ESP/BAS light on - JeepForum.com
post #1 of 6 Old 04-07-2009, 08:52 AM Thread Starter
campijr
ESP/BAS light on
Hi All, I have a 2006 Jeep Commander 4.7 litre with the ESP/BAS light on. Checked OBDII for codes. All I found was C0077 Low tire pressure. Thought I found problem when the low tire light ws on too. Tires were all low. Didn't put out ESP/BAS light I checked wheel sensors and all are reading the same going done road. I looked for damage to undercarriage (none) The steering wheel is straight. Anyone have same problem? Any help would be great
campijr is offline
post #2 of 6 Old 04-07-2009, 10:08 AM
merlinTec
merlinTec's Avatar
Hi
I can’t see why you don’t have any codes if the light is on. All I can think is your scanner can’t read the codes. Even if the ABS module went down you would get a loss of comms DTC set against it from other module. Suggest try another code reader.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #3 of 6 Old 04-07-2009, 01:13 PM
WSPJeep
I had the same problem, just go and get your PCM reflashed, im pretty sure thats what fixed mine or it may have been a TSB. check out wkjeeps.com and look for that TSB.
Matt
'90 YJ- 4 bangin on 32's
'72 Dodge Dart 318 V8, 2 door
WSPJeep is offline
post #4 of 6 Old 05-03-2009, 06:47 PM
CreepCommander
I just had brand new tires put on my 2006 Jeep Commander a couple of days ago. Immediately after I drove away from the tire place the low tire pressure light came on even though the tires were not low. The light went off after I turned the Jeep off then back on again. Today when I got into my Jeep, the "ESP BAS" light and the "Traction Symbol" light came on and stayed on. When I turned the Jeep off and then back on again the lights were gone. Does anybody have any clue what this means? Do you think it has something to do with me putting new tires on it?
CreepCommander is offline
post #5 of 6 Old 05-03-2009, 07:39 PM
WSPJeep
Have you had your PCM reflashed at the dealer?
Matt
WSPJeep is offline
post #6 of 6 Old 05-03-2009, 07:56 PM
JeepGuy026
2011 WK
I put new wheels on my Jeep Soon After somehow i broke a wheel speed sensor so it could be a problem with one of them too possibly. I had the Same Issues a WK of Course.
2006 Jeep WK Grand Cherokee Limited 5.7
( Midnight Blue Pearl Coat)
Leather, Nav, 4x4 Package, Khaki Interior
JeepGuy026 is offline
tail light not working - brake light does work gd929 ZJ Grand Cherokee Forum 2 06-17-2010 12:29 AM
OIL LEVEL GAUGE, AIR BAG LIGHT & ABS LIGHT SHOWING ON DASHBOARD - WJ Model babix0ashh ZJ Grand Cherokee Forum 6 01-19-2010 12:48 AM
gcl 4.0 driving light/brake light/turnsignal issues msherman1 ZJ Grand Cherokee Forum 1 01-05-2010 09:23 PM
Super cheap headlight, marker light, directional light kit... thoughts? aaron7 ZJ Grand Cherokee Forum 13 01-07-2009 06:17 PM
Tail Light Doesn't work, brake light does? venterminator ZJ Grand Cherokee Forum 0 08-04-2007 07:58 AM
