Factory navigation screen blank - JeepForum.com
post #1 of 7 Old 04-20-2013, 01:01 AM Thread Starter
whitetj0525
Yesterday I began having a problem with my wife's 2006 GC limited. It has the stock nav unit installed. The unit will not come on(only comes on to eject a disk), not play any music and no buttons will work except for the disk eject. Any help would be apperciated. Also I already tried disconnecting the battery.
whitetj0525 is offline
post #2 of 7 Old 04-20-2013, 06:27 PM
WmassWK
2006 WK
Mine completely crapped out 3 weeks ago. After it heated up the screen would die and the right side and bottom buttons would not work. The radio did play but only the presets would function. I managed to get the discs out out and ordered a used one from ebay. I got the used one in like new condition for cheaper than going aftermarket. The original was then brought to the range to help ease my nerves through proper therapy. I did save the nav disc.
WmassWK is offline
post #3 of 7 Old 04-21-2013, 06:48 AM
darot
your looking at 4 to 500 to replace with a reman one, hardly worth the money. Just junk it and get an aftermarket (cruchfield). Its a bummer loosing the factory phone but I got over it. I got the sony all touch screen. I would get one that has knobs for radio, the touch is a pain for the radio. I do love the tom tom nav though.
BTW i went through 2 factory nav radios, trust me and just junk it.
darot is offline
post #4 of 7 Old 04-22-2013, 05:02 AM Thread Starter
whitetj0525
Well I would like to get an after-market unit, but my wife doesn't want to lose the ability to play the rear DVD sound for my kids. So it looks like I will have to replace the factory one. Does anyone know of a good site I can get one for cheap? Also is there any newer chrysler units the will let me retain the ability to have the DVD volume play through my speakers?
Thanks for the input,
Mike
post #5 of 7 Old 04-24-2013, 09:37 AM
stpmnwkjeep
2005 WK
Mike
If you get an aftermarket one like I did the rear DVD will still work with the headphones. If you don't have a set you can pick them up on eBay for around $50. Plus then you can listen to whatever you want and the kids can hear their program -a win win!
stpmnwkjeep is offline
post #6 of 7 Old 11-29-2013, 02:00 PM
kielg
2005 WK
Fixed same issue
I recently had the same issue in my 2005 WK Limited with the factory REC navigation screen only working in the cold and then powering down the screen leaving only the radio preset buttons working. I was able to remove the stereo and take the face off, remove the control board and resolder the resistors below the video controller on the backside and use alcohol to clean all the grounding pads. 1 week so far and the screen hasn't failed yet so hopefully this is the fix.
kielg is offline
post #7 of 7 Old 11-29-2013, 06:25 PM
94jeepman
2005 WK
They are crap you'd be better off going out and buying one that you like for $300+ depending on what you would go with. I have read somewhere on what might fix it but it requires good soldering
94jeepman is offline
