First time doing oil change on a 08 CDI - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > First time doing oil change on a 08 CDI
TeraFlex Now at Rockridge 4WD! BEST DEALS around!Why Buy Brakes From 1A Auto?ZONE 4.25" combo lift for TJ available at Rockridge4w
Unread 01-24-2015, 09:40 PM   #1
MarvinTm
2008 WK
it was not as bad as i first thought. had a few hiccups but easy fixes.
the funnest thing i found was i got the oil and filter right from the Mercedes dealer in town and it was way cheaper then everyone else "who" carried the right oil.
will be saving myself at least $100 every time
MarvinTm is offline   Reply With Quote Quick reply to this message
Unread 01-25-2015, 07:43 AM   #2
caddydaddy
2007 WK
Nice! It's not too hard as long as you know the correct procedure.
2007 CRD Grand Cherokee Limited 4x4
GDE ECO Tune, Turbo Resonator Delete, EHM
169,000+ miles!
caddydaddy is offline   Reply With Quote Quick reply to this message
Unread 01-26-2015, 09:47 PM   #3
ggrassmid
I do mine myself also. I use Amsoil: changed filter at 7500 miles, and will change oil/filter at 15,000 miles. I have also gotten the oil tested at the 7500 mile mark after purchasing my GC. My next oil analysis will be with brand new untouch Amsoil oil along with my 15,000 mile oil and see what it looks like and if I should change to 5,000/10,000 intervals.
Good luck!
Black 2008 Limited CRD
Currently stock with EHM
JF Black WK Club #168
ggrassmid is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 05:37 PM   #4
TangoTango
2008 WK
how do you get your oil tested?
Black WK Club #147
TangoTango is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 06:38 PM   #5
pawwright
blackstone - they'll send you the bottle and such. Very cheap, overall. I can't remember the price but somewhere around $20.00?? I think..
pawwright is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 07:08 PM   #6
ggrassmid
yes, Blackstone in Indiana. Cost $20-$30. I think I paid the $30 to get something extra tested. They do give you recommendations on change intervals also. I attached mine. I changed my oil to Amsoil right after I bought it. This analysis is after 7500 miles on that oil when I only changed the filter. At 15,000 I will change oil and filter, get tested for the 15k oil and also send in a sample of clean unused Amsoil. You will see that made a note about the viscosity, but looking up Amsoil's specs, the viscosity is in range to that. Conveniently attached for your review.
Blackstone Test Price
Last edited by ggrassmid; Yesterday at 10:26 PM.. Reason: Removed PDF that was corrupted
Unread Yesterday, 10:12 PM   #7
TangoTango
2008 WK
thanks,
the 2nd document doesn't open up though.
i know the truckers look at these.. but I really don't know how to read them. Like your oil is low on calcium what does that mean? .. or the main issue to me is how do I tell when I will need to change it out?
do you take (2) readings then use that as a base line?
Black WK Club #147
Unread Yesterday, 10:25 PM   #8
ggrassmid
Sorry, not sure how/why the pdf got corrupted (removed now). You can look it up on Amsoil site. I use the European Low SAPS formula, which has the correct Merc spec oil.
Yes, this posted reading would be my baseline; though technically I should have had the new oil tested as clean baseline and then have my dirty oil tested. Since I did not think of that first, I will be having that added to my tests the next samples I send in. That way I have a baseline of unused new oil compared to what happened after running 7500 & 15000 miles on it. Then if I need/want to adjust to 5/10k I can do that.
The silicon in my sample is high compared to averages, which does make sense a little has I did do some offroading with my jeep and one day included sand dunes here in Michigan. Amoils data sheet doesn't show all the particulate data, so their oil could have a bit higher silicon in it than convention also. Hence the clean new oil baseline I need to get. Blackstone made a note of the viscosity, but looking at Amsoil's data sheet, I am on target. So it will be interesting to see a clean unused sample data compared to used oil on this.
I dont want to open up a quart to take the sample out and not use the oil until later, that is why I am waiting till my next oil change.
