Fixing Damaged Caliper Help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Fixing Damaged Caliper Help
Savvy/Currie Aluminum Control ArmsIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAlloy usa heavy duty ball joint kits
Unread 06-26-2014, 03:14 PM   #1
jbarrett
Getting some serious brake noise. Replaced rotors, pads, still noise. Need to check my dust shields for being bent - but this weekend I had the pads off and I noticed on 2 of the calipers, several of the pistons were damaged. On the face of the piston that touches the brake pad, there are "chunks" missing. I have no idea if this would cause noise, but I'm assuming it should be fixed. I understand I can just replace the pistons and seals without replacing the entire caliper assembly. Can anyone explain how that is done? Thanks.
jbarrett is offline   Reply With Quote Quick reply to this message
Unread 06-26-2014, 03:38 PM   #2
caddydaddy
2007 WK
You can search google or you tube on how to rebuild calipers and replace the pistons. It might just be cheaper to buy rebuilt calipers though.
2007 CRD Grand Cherokee Limited 4x4
GDE ECO Tune, Turbo Resonator Delete, EHM
169,000+ miles!
caddydaddy is offline   Reply With Quote Quick reply to this message
Unread 06-26-2014, 03:40 PM   #3
jbarrett
Yea I see that now. Looks like the caliper assemblies are like $30 (after core) from rockauto. But the pistons are only $9. Hmmm....
Unread 06-27-2014, 09:53 AM   #4
bersh
2008 WK
I've been down that road before and for the few extra bucks it's worth just replacing the caliper. You could try some high temp silicone on the piston faces as that can help.
bersh is offline   Reply With Quote Quick reply to this message
