filter magnet - JeepForum.com
post #1 of 11 Old 11-26-2013, 11:49 PM Thread Starter
94jeepman
2005 WK
filter magnet
I was on summitracing.com and I saw this filter magnet. http://www.summitracing.com/parts/ft...view/make/jeep
My guys is it sticks on to the filter and magnetize it to keep metal from going back into the motor. Any body else know what it actually does?
94jeepman is offline
post #2 of 11 Old 11-27-2013, 12:00 AM
JRLT
2010 WK
Basically, that's all they are supposed to do. There are cheaper ones out there.
2010 3.7L, 4XGuard Matrix, Fastman TB, TB Ground Mod, Injen CAI, 255/60/18 Nitto Terra Grapplers, Bilstein Shocks & Struts, Cruiser Alloy Wheels - Switchblade, Stillen Brakes, Cargo Light Strip Mod, Electric Ashtray Mod, Jet-powered, Monkey Navigated...
JRLT is offline
post #3 of 11 Old 11-27-2013, 12:09 AM
colinzj
2006 WK
Separates you from $54.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline
post #4 of 11 Old 11-27-2013, 04:02 AM
atarijedi
2008 WK
It collects metallic particles that are ferromagnetic, like steel. That is all it does.
Not really worth it though. This guy made his own version using strong NeFdB magnets, and after 8000km it didn't seem to catch much.
atarijedi is offline
post #5 of 11 Old 11-27-2013, 08:29 AM
fishinbama
2007 WK
The best place to get disposable neodymium magnets is out of old hard drives. Take them apart and you will find a very strong magnet.
2007 limited crd 2wd, 3.07 ratio, GDE eco tune, dpf delete, tnadanzig resonator delete
fishinbama is offline
post #6 of 11 Old 11-27-2013, 09:02 AM
james_2k
2003 WJ
+1
i took apart a hard drive and got myself 4 strong magnets which i put on the oil pans of my cars, around the drain plug (2 each)
james_2k is offline
post #7 of 11 Old 11-27-2013, 11:29 AM
imnotted
2007 WK
If you're worried about a significant amount of metal in your engine oil, you may have far greater problems that a magnet won't solve. I don't use magnets on my engines; a little bit of benign metal isn't going to hurt. If it is big enough to damage my engine, then it probably came from a spun bearing, in which case I'm looking at a rebuild anyway. I've been told by a master ASE mechanic friend of mine that they're kind of pointless on auto transmissions, too. He seems to believe leaving that metal in the system actually helps the clutch packs engage and slows down their wear. I'm not sure I agree with that, and I still drain and clean my magnet on a fluid change (though I do follow my own, extended change interval). But the theory is there, so take it for what it's worth. I look at Sprinter vans, which use the same NAG1 as my CRD (basically a 722.6/W5A580), and I know they're not getting changed as often as they should; they still manage to go about 200k miles between rebuilds. It's a finicky transmission when it comes to fluid levels, but it's far more resilient than people give it credit. I've seen them go 100k miles between changes without extra magnets and without issues (see: every MB that shipped with a 722.6 that Mercedes said was "filled for life").
07 WK CRD QDII
10 Sierra 1500 Z71
97 Civic Beater Edition
imnotted is offline
post #8 of 11 Old 11-27-2013, 04:13 PM Thread Starter
94jeepman
2005 WK
I was just curious what it did never saw one before
post #9 of 11 Old 11-27-2013, 05:25 PM
suzieque
2008 WK
cool vid. I bought a magnet off of ebay, I've never cut a filter open to see what it catches. Seemed like simple insurance to me.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #10 of 11 Old 11-28-2013, 11:57 PM
fishinbama
2007 WK
Magnetic oil drain plugs are stock on some vehicles and are included in many differentials as well as most transmissions. There must be some benefit for a cost-cutting manufacturer to spend the extra dimes.
post #11 of 11 Old 11-29-2013, 06:08 AM
tjkj2002
2002 KJ Liberty
Never seen one on a auto trans but are pretty standard on manual trans.If you notice diffs and manual trans do not have oil filters,hence the magnet of the drain plug.
tjkj2002 is offline
