Elephant Hose Installation step by step 3.0L CRD - Page 4 - JeepForum.com
post #46 of 133 Old 02-07-2012, 10:10 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
Originally Posted by BigSensFan View Post
So I ran mine down the front like you.. but looking today, I was wondeirng why not simply run it down the left side (passenger side) of the firewall as there is a space there that would work... is there a reason for going front of engine instead of behind it?
I did not choose that path because I did not want to make in sharp turns in the hose path. It certainly could go that route.
Chirpz
2007 WK 3.0L CRD, Quadradrive II, GDE EcoTune, DPF-Delete
4xGuard Front, Rear, Belly, & Side Rails, Factory Skids
EHM MOD, Garmin Mechanic EcoHD, K&N Filter (Deleted)
Chirpz is offline
post #47 of 133 Old 02-08-2012, 11:54 AM
ktmkris
2008 WK
my 2008 with 50,000 miles puffs out a hefty amount of smoke here and there. I was told the sensor thing that is hooked up between the ccv and intake was actually a heating unit to burn or vaporize the oil that went through it. So that would mean any smoke that comes through is a result of the sensor or Could be a a partially clogged ccv spurting more oil out. I have a extensive background with diesel engines, with my maintenance and mobil 1 I seriously doubt it is a major blow by issue. Also if blow by was that bad, there would be issues of losing oil, fuel contaminating the oil and It is not showing. I have seen mercedes diesel engines log 350,000 with no trouble.
2008 jeep grand cherokee 4x4 3.0 crd limited 50,000 miles,GDE eco tune,dpfe delete. mbrp dpf back exhaust gutted resonator mod, ehm, rock krawler 3.5 inch x factor lift, rough country 1.5 wheel spacers,Rusty's offroad diff guards, k&n drop in, 275/75-17 bfg km1's,tinted windows.....on the way:custom cold air intake.
ktmkris is offline
post #48 of 133 Old 02-08-2012, 12:27 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
EHM Smoking
I have had my EHM since Sept of last year. It rarely smokes and occasionally emits a smell. I DO have some smoke under certain conditions. If it is a hot day and I just did something that stresses the engine, like zipping up a steep grade, then I get a some smoking when I stand still and go to idle.
I have not yet seen any convincing evidence regarding that funny device. Some say it is a heater, some say it is a temperature sensor. I've seen lots of opinion about it but no hard evidence such as a document, part number with a name attached to it, etc. I left mine in place, so maybe it still functions.
Chirpz
Chirpz is offline
post #49 of 133 Old 02-08-2012, 07:27 PM
CRD Dawg
2008 WK
Go to Sprinter Source forum. NCV3 section (2007 & newer Sprinters). Dig around. You will find the same issues there. Leaks from the intake tube. Orange seal. Black seal. Swirl motor & valve failures. Misdiagnosed oil leaks. It's all there... There are plenty of high mileage OM642s. Multiple there claiming well beyond 300k. But not without these issues. The swirl system is the weak link with this engine. Hopefully I've addressed that issue before it arrives. Reduced EGR and no blowby recirculation.
2008 Grand Cherokee Limited 2wd CRD-InMotion Stage 2 Tune, K&N Air Filter, Elephant Hose CCV Mod, Gutted Turbo Resonator, MBRP Pro Series Exhaust
CRD Dawg is offline
post #50 of 133 Old 02-18-2012, 01:47 PM
jiggadog
2008 WK
i just finished the EHM. really straight forward, but for the few minutes the jeep was idling after i finished, it was smoking, but temp is around freezing so i'm not sure if it's condensation or what. hope it works out and along with the new seal (changed about 10k km ago) prevents or at least prolongs potential swirl motor issues.
jiggadog is offline
post #51 of 133 Old 04-27-2012, 05:08 PM
terrasmak
2007 WK
http://saikoufabrication.blogspot.co...&max-results=3 I wonder how a breather like this one would work on the CRD
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
terrasmak is offline
post #52 of 133 Old 12-16-2012, 10:23 AM
nemesisngr
2008 WK
Awesome
So, getting my "swirl Motor" done this coming week. (Wen't at 178k km).
