Floor jack question. - JeepForum.com
post #1 of 7 Old 08-15-2013, 03:52 PM Thread Starter
slayerized6
I actually feel pretty stupid for asking this question.... I have a 2 ton floor jack. I just recently bought an 08 WK (4738 lbs). Should I be fine with this jack?
2008 Grand Cherokee (WK)- 5.7l HEMI. OME HD Lift, Superchips Tune w/ ATT, aFe Intake, Flowmaster 44
slayerized6 is offline
post #2 of 7 Old 08-15-2013, 03:59 PM
Siva283
Yes since it only lifts 25 percent of the jeeps weight when used as intended and 50 percent if tou jacl an entire end up
Sent from my SPH-L300 using JeepForum
Ask me how I know...
Siva283 is offline
post #3 of 7 Old 08-15-2013, 04:25 PM
Walt
2008 WK
I routinely use this capacity for one wheel on my '08 WK.
Only thing to watch is not positioning yourself under the load with a hydraulic jack. They have a nasty tendency to leak slowly when you are not watching.
If you are doing extended work, I recommend a jackstand as a precaution.
HEMI CLUB MEMBER #45; SILVER WK CLUB MEMBER #13
'08 WK GC Limited. 5.7L HEMI. Quadra-Trac II. Bright Silver Metallic. Class IV hitch.
Michelin LTX M/S tires. Fumoto oil drain valve. Billet Technology oil catch can.
Walt is offline
post #4 of 7 Old 08-15-2013, 05:21 PM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
You will be fine - the real limiting factor will be how tall the jack will go. Cause once you lift it that's something to consider. ;-)
Seriously though, a 2ton jack will work well for you and Walt is right - always use jackstands when you do anything outside of maybe tire rotations.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #5 of 7 Old 08-15-2013, 05:27 PM Thread Starter
slayerized6
Thats what I thought. I felt like my jack hesitated a little before, but it felt better once I changed the jacking location (my driveway is also not the best)
I got more than enough jackstands. I will probably end up having to buy new ones once I lift the Jeep
Has a 24'' max lift. I could probably throw a few blocks of wood on it too and get more out of it it need be.
post #6 of 7 Old 05-28-2014, 02:58 PM
fairway551
2006 WK
If I want to use the floor jack to lift one side of the Jeep and rotate the tires, where do you suggest that I place the jack?
fairway551 is offline
post #7 of 7 Old 05-28-2014, 03:05 PM
JeepN4KC
JeepN4KC's Avatar
^^^ I put my floor jack right under where the crossmember bolts to the unirail on the side I'm rotating. Front to back ---> back to front. Switch sides - same thing. Put 3 lugs on the rears. Put the jack under the pumpkin --------swap rear driver/passenger sides. Put the Jeep on the ground, torque the lugs, done. Takes maybe 30 minutes with a good floor jack, impact, and torque wrench.
~Mike~
WK
XJ
JeepN4KC is offline
