esp acting up after ome hd instal - JeepForum.com
post #1 of 10 Old 03-05-2014, 09:05 PM Thread Starter
ChrisMartin921
2006 WK
esp acting up after ome hd install
I installed the ome hd lift on my 06 grand Cherokee and had it aligned after the install. I also put 17x8 xd series wheels with 35 offset and 265-70-17 terra grapplers. I was getting on the highway and was going about 30mph on the on ramp and the traction control came on and the ESP grabbed the front brake but I wasnt sliding. Any way the esp can be reworked to not be so sensitive?
ChrisMartin921 is offline
post #2 of 10 Old 03-05-2014, 09:45 PM
fafafofi
2006 WK
Read the "JK rubi take offs" thread. A few of is talking about that there. My guess is need for lift specific UCAs to help with alignment but I'm no expert. Let me know if you start getting a squeak from the ball joints. I have a theory it happens at full lift before the need for a super lift
fafafofi is offline
post #3 of 10 Old 03-06-2014, 05:53 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
This is a common issue. IMO more common in the 4.7s as the QTII system also uses the btc to limit wheel slip (this on top of esp). Could be wrong........
Several have suggested disabling the esp. Personally I'd just keep a close eye on specifically when the rig does this and note your turn radius and speed - then adjust driving style accordingly.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is online now
post #4 of 10 Old 03-06-2014, 08:24 AM
skibum555
2005 WK
Yep, I started the Rubi Take off thread and since I started taking it a little easier I haven't had any issues with it. My 05 QDII only freaks out if I take a slight curve at speed. I have just toned down my aggressive entry into corners and no ESP!!! another option would be to drive around with my ESP off...but I never remember to push the darn button.
Jeepin ain't easy...
Proud Member of the BlAcK wK club
MEMBER #105
skibum555 is offline
post #5 of 10 Old 03-06-2014, 10:38 AM
sk1er18
2007 XK Commander
Did you reprogram the tire size? And if you did, did you measure the effective radius of the tire to determine the "actual" size that the computer should be programmed to?
-Matt
sk1er18 is offline
post #6 of 10 Old 03-06-2014, 11:12 AM
BAH101
2008 WK
I have the same size tires, (different type though) with OME lift and never had an issue with traction control. I wonder if you have a bad sensor, or a partially disconnected sensor plug from installation. Might be a good place to start.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #7 of 10 Old 03-06-2014, 01:11 PM
trax95008
2006 XK Commander
The issue is tire size. The computer needs to be told your actual tire size, so that it knows your actual speed. The problem is that with larger tires, you going faster than the computer knows. So when you take a turn, the gyroscope measures a certain amount of yaw, and because the computer thinks your going slower, that's too much yaw for the speed and thinks your about to roll over. Telling it you have larger tires, it knows your actually going faster, and that amount of yaw is normal for that speed
trax95008 is offline
post #8 of 10 Old 03-06-2014, 02:04 PM
skibum555
2005 WK
For the win!! I was second guessing myself about where the confusion was occurring as far as the stability system... it's that damn YAW.... lol thanks man. This will put my worries to rest. Now to find find a used superchip or other tuner.
MEMBER #105
post #9 of 10 Old 03-06-2014, 03:13 PM Thread Starter
ChrisMartin921
2006 WK
I used the flashpaq 3872 to calibrate the speedo. And yes I measured the tires to find correct size
06 grand Cherokee 4.7L. OME HD lift, XD series heist 17x8 35offset wheels, 265-70-17 terra grapplers, Superchips 3872 with trans tune. K&N filter, interior l.e.d.'s, custom l.e.d. lighting in headliner.
post #10 of 10 Old 03-07-2014, 10:25 AM
audiophonicz
2007 WK
Its inherant to our Jeeps. I have the exact same thing above with twice the lift + the EGR module. Just gotta take them ramps slow.
Its also fun when you hit 50 way out of alignment with your steering wheel at 2o'clock going dead straight. ESP freaks out and disables itself.
audiophonicz is offline