I've looked, but can someone please direct me how to trick the computer to think the swirl is working (swirl delete). Pics, links, or what-ever.
Does the "new" hose with the black gasket fix the oil getting into the swirl motor problem?
Thanks for all your input.
Cheers.
2008 GC 178k Km.
nemesisngr is offline
post #53 of 133 Old 12-16-2012, 12:03 PM
DieselDevotion
2007 WK
Cheers.
2008 GC 178k Km.
http://www.jeepforum.com/forum/f67/c...istor-1380618/
07 Grand Cherokee Limited 3.0L CRD QDII
89 5.9 Cummins powered F350
98 TDI Jetta
DieselDevotion is offline
post #54 of 133 Old 03-08-2013, 02:47 PM
mathetes
2007 WK
Just finished the EHM. Thanks Chirpz for your step by step detailed instructions. Soon I will do the gde tune, but hopefully I won't have the swirl motor failure until then.
mathetes is offline
post #55 of 133 Old 12-24-2013, 05:30 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
Hmmm..... I just noticed that I have been using the EHM since June 2011. I still have not seen a single drop of oil dripped on the driveway.
Chirpz
Chirpz is offline
post #56 of 133 Old 12-26-2013, 01:47 PM
GDE
2005 KJ Liberty
The device between CCV and intake is a small heater to prevent CCV gases from freeze-up issues. It is just a warming device and does not get very hot. Condensation can be a problem with an EHM if it is exposed to cold air. If the pipe were to get a blockage in very cold weather it could lead to a blown crank seal due to block pressurization.
Not overfilling the oil should minimize the blow-by.
GDE is offline
post #57 of 133 Old 05-12-2014, 09:37 AM
sfoster4
2008 WK
So if I live in Minneapolis MN, winter here could be an issue for the EHM?
sfoster4 is offline
post #58 of 133 Old 05-12-2014, 09:56 AM
CRD Dawg
2008 WK
I incorporated the heater into my EHM. Is it necessary?
CRD Dawg is offline
post #59 of 133 Old 05-12-2014, 10:01 AM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
I would like to know more about that little "heater" in the CCV. I've never heard a convincing argument about it.
If it truly is a heater, does it function while the car is turned OFF and is just sitting there in the cold.
If that is not the case, WHEN does it function. If you crank your engine it is too late for it to do any good because you would be producing pressure against a blocked hose that has not had time to thaw.
You certainly don't need it once the engine is warmed up. Also, there is no time for it to do anything between the time you turn the key and the engine fires. Try to imagine an instant heater. Have you ever tried to melt an ice cube with a propane torch.... it melts fast but still takes time.
If it functions when the car is turned OFF, that would make sense....sort of like a block heater for the CCV hose. But it would protect only a short segment of the hose. If you have a long cold spell and don't use your car...does your battery drain down? How many watts does it draw?
I realize freezing is a problem....but I'm a CCV Heater skeptic. I don't know what the thing is....... but the heater idea makes no sense to me.
May be someone has a part number that also has an identifying label. Something like "MB4198583 - CCV Heater" (I made that up) That would be convincing.
I'm not trying to make trouble here.... Just expressing my my questions and doubts. I'd really like to know for sure.
Chirpz
Chirpz is offline
post #60 of 133 Old 05-12-2014, 10:06 AM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
I left mine in place when I did the EHM but I'm not convinced it is a heater.
Chirpz
Chirpz is offline
Elephant Hose Mod Version 2.0 CRD Dawg WK Grand Cherokee & XK Commander Forum 129 07-20-2016 06:59 PM
IRO ZJ Front Long Arm Install ( Step by Step Pics ) CLNinja ZJ Grand Cherokee Forum 64 04-01-2009 01:23 PM
would you buy another zj or step up to a wj ? or is it step down ? crazydude2500 ZJ Grand Cherokee Forum 120 08-27-2008 08:38 PM
step X step cruise control diag IronManVa ZJ Grand Cherokee Forum 12 11-18-2007 02:42 PM
next step after BB grandman97 ZJ Grand Cherokee Forum 9 03-16-2005 11:21 AM
