Finally... a 12 Bolt Differential Cover. - Page 2 - JeepForum.com
post #16 of 96 Old 12-21-2013, 10:52 AM
MC_wk
2007 WK
Originally Posted by Blown7 View Post
Here from WKJEEPS
3.07:1 axle ratio (with V6 and Quadra-Trac I)
3.55:1 axle ratio (with V6 and Quadra-Trac II)
3.73:1 axle ratio (Dana 44, with V8 and CRD engines)
The last one is what I'm talkin about..A 8.9 inch ring gear Dana 44
I'm confused now. Do we have a variation of the Chryco 8.25, or is it a variation of the D44?
07 WK CRD | QD2 | GDE ECO - DPF | OME HD | Moabs & Duratracs
98 XJ | FbG | Moabs & Duratracs
96 XJ
MC_wk is offline
post #17 of 96 Old 12-21-2013, 10:59 AM
caulk04
2008 WK
The SRT8 and possibly the CRD use a D44 variant. The vast majority of these Jeeps (3.7, 4.7 and Hemi) use the C213R(E) axle.
The 213 refers to 213mm ring gear. Actually measures 8.38.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #18 of 96 Old 12-21-2013, 11:17 AM
Blown7
There ya go!
Blown7 is offline
post #19 of 96 Old 12-21-2013, 11:37 AM
ca07wk
2007 WK
There reason the covers price is high is due to the setup and mold costs. No company makes or has any interest in making a 12bolt diff cover except the Steel Armadillo, if I had a 12bolt I would be all over this.
Crawl-Offroad.com-Boycott Paved Roads
2006 WK Limited Modified QT2
OME HD/RRO UCA/Wrangler MTRs on Moabs/JKS Rear Discos/Steel Armadillo Skids, Sliders,Front Shackles,Antenna Mount/Crawl Rear Skid
ca07wk is offline
post #20 of 96 Old 12-21-2013, 01:46 PM
caulk04
2008 WK
Come to think of it, the crd can't use the d44 exclusively. Maybe it was the 2wd models that use it.
Either way, the c213r and it's re version are the common axle.
caulk04 is offline
post #21 of 96 Old 12-21-2013, 02:36 PM
MC_wk
2007 WK
275 is SUPER pricey. When I still lived on the West coast a local 4x4/fab shop said they could make one for half that cost.
Bingo. I remember reading that a number of months back.
96 XJ
MC_wk is offline
post #22 of 96 Old 12-21-2013, 03:02 PM
Blown7
Poision spyder has the Big Dana 44 covered, just use the JK cover
http://shop.poisonspyder.com/Dana-44.../42-10-044.htm
89 bucks
Blown7 is offline
post #23 of 96 Old 12-21-2013, 03:54 PM
BAH101
2008 WK
Poision spyder has the Big Dana 44 covered, just use the JK cover http://shop.poisonspyder.com/Dana-44.../42-10-044.htm 89 bucks
Wrong bolt pattern...its also missing two bolts.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #24 of 96 Old 12-21-2013, 04:17 PM Thread Starter
PeoriaXK
2006 XK Commander
89 bucks
Again... Nobody makes a 12 bolt.... Nobody!
PeoriaXK is offline
post #25 of 96 Old 12-21-2013, 04:18 PM
Blown7
Ya you and your 12 bolt...
Blown7 is offline
post #26 of 96 Old 12-21-2013, 08:40 PM
Jeepforthewin
2010 JK Wrangler
Actually 4xguard does......
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #27 of 96 Old 12-21-2013, 08:44 PM
sk1er18
2007 XK Commander
That's a guard, not a replacement cover.
-Matt
sk1er18 is offline
post #28 of 96 Old 12-21-2013, 10:29 PM
Valpacer
2007 WK
44's are not on the CRD's.
the 12 bolt 8.25 (c213re is correct, e standing for ELSD) is unique to our platform, hence nil aftermarket support except for Steel armadillo in this case.
ALL QD2 vehicles have the c123re diff.
2007 WH Grand Cherokee CRD (Yup, RHD Australia)- 3" Exhaust, GDE Flash Tune, CRDSTU/SL Hybrid Lift & bash Plates, 4xGuard Rock Rails, Saguaro F & R Bars, RCV's, Warn 9.5cti-s, AEV Saverge Rims, Nitto Mud Grapplers, Snorkel, Custom Rear Drawers, On Board Air, BullyDog Monitor, Dual Batteries -
Valpacer is offline
post #29 of 96 Old 12-21-2013, 11:41 PM
atarijedi
2008 WK
As I understand it, from the Service Manual and from a few sources online, it goes like this.
The 2007-2008 CRD has a Chrysler 7.9" IFS front, and a Chrysler 8.25" solid rear, both are 3.73 ratio. They are sometimes called "Corporate" instead of "Chrysler".
Front diff is either C200F for QT1/2, or C200FE for QD2. Rear is C213R for QT1/2 or C213RE for QD2.
The 200 and 213 are ring diameter, 200mm (7.87", sometimes referred to as 7.9") and 209.5mm (8.25") respectively. Yeah, I know, 209.5mm when its called C213R. But that is what the service manual says.
As for the number of bolts for the differential covers, I believe it is 10 on the front, I am not sure as I haven't seen it. But it is 10 on the back.
atarijedi is offline
post #30 of 96 Old 12-22-2013, 04:34 AM
Valpacer
2007 WK
10 bolt rear cover on the c213r , same as any 8.25 diff cover.
12 bolt rear cover on the c213re, QD2 ELSD equipped vehicles.
The F and R in the part numbers just refer to front and rear differential packages.
Front is not an issue, nor requires aftermarket as its protected under the subframe. And has a mount bolted to the front of it....
Valpacer is offline
