Fender Liner Retainers - JeepForum.com
post #1 of 10 Old 04-06-2016, 07:42 PM Thread Starter
2007laredowk
2006 WK
Looking at the fender liners I noticed some retainers missing and others broken or close to be broken. After some searching I found different types of retainers that all said are the part needed for the liner but, looking in the liner I see other type of retainers that I don't see listed as the part needed, so that left me a little confused about which ones I need and where. I'll post some pictures of the ones I found and see if someone knows where they go or are they even used. I'm also looking for the plastic retainer that goes on the back of the wheel holding the liner to the body near the stabilizer bar and the white retainer that holds the bumper to the fender using a metal screw. Any help appreciated. Thanks.
2007laredowk is offline
post #2 of 10 Old 04-06-2016, 08:14 PM Thread Starter
2007laredowk
2006 WK
There were four images, something happened to the other two. I'll try to upload them in this reply.
post #3 of 10 Old 04-06-2016, 08:19 PM Thread Starter
2007laredowk
2006 WK
Something is happening to those two pictures, they don't appear when I log off. Re upload in this reply. Let's see if these ones work.
post #4 of 10 Old 04-06-2016, 08:28 PM Thread Starter
2007laredowk
2006 WK
Don't know what's going on, again I will post the last image that was supposed to be at the thread start. If it doesn't appear it's called the plastic rivet, a quick search will show which ones they are.
post #5 of 10 Old 04-06-2016, 10:45 PM
Curt0306
The long thin one is the original one that came stock, but in theory, they will all work. You also don't need a rivet gun if u don't have one. I used 2 needle nose pliers to apply mine. One to pull the rivet, the second to hold it in place while I pulled.
2008 WK QTII 4.7 with OME HD, 285/70/17 BFG KO2, K&N CAI
Curt0306 is offline
post #6 of 10 Old 04-07-2016, 07:30 AM
boxboy5371
2015 BU Renegade
If you have a harbor freight tools down by you, you can buy a plastic rivet gun tool fairly cheap.
the other ones i went to Napa to try and find them and had a hard time.
I just opted to get the rivet gun and rivets, so far no issues and it looks as food as new.
boxboy5371 is offline
post #7 of 10 Old 04-07-2016, 11:38 AM
road_tripper
if you search for - 1/4" Nylon Blind Rivets - on ebay, you'll get a lot of hits. about $7-$8 for 25.
road_tripper is offline
post #8 of 10 Old 04-07-2016, 02:41 PM
Montreal300
Montreal300's Avatar
All of the retainer pins you show are from various FCA products. The first three in Post #1, for example, are used in the LX platform to keep the front facia in place and in the trunk to retain carpeting.
Montreal300 is offline
post #9 of 10 Old 04-07-2016, 02:53 PM Thread Starter
2007laredowk
2006 WK
Looks like I'm going for the last ones to keep the factory look. The ones that I'm still looking for are located behind the wheel near the stabilizer bar, it's a black plastic retainer that kind of looks like a screw but with a rounded head instead of an hexagonal one and the square white plastic one that uses a metal screw to hold the end of the bumper to the fender near the wheels. I'll post pictures to get an idea. The picture for the black plastic one is from a 2012 SRT WK2 and I need the ones for a '06 WK but it's just to show the location since it's very close, the bad crop is for the picture to show up.
grand cherokee wheel well retainer.jpg   Jeep-Grand_Cherokee_5.7_Limited_2005_1600x1200_wallpaper_04.jpg
post #10 of 10 Old 04-07-2016, 02:54 PM Thread Starter
2007laredowk
2006 WK
Ignore the yellow arrow in the first picture, the white ones are the ones indicating what I'm talking about.
fender , liner , retainer , screws
