Engine problems - Page 2 - JeepForum.com
post #16 of 25 Old 08-15-2013, 09:06 AM
tjkj2002
2002 KJ Liberty
Originally Posted by DRCracker View Post
Are there any real mechanics anymore, or are they just computer techs?
Get a mechanic who can work on a car that doesn't have a computer, he'll figure out the problem.
My guess, fire, air, or fuel; one of those is screwed up.
TC
In today's vehicles the computer(PCM) controls all of those.Mechanics are part changers,technicians find the problem and fix it.
We had a old school mechanic(63 years old) who never worked on modern vehicles with computers,he lasted 1 day after he spent almost a hour trying to figure out how to reset the "oil change required" light in a '05 Suburban.
tjkj2002 is offline
post #17 of 25 Old 08-15-2013, 10:29 AM
DRCracker
2006 WK
Soon our Doctors will be just the same; if the computer can't figure out what's wrong with you, then nothing's wrong with you!
We need more people who can diagnose the computer(computer tech's I guess) so the computer can diagnose the engine/machine?
TC
MOLON LABE: 2006 WK Limited, Dark Khaki Pearl, 5.7 HEMI, QDII,
Console XDs-45acp, Billet Catch Can, Airaid CAI Tube,
1" Spacers, Steel Armadillo Sliders, Dark Khaki 4xGuard Front Skid,
Dark Khaki 2011 #9104 Wheels, Firestone Destination A/T 265/70/17's.
OME HD lift. Dark Khaki Matrix Brush Guard, Dark Khaki Painted Headlight Bezels.
Hemi Club #65 // Khaki WK Club #40
DRCracker is offline
post #18 of 25 Old 08-15-2013, 11:17 AM
tjkj2002
2002 KJ Liberty
TC
Do you even know what your looking for when diagnosing a modern engine? You got short term fuel trims,long term fuel trims,MAP sensor readings(or MAF sensor),O2 sensors voltages,and many more.A multimeter is not enough these days,you need to see what the PCM is recieving from the sensors to know what's going on otherwise your just down to replacing parts till it's fixed.
tjkj2002 is offline
post #19 of 25 Old 08-15-2013, 03:14 PM
DRCracker
2006 WK
We don't really disagree.
I guess engine/emissions controls are so complicated now that it takes a computer to manipulate each variable.
I'm just saying that maybe a human brain (used to be called a mechanic) that understands the way the engine is working could spend some time trying to figure out the defect, since the computer is unable to see it with it's limited number of sensors and inputs. Maybe a human brain could figure out where to look for the defect.
Poor computer doesn't have sensors for everything.
Let's not fight.
TC
post #20 of 25 Old 08-15-2013, 04:07 PM
tjkj2002
2002 KJ Liberty
Let's not fight.
TC
Yes you do need to understand how a engine works and what all the sensors are but the PCM does monitor everything in these newer engines(OBDII).Talking about everything from timing,air/fuel ratio,injector modulation,altitude,air temp,oil pressure,exhuast temps,misfires,knock sensors(if you have them),and the list goes on and on.On OEM scanners you can look through about 100+ different parameters monitored by the PCM,then you got the BCM,TCM,ABS,and all those other computers also.
tjkj2002 is offline
post #21 of 25 Old 08-15-2013, 07:40 PM Thread Starter
slickdevil08
2005 WK
Yeah but on these engines if the fuel pump is on the way out It will not throw a code or say anythings wrong
Sent from AutoGuide.com App
2005 Grand Cherokee Limited
Blacked Out Emblems
slickdevil08 is offline
post #22 of 25 Old 08-15-2013, 09:00 PM
tjkj2002
2002 KJ Liberty
It can if it's a slowly dying pump in misfire codes,knock sensor codes,lean codes,and/or o2 codes.A sudden death of a fuel pump will not but you will be left with a crank no start condition which the 1st thing you check is fuel pressure anyways.
tjkj2002 is offline
post #23 of 25 Old 08-16-2013, 12:45 AM Thread Starter
slickdevil08
2005 WK
Well my biggest gripe is that it has stalled 3 times on me while in drive and it tends to sputter and at idle it shakes the whole jeep but the techs keep saying that's normal .... That doesn't seem normal to me
Blacked Out Emblems
post #24 of 25 Old 08-16-2013, 09:25 AM
XK1982
2006 XK Commander
Where did you get this Jeep from? Did you buy new? I might be skeptical that the previous owner (if there is one) may not have disclosed all that's happened in this jeep's past.
2006 XK Commander, 4.7L V8, Quadra-Trac II, 6.25" Modified Superlift, Jeepin by Al's front UCA's, Rusty's Adjustable rear LCA's; 35x12.5R17 TOYO Open Country MT's; Method NV305 17x8.5 wheels
XK1982 is offline
post #25 of 25 Old 08-16-2013, 12:50 PM Thread Starter
slickdevil08
2005 WK
I got it from a dealership that swears its a great running jeep and it was a one owner when I got it
Blacked Out Emblems
