get the Oil changed, however I've never really worked on a car (I'm 16) and my dad is currently deployed so I can't ask for his help. It's just me.
'15 JK 2.5" lift on 35's
'06 WK 3.5" lift on 33's (Sold)
BoraBora is offline
post #2 of 6 Old 06-19-2013, 10:32 PM
Jeepforthewin
2010 JK Wrangler
Did the seller give you any maintenance records of any sort when you bought it? If not and you think the spark plugs are still the original It wouldn't hurt to go ahead and swap them out. I just swapped mine out last weekend and I can feel a big difference, I have the hemi but you should still see a nice difference if they are the original plugs!
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #3 of 6 Old 06-19-2013, 10:34 PM
Jeepforthewin
2010 JK Wrangler
Also I would check the fluids too. If you didn't get any maintenance records they may not have even done the 60k mile service
post #4 of 6 Old 06-19-2013, 10:49 PM Thread Starter
BoraBora
2015 JK Wrangler
Yeah I didn't get any of the service records, I'm thinking I should just go ahead and get all the fluids done at once, after I go out and check them tomorrow morning. Would the fluids explain the rough downshifting from 2nd to 1st gear when my foots off the gas?
BoraBora is offline
post #5 of 6 Old 06-19-2013, 11:42 PM
JRLT
2010 WK
Did my fluids at 48k and they werent bad but it was a piece of mind thing for me.
Reset your MPG on your EVID cause its probably estimating from factory and not your driving habits.
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
post #6 of 6 Old 06-20-2013, 06:18 AM
caulk04
2008 WK
Reset the avg mileage every time you fill up.
I've found that ours reads no more than .2 (yes POINT2) MPG higher than actual mileage. Whether I'm getting 10.8 towing in the hills, 15.5 average driving or 18.2 all highway, it's basically dead on. If you let it figure an average for ever, it won't be accurate. Reset each time.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
