ESP/BAS, traction control, ABS lights - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > ESP/BAS, traction control, ABS lights
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGrizzly Lockers available at Rockridge4wd.comThe ULTIMATE "Selectable" Locker System! Brough
Unread 10-21-2014, 10:48 AM   #1
BlackedTheFOut
I have read a bunch of posts about this in an effort to find an answer but nothing seems to point to the same issue I am having. So here it goes:
When I hit any sort of bumps or apply anything more than medium break pressure I feel a slight pull to the passenger side and then my ESP/BAS, traction control, ABS lights pop on. Once the lights are on my cruise control and ABS don't work. On most occasions the lights turn off after a couple minutes of normal driving.
Anyone have any clue where this issue might be coming from?
Black WK Club #115
Blacked Out-RC 2" lift-Billsteins-MB TKOs-265/70R17 Duratracs-pinch weld
BlackedTheFOut is offline   Reply With Quote Quick reply to this message
Unread 10-21-2014, 03:19 PM   #2
airportdave
2010 WK
Sounds like a faulty wheel speed sensor perhaps...
2010 Grand Cherokee Limited Hemi Q-D II, 4X Belly Guard. Diablosport InTune/HemiFever tune, K&N drop-in, 265/65/17 Hankook Dynapro ATM RF10's
airportdave is offline   Reply With Quote Quick reply to this message
Unread 10-21-2014, 04:11 PM   #3
FCNY
2010 WK
I had the same problem. I took it to the dealer and they replaced multiple parts and couldn't find the problem. I took it to my other mechanic and all he did was tighten the steering wheel and it never happened again.
FCNY is offline   Reply With Quote Quick reply to this message
Unread 10-21-2014, 09:28 PM   #4
modernblueWK
Wheel speed sensor loose? Mine got caked with mud, the sensor contacted the reluctor wheel and all the same lights came on. If you can get it scanned when the lights are on it will tell you where the problem is.
If you have an android device get a cheap elm327 bluetooth obd2 reader. $5-$10. You can plug it in and when the lights pop up pull over and see what codes you get.
2008 WK 4.7 245/70-17 Grabber AT2 - Magnflow - JBA - G2 - Steel Armadillo - MLL's
Blue WK club #4
modernblueWK is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 10:41 AM   #5
ISUzj
2005 WK
I have a similar issue on my jeep, its funny in the same way, I can be at a stop light, it turns green and if i hit the gas too hard and the front end comes "up" my ABS/ESP lights come on, but then can turn the jeep off and on and the code will be gone. This also happens if I go around a corner too fast.
you know which apps can read the ABS codes? I know not all of them do.
Can't wait to get started, but my wallet can......
~~~_______oooo_
~~ / ../...\...\_____\
~~[_---_____---_\-\\\\\\-\
~~~(o) )-o---(o) )-o---) )
94ZJ 5.2 Red; Rusty's 3" Coils,Skyjacker hydro's, Brush Guard, Custom Rear Bumper, Custom Roof Rack, KVG Quick Discos, 31-10.50-15's DAYTON TIMBERLINE A/T OBA 2 Gallon tank
Can't buy it? BUILD IT!! Do it cheap too cuz your in college
My Build Thread Align your jeep yourself B N B#175
ISUzj is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 10:47 AM   #6
modernblueWK
I do not know. Most likely the paid apps like dashcommand.
Blue WK club #4
Unread Yesterday, 08:50 PM   #7
ChrisWK
2005 WK
I had this problem with the ESP tuning on over speed bumps going slow the light turn on then off. I was in the mountain going on the twirling road the light comes on slows jeep then drives fine. I had my front shocks changed couple month ago and the install guy told me that my abs wire was rapped around the shock and it was pulling on the wire it was mounted correct and have not had a problem since.
Limited HEMI Dark Khaki Pearl SRT8 Full Body Kit, Roof Rails,SRT8 Engine Strut Bar, Lund Rear Spoiler, MYGIG INSTALLED with LOCKPICK, Kenwood Sub,AFE Intake, Taylor Spark Plug Wires,G2 Silver Painted Brake Calipers, Billet Tech Catch Can, Addco Sway Bars Front and Rear, Eibach Lowering Springs,Xenon Volt HID Lows 6k,Chrome SRT Reps
ChrisWK is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 10:20 PM   #8
modernblueWK
Yeah inspect your abs sensors.
Blue WK club #4
