Elephant Hose Installation step by step 3.0L CRD - JeepForum.com
post #1 of 133 Old 06-18-2011, 07:29 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
A ruined swirl motor aroused my interest in the Elephant Hose Modification. After reading all about on this forum, I decided to do it. Others have posted descriptions of their EHM's. This is how I chose to perform the task.
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #2 of 133 Old 06-18-2011, 07:38 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
EHM install continued
continuing....
Chirpz
Chirpz is offline
post #3 of 133 Old 06-18-2011, 07:43 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
final steps ....
Chirpz
Chirpz is offline
post #4 of 133 Old 06-18-2011, 07:52 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
EHM install in PDF format
If you want to download the procedure with the photo in a nifty PDF file that you can save and print, click the link below.
http://www.chirpz.com/swirl/Elephant_Hose.pdf
Chirpz
Chirpz is offline
post #5 of 133 Old 06-18-2011, 10:24 PM
TurboDiesel
2008 WK
FINALLY!!! thanks so much man for makin a step by step
ive read all the other "how-too's" but they just didnt make sense
i am FAR from a car guru and needed step by step instructions and the word "thingy" is probably more helpful than the actual parts name ahha
thats awesome, i gotta do this on my 08, havent noticed any problems and im at 94xxx KMS right now, but better to be safe than sorry
TurboDiesel is online now
post #6 of 133 Old 07-05-2011, 09:27 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
EHM smoke
On July 4th we took a 111 mile trip. Warm day, mid 80's. During one part of the trip we drove up a fairly steep, long grade. We were not going fast since it was curvy and we were looking for geocaches all along the route. When we arrived at the top, my wife got out of the idling WK and said, "Hey, what is all this smoke?"
I immediately checked my temp gauge and it was OK. I looked and there was hot vapor, hardly visible, rising from my passenger wheel well. It smelled a little oily.
This is the first time we have noticed any output from the new EHM. Most of the day, there was noticeable emmissions from the hose.
By the way, we found 95 geocaches that day.
Chirpz
Chirpz is offline
post #7 of 133 Old 07-06-2011, 08:25 AM
suzieque
2008 WK
I think I'm most concerned when a new CRD owners asks "what kinds of problems CRDs have?".
Helpful fellow CRD owners on this site direct those questions to the threads about the swirl motor failure and then he/she posts back, "Well my CRD is running fine right now, I'm not going to do any mod to it."
sadly, it's that owner that comes back on line later and says "guess what, I got a check engine light and the dealer wants $1000 what should I do?"
the best time to do preventitive maintenance is before the system fails.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #8 of 133 Old 07-06-2011, 05:45 PM
TurboDiesel
2008 WK
which is what i said....
i never asked what problems they have, every car has its problems
i hope ur not callin me out i dont see how i said anything wrong?...
post #9 of 133 Old 07-06-2011, 05:48 PM
SSF556
2008 WK
I think with the swirl motor it is only time until it fails. I believe you can polish the turd (swirl motor, not the Mercedes engine) but it is still a turd.
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #10 of 133 Old 07-06-2011, 05:58 PM
TurboDiesel
2008 WK
yea i heard that its not necessarily the oil that kills the swirl motor its just a crap part to begin with lol
post #11 of 133 Old 07-06-2011, 07:18 PM
suzieque
2008 WK
nope, I think its great that you are asking the right questions, reading the threads, educating yourself, and doing what folks here suggest with respect to catch cans, new air intake tubes, cleaning up the oil leak etc.
suzieque is offline
post #12 of 133 Old 07-06-2011, 07:32 PM
TurboDiesel
2008 WK
oh okay good
yea i read all the threads and try to educate myself on problems that could go wrong just incase it ever does go wrong
i dont know much about cars so these forums really help out a guy like me quite abit
post #13 of 133 Old 07-06-2011, 10:18 PM Thread Starter
Chirpz
Chirpz's Avatar
2007 WK
Believe me, its the oil. Check out the pictures I posted on one of the other threads. When I cracked my old swirl motor open, I must have poured 1/8 of a cup of oil out of the inside of the "sealed" motor. It just can't take having that slow drip of hot oil that seeps from that faulty intake seal. It works its way into the motor and eventually kills it.
Chirpz
Chirpz is offline
post #14 of 133 Old 07-06-2011, 11:55 PM
Tuco
Tuco's Avatar
2007 WK
Yep, its probably the oil. Ours didn't look oil contaminated, but after closer look it was oil contaminated. It can also fail if too much oil gets into the intake and gums up the swirl flaps. Anyone with this CRD engine should get the improved intake tube and do some kind of mod like EHM or filter.
07 WK CRD Limited
Tuco is offline
post #15 of 133 Old 07-27-2011, 06:02 PM
BigSensFan
2007 WK
So the end under the Jeep, is that simply a drain end (onto the pavement) or is there a catch can under there?
BigSensFan is offline
Elephant Hose Mod Version 2.0 CRD Dawg WK Grand Cherokee & XK Commander Forum 129 07-20-2016 06:59 PM
IRO ZJ Front Long Arm Install ( Step by Step Pics ) CLNinja ZJ Grand Cherokee Forum 64 04-01-2009 01:23 PM
would you buy another zj or step up to a wj ? or is it step down ? crazydude2500 ZJ Grand Cherokee Forum 120 08-27-2008 08:38 PM
step X step cruise control diag IronManVa ZJ Grand Cherokee Forum 12 11-18-2007 02:42 PM
next step after BB grandman97 ZJ Grand Cherokee Forum 9 03-16-2005 11:21 AM
