EVIC not working - JeepForum.com
post #1 of 5 Old 07-09-2009, 06:31 AM Thread Starter
ccchris
2014 JK Wrangler
EVIC not working
2005 Grand Cherokee 3.7L.
At some point this morning my EVIC stopped displaying all information? It was working last night as it indicated that a rear door was not closed on my way home.
Anyone have this issue? I can not figure out if it is on its own fuse and I have tried to search the forum looking for similar problems but had no luck.
Any suggestions would be appreciated.
Chris
ccchris is offline
post #2 of 5 Old 07-09-2009, 09:55 AM
Texas WJ
Texas WJ's Avatar
2005 WK
I know this sounds stupid and I don't mean to insult you're intelligence, but you got to start with the simple stuff, have you tried flipping through the info readouts with the "step" button? I ask 'cause there's a setting on there that shuts off the display. Maybe you hit it by accident?
Texas WJ is offline
post #3 of 5 Old 07-09-2009, 11:24 AM Thread Starter
ccchris
2014 JK Wrangler
Not insulted at all, i use the evic frequently (L / 100km and trip) and checked the obvious. At first I thought I must have dimmed the cluster but the odometer shines brightly and the evic side is blank. Pushing the step etc does not do anything.
Any other ideas?
ccchris is offline
post #4 of 5 Old 07-19-2009, 08:54 PM Thread Starter
ccchris
2014 JK Wrangler
Seems like the evic is not serviceable and the only solution once it fails is to replace the entire cluster?
If any know this the be true please let me know.
thanks
ccchris is offline
post #5 of 5 Old 07-20-2009, 12:48 PM
colinzj
2006 WK
If it's a bad connector or solder joint, it can be repaired (although a dealer may not feel like it). Beyond that, yeah, the cluster board's replaced as an assembly.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline
Need help with Evic. kiesha WK Grand Cherokee & XK Commander Forum 6 02-14-2010 02:04 PM
EVIC Check Gas Cap vanmak52290 WK Grand Cherokee & XK Commander Forum 4 02-11-2009 05:36 PM
EVIC question JPK ZJ Grand Cherokee Forum 3 03-24-2008 03:11 PM
evic naeem ZJ Grand Cherokee Forum 7 12-11-2005 12:56 PM
Avg MPG / EVIC question HemimanNYC ZJ Grand Cherokee Forum 1 07-12-2005 11:57 PM
