Electronic Shift Module - JeepForum.com
post #1 of 6 Old 04-09-2009, 07:06 AM Thread Starter
MassRedneck
I have an 06 grand cherokee v6 with about 50k on it. Recently the malfunction indicator light has come on randomly. I had a local garage read it and they said it was the ESM. Brought it to jeep for a "complimentary oil change" they too read the code and said ESM and want almost 700 to fix it. Does anyone know anything about this? is it possible to do myself?
REDNECK
If its a jeep thing I have or will break it at least once
MassRedneck is offline
post #2 of 6 Old 04-09-2009, 12:28 PM
JMorash
2005 WK
You gotta bring it into the dealership so the ESM can get reflashed. As long as the check engine light is on and the car isnt working right. The dealership has the only tool to fix it or replace it, You should be covered under the powertrain warranty since your under 70k miles.
2005 WK 5.7L Hemi
HEMI Club Member #28
3.5 Rock crawler lift.265/65R17 Toyo AT SuperChips Flashpaq MDS delete
JMorash is offline
post #3 of 6 Old 04-09-2009, 05:43 PM
Nejeep
I believe the ESM is the electronic stability module not shift module, but in any event the dealer is probably your only option. Also your 06 would only have 3/36 factory warranty unless you bought an extended warranty.
Good Luck
06 Laredo - 4x4 V6 - Stone White - Custom LED Cargo Area Lights, Lighted Visors Added - now at 49k miles
97 Laredo - 4.0 4x4 Daily driver for 8 years then relocated to Arizona for 6 more years with the relatives
Nejeep is online now
post #4 of 6 Old 04-10-2009, 04:23 AM
merlinTec
merlinTec's Avatar
Hi
ESP is electronic stability Program ESM is electronic shifter module and you can change it yourself follow the TSB on shifter bezel.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #5 of 6 Old 06-02-2016, 03:53 PM
jharrell
I have found that a pencil eraser works best in cleaning the runs on the ESM. It cleans off all of the graphite so the fingers can run smoothly on the runs.
jharrell is offline
post #6 of 6 Old 06-03-2016, 09:13 AM
skibum555
2005 WK
Most shift modules work on any model. For instance, I used a module from an 06 WK 2wd on my wife's 07 Commander 4wd QTI and have had ZERO issues with it. I picked it up for 125 from ebay after I saw the dealer price of the unit. simple install no hassles or modification needed.
Jeepin ain't easy...
Proud Member of the BlAcK wK club
MEMBER #105
skibum555 is offline
U0103 Lost Communication to Gear Shift Module goody9825 WK Grand Cherokee & XK Commander Forum 9 11-11-2011 10:32 AM
Gear Shift Module wim3324 WK Grand Cherokee & XK Commander Forum 11 08-30-2011 08:07 PM
Body Contorl Module or Door Control Module?? Drdan524 ZJ Grand Cherokee Forum 4 05-19-2010 01:04 PM
Driver Door Module or Body Control Module ronmaynard ZJ Grand Cherokee Forum 3 04-28-2008 08:13 AM
electronic display xirnibor ZJ Grand Cherokee Forum 3 07-21-2004 10:01 PM
