Engine size questions - JeepForum.com
post #1 of 15 Old 04-19-2010, 08:29 PM Thread Starter
hughes278
I already have a 2007 WK but it is my "wife's" vehicle. Within a couple of months I am looking at getting another one. Right now the one we have is V6 and it is all-wheel drive. It gets on avg. 15 miles a gallon. I want to get mine in a V8... probably the 4.7. I do not want it to be all wheel drive but still 4x4 capability of course.
I suppose I will finally get to the question. Do you think I will get worse gas mileage than I already do in my V6 if I get the 8?
hughes278 is offline
post #2 of 15 Old 04-20-2010, 08:04 AM
dsalinas
2006 WK
theoritically, yes you will get slightly lower mpg, my guess 14ish city. That is such a low displacement between v6 and v8, I would go V8. I'm getting 13.5 all city with hemi and MDS disabled. If you can't get a 5.7, try to get 08+ 4.7 with the added power. Both are very strong drivetrains.
dsalinas is offline
post #3 of 15 Old 04-20-2010, 12:57 PM
345jeep
2008 WK
You will get about 1-1.5 MPG worse in both city and higway with a MDS Hemi V8 vs. the V6.
2008 GC Overland 4x4 Trail Rated
2001 Cherokee Limited 4x4 (Sold)
1982 Wagoneer Limited 4x4 258 6cyl (Sold)
345jeep is offline
post #4 of 15 Old 04-20-2010, 01:27 PM
thewalrus
2005 WK
If its 4WD its ALWAYS 4WD, no choice. Most have 4-lo though, but no option for 2WD only.
-Thanks
ASE Master Tech
thewalrus is offline
post #5 of 15 Old 04-20-2010, 07:49 PM
Dreezy
1990 FSJ Wagoneer
If you can find a deal, get the HEMI. They all get within 2mpg of each other. I do like my 4.7 though. I just wish I had the qudradrive II, but I didnt know and got a laredo with qudratrac II.
Dreezy is offline
post #6 of 15 Old 04-21-2010, 05:37 AM
Devilsmed98
Go with a Hemi. I have a 2007 4.7L and I must say, the power is a lot nicer over a V6, but from what I've heard the gas mileage is about 1-2mpg between each model. And trust me, you want 4wd, especially if you get the Hemi. It's nice coming up to red lights and some ******* in a ricer next to you thinks he can beat you and your 4wd helps you grip that road while he's in your rear view mirror still squealing and slipping.
Another thing I would also go back on if I had the chance, make sure the 4wd is Quadra-DriveII. My QTII is fine but those lockers make a difference.
~Black WK Club Member #9~
2011 WKII Overland
2007 WK Limited[/COLOR]
1995 YJ Rio Grande
Devilsmed98 is offline
post #7 of 15 Old 04-21-2010, 08:33 AM
Jims9507
2007 WK
Buy a V8 (4.7L or the 5.7L Hemi)........ If you're worried about a gas crisis, remember the 4.7L also runs on E-85.
Jims9507 is offline
post #8 of 15 Old 04-21-2010, 08:35 AM
Jims9507
2007 WK
How do you disable the MDS ??
Jims9507 is offline
post #9 of 15 Old 04-21-2010, 10:35 AM
Megaman7
2005 WK
It can be disabled through a programmer, like superchips unit.
Megaman7 is offline
post #10 of 15 Old 04-21-2010, 10:39 AM
Jims9507
2007 WK
Wow, didn't know that. Thanks for the info
Jims9507 is offline
post #11 of 15 Old 04-21-2010, 04:04 PM
Dreezy
1990 FSJ Wagoneer
on 07 (i think) and up.
Dreezy is offline
post #12 of 15 Old 04-22-2010, 06:15 AM
Jims9507
2007 WK
Mine is an 07 4.7L and is able to use E-85. Not sure about other years.
Jims9507 is offline
post #13 of 15 Old 04-22-2010, 07:33 AM
Devilsmed98
I have a 2007 4.7 and it shows nowhere on it that it is flex fuel.
2011 WKII Overland
1995 YJ Rio Grande
post #14 of 15 Old 04-22-2010, 08:37 AM
Jims9507
2007 WK
Mine has a yellow gas cap that says E-85 in black. No other marking on the vehicle. I know they use to put a little "Flex/Fuel" tag on the rear hatch (right side) but haven't seen them on any in traffic recently. I bought my Jeep used so it may have been there and fallen off ?? Who knows ?? Since the fuel cap is attached with a plastic cable I would think it's original too. I wonder if you would be able to tell by the VIN # ?? Maybe someone reading this could help....................
Jims9507 is offline
post #15 of 15 Old 04-22-2010, 08:39 AM
Jims9507
2007 WK
The following is from the '07 Owner's manual:
FLEXIBLE FUEL (4.7L ONLY) — IF EQUIPPED
E-85 General Information
The information in this section is for Flexible Fuel
vehicles only. These vehicles can be identified by the
unique fuel filler door label that states Ethanol (E-85) or
Unleaded Gasoline Only. This section only covers those
subjects that are unique to these vehicles. Please refer to
the other sections of this manual for information on
features that are common between Flexible Fuel and
gasoline only powered vehicles.
CAUTION!
Only vehicles with the E-85 fuel filler door label can
operate on E-85.
ETHANOL FUEL (E-85)
E-85 is a mixture of approximately 85% fuel ethanol and
15% unleaded gasoline.
Jims9507 is offline
engine size , gas mileage
Firestone Destination MTs and tires size questions jeepgc99lmtd ZJ Grand Cherokee Forum 11 10-23-2009 03:32 PM
WK CRD: Engine to Tranny Bolt Size Tuco WK Grand Cherokee & XK Commander Forum 1 09-25-2007 09:29 AM
Lift/Rim/Tire Size Questions JohnnyBighead WK Grand Cherokee & XK Commander Forum 2 07-18-2007 08:40 AM
Lifting my WJ questions/tires size Dacaur WJ Grand Cherokee Forum 9 04-29-2004 01:09 PM
Dumb Questions - what CU IN engine size? Scottsdale Jack WJ Grand Cherokee Forum 2 08-01-2003 07:12 PM
