Exhaust leak? should I worry? - JeepForum.com
post #1 of 9 Old 12-27-2013, 10:32 AM Thread Starter
Whit
1950 CJ3A
Started up the WK on this cold California morning... I know, 32deg isnt that cold. Noticed quite a bit of water dripping from the muffler. If water drips, wouldn't exhaust drip too? Should I replace the muffler?
btw, I have the 3.7l
1950 Willys CJ3A, all stock except 33" BFG M/T
2011 black WK2, 5.7L Hemi
Whit is offline
post #2 of 9 Old 12-27-2013, 12:21 PM
dorelse
I miss Pleasanton. Worked at the PeopleSoft HQ on Hacienda Blvd (Now Oracle & Kaiser buildings) back in the late 90's & early 00's.
Are you sure you're not just noticing normal condensation in muffler forming when you start up & run the Jeep? In colder climates, that's perfectly normal and seen on practically every car here.
dorelse is offline
post #3 of 9 Old 12-27-2013, 12:26 PM Thread Starter
Whit
1950 CJ3A
I suppose it could be condensation but wouldn't that come out the tailpipe instead of a muffler seam?
Whit is offline
post #4 of 9 Old 12-27-2013, 12:34 PM
Jeepforthewin
2010 JK Wrangler
If it's coming out of a muffler seam it shouldn't be, I thought condensation at first but didn't realize it was literally coming our of the muffler and not the tail pipe.
2010 JKU - Stock for now
2005 WK - 6" lift, 35" BFG's, a lot more (SOLD)
Jeepforthewin is offline
post #5 of 9 Old 12-27-2013, 12:45 PM
dorelse
Yep, me either...I didn't pick up you were specifying the muffler seam.
dorelse is offline
post #6 of 9 Old 12-27-2013, 12:53 PM
dorelse
You know, I've seen them drip from seams, here, but, we don't do smog emissions testing in the Midwest...I suppose you could see if it still passes CA smog emissions. My hunch is that the colder weather has given you a visual of something that's been there since it came off the production line and isn't an issue. (Notice I said it was a hunch.)
dorelse is offline
post #7 of 9 Old 12-27-2013, 01:40 PM
mykdee311
2005 WK
if it doesn't make any noise, and still passes emissions. don't worry about it
05 WK Limited, QDII, Hemi, Superchip, OME HD Lift, JBA UCA & disconnects, 4xGuard (Belly, Sliders, Rear Sliders, Diff), 255/75R17 on Moab's w/ 1.5" Spacer, Thule M.O.A.B. Basket
03 3500 Cummins, 79 Mustang 2.5T Stroker, 63 F250 428 4x4
mykdee311 is offline
post #8 of 9 Old 12-27-2013, 01:58 PM
970001zj
there may be little holes in the muffler that let water out by design
ive seen it before but im not sure if yours has them o.e.
crawl under there and check exactly where its coming from
97 zj orvis/04 wj ltd/02 lancer oz rally/85 rx7 gs
970001zj is offline
post #9 of 9 Old 12-28-2013, 06:24 AM
DVB
2006 WK
Could it be coming out of the "weep hole" on the muff? I get a lot of condensation, I even get dripping from the middle of my exhaust, not sure if it's before or after the Cat. I heard it's normal too though.
2006 4.7 Limited QD II, Stock
DVB is offline
