EZ Tire deflator and TPMS stems - JeepForum.com
post #1 of 6 Old 01-21-2013, 10:15 AM Thread Starter
Scottso699
2006 WK
Hi Guys - I am planning to take a trip to Rausch Creek soon and for the first time use a jeep that has a TPMS - can you use an ez deflator on the valve stems of a TPMS equipped tire? I have the Currie EZ Tire Deflator (http://www.currieenterprises.com/ces...9.aspx?id=1236)
but don't want to break a valve stem by a "yeah I should have known better" scenario.
Scott
2006 WK Overland, OME HD Springs F&R, Bilstein 4600 Struts, 1.5" Rear Spacer, 265/70/r17 BFGs
Scottso699 is offline
post #2 of 6 Old 01-21-2013, 02:34 PM
DieselDevotion
2007 WK
It won't hurt your sensors
07 Grand Cherokee Limited 3.0L CRD QDII
89 5.9 Cummins powered F350
98 TDI Jetta
DieselDevotion is offline
post #3 of 6 Old 01-21-2013, 03:18 PM
goldcrown4
2005 WK
It probably won't hurt the sensors, but you may feel the need to pound your fist on the dash a few hundred times as the tire pressure changes, depending on how much change is required before the dang audible kicks in reminding you like every 15 seconds (that is, if your stereo is on). [I just had three sensors replaced including the spare but the spare reports "low pressure" way too frequently. I need to have the spare checked out obviously.]
goldcrown4 is offline
post #4 of 6 Old 01-21-2013, 08:58 PM Thread Starter
Scottso699
2006 WK
Ah ha! I have a solution for that - I have a superchips tuner to turn off the TPMS!
Scott
post #5 of 6 Old 01-22-2013, 12:44 PM
goldcrown4
2005 WK
How much is something like that?
post #6 of 6 Old 01-22-2013, 04:51 PM Thread Starter
Scottso699
2006 WK
The superships tuners usually go for $340 new.
Scott
